chevy aluminum heads 10088113 - Yellow Bullet Forums
Old 01-24-2012, 11:10 PM   #1
awake1630
Member
Pullin gears
awake1630's Avatar
Default chevy aluminum heads 10088113
Anybody have any information on these castings? 10088113
chevy aluminum factory heads
Flow numbers?
What would be a good deal on these heads?
Would they be suggested?
Anybody use them with positive results?
1969 Camaro
10.83 @ 123.33
1.53 - 60 foot
SBC
Brodix track 1 2.08/1.60
Ford Aod
4.33 gears
4 wheel Disc brakes
E85
awake1630 is offline   Reply With Quote
Old 01-25-2012, 08:54 PM   #2
62chevynova
62chevynova's Avatar
Default Re: chevy aluminum heads 10088113
88-90 350cid heads with 194 int valve. 163 intake volume. It depends on what your motor is for. They are like using 305 heads on a 350 it seems to choke the motor down. I would save your money for AFR heads or something compairible. Buying a great set of heads is the #1 best thing you can do for your combo just make sure it isnt too big of a runner cause I've done that before too
62chevynova is offline   Reply With Quote
Old 01-25-2012, 09:54 PM   #3
ten5nova
Beer me!!
ten5nova's Avatar
Quote:
Originally Posted by 62chevynova View Post
88-90 350cid heads
What did they come on, Corvettes?
ten5nova is offline   Reply With Quote
Old 01-25-2012, 10:05 PM   #4
AdvAutoBob
This Space For Lease
AdvAutoBob's Avatar
Corvette 98 Tuned Port Injection heads... they can be worked with for a mild street build, but not worth the effort if you're looking for serious HP.
Robert
"chance favors the prepared mind..."
Advanced Automotive of Cape Coral
"SW Florida's FULL SERVICE Speed Shop"
DW2013 - DNF (trans failure)
DW2014 - Street Race BB/PA winner
DW2015 - Just glad I survived!
DW2016 - 3rd place - Ultimate Iron
DW2017 - What am I driving?
AdvAutoBob is offline   Reply With Quote
Old 01-25-2012, 10:18 PM   #5
ten5nova
Beer me!!
ten5nova's Avatar
Quote:
Ok, L98 heads is what I was thinking. Yes, I've seen them used in other applications, and they are not worth the time, money, and effort.
Old 01-25-2012, 11:49 PM   #6
awake1630
Member
Pullin gears
awake1630's Avatar
they were for sale locally 300
but ill pass on them thn.
1969 Camaro
10.83 @ 123.33
1.53 - 60 foot
SBC
Ford Aod
4.33 gears
4 wheel Disc brakes
E85
Old 01-26-2012, 01:27 AM   #7
62chevynova
sorry to disappoint you But Ive been down that road of trying to save money only to spend twice as much a year later. what type of set up did you want them for. They might be good for like a 4wd offroad where you need low end torque.
Old 01-26-2012, 01:32 AM   #8
62chevynova
for 450 my brother bought a set of 200cc dart platinums bare that are new.these would be a better deal if you already have valves
Old 01-26-2012, 01:38 AM   #9
ten5nova
Beer me!!
ten5nova's Avatar
Vortec heads are always a good low cost option, they make awesome torque, and decent horsepower numbers for such a small port volume, 170cc. There are several aftermarket Vortec heads that are affordable as well.
Old 01-26-2012, 04:12 AM   #10
allend43
allend43's Avatar
Location: Californys the place ya outta be, so we loaded up the truck and moved to Beverly...hills, that is...
Jegs aluminum heads would be a lot better flowing deal, for not much more money, and much thicker decks. Vortecs flow much better too, for a factory head.
allend43 is offline   Reply With Quote
Old 02-02-2012, 08:41 PM   #11
tahoe
Spooled up
Flow about 190-195 @ .500ish. For what its worth, I bowl blended a pair pretty quickly, left them in carbide, flowed low 230's with the stock valve, put them on an undecked flat top 350 engine....9.7-1 compression or so..(piston was waaay in the hole), with a performer rpm manifold, a sizey hydraulic camshaft, 248/254 @ .050, .520/.520 on a 110 lsa, 750 holley dbl pumper, 4.10 gear, 4500 converter, ran easy low 12's at 3550 lbs. Im sure with more gear and time, 11's would be do-able.
tahoe is offline   Reply With Quote
Old 02-11-2012, 03:04 PM   #12
stage20
85-91 corvette head and also used on the zz3-zz4 crate engines. you can make about 450p out of them. wont set the world on fire. 300 complete and ready to bolt on is not a bad price. a vortec head could probably make 10-15 more hp, but you would have to tack on the extra weight as well.
TJ
88 iroc-z/28 408 LSx
all the good stuff.
05 2500HD 6.0L
one hauls, one hauls @$$!
CHP May 2011 feature
http://www.chevyhiperformance.com/fe...aro/index.html
stage20 is offline   Reply With Quote
Old 02-11-2012, 03:30 PM   #13
Collinsautomotive
there are several company cnc porting them, well used to port them, and they can be good performers. but its not worth the $$$ if you don't already have a set as a $400 purchase plus 800-1000 in porting to bring them up to spec isn't worth it, the small chambers are nice however.
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
Old 02-11-2012, 03:42 PM   #14
JHaleyH374
Bracket racer
JHaleyH374's Avatar
Yup L98 heads.....they're decent for what they are. My buddy has a set that he's going to put on a 350 to put in his truck. For a heavy truck they should make decent power/torque.
Haley Racing Products
270-784-1534
www.haleyracingproducts.com
PM me about the RJS safety equipment special I'm offering from April 1st to June 30th!
"I have no idols. I admire work, dedication, and competence." - Ayrton Senna
JHaleyH374 is offline   Reply With Quote
Old 02-11-2012, 05:20 PM   #15
awake1630
Member
Pullin gears
awake1630's Avatar
welp with all this definitely not gonna buy the heads. They looked interesting cause of the 58cc chambers
1969 Camaro
10.83 @ 123.33
1.53 - 60 foot
SBC
Ford Aod
4.33 gears
4 wheel Disc brakes
E85
Resources saved on this page: MySQL 1.98%
