Spark Plugs for Alcohol - Yellow Bullet Forums
Old 01-23-2012, 12:19 AM   #1
9secondart
Burnout box
Default Spark Plugs for Alcohol
I just switched to Alcohol and I am looking for help on a spark plug and gap recomondation. I currently run a Champion C61YC. I have 13.5:1 compression and run a Dominator. Any help would be appriciated.
Ray
9.18 Small Block Chrysler...ALL Motor
9secondart is offline   Reply With Quote
Old 01-23-2012, 12:38 AM   #2
69chicken
69chicken's Avatar
Default Re: Spark Plugs for Alcohol
I like NGK-10s .030 gap. Go 2 steps colder then where your at possibly more if the temp goes up. Colder is better.
69chicken is offline   Reply With Quote
Old 01-23-2012, 12:41 AM   #3
ordinary builder
try at the full cold direction of the spectrum
you want to LEAVE as much heat IN the chamber as possible.
I do not have much faith in the selection from champion....
try autolite or ngk.
ordinary builder is offline   Reply With Quote
Old 01-23-2012, 04:28 AM   #4
clevo
Start with NGK-8 or -9
NGK-10 are very cold and they will foul up very easy.
clevo is offline   Reply With Quote
Old 01-23-2012, 08:04 AM   #5
Innovative225
Innovative225's Avatar
NGK R5671A-9 here, methanol SBC with 13.70:1 comp and a Ron's Toilet. They are cheap and seem to last OK, plus the heat range is spot on for my motor.
Innovative225 is offline   Reply With Quote
Old 01-23-2012, 10:03 AM   #6
bones427
bones427's Avatar
ngk-9 in mine .025 gap, bbc 15.5-1
bones427 is offline   Reply With Quote
Old 01-23-2012, 06:13 PM   #7
Quik598
Launchin
Dont forget that Chris U has a spark plug cross over in the sticky section...
Quik598 is offline   Reply With Quote
Old 01-23-2012, 06:48 PM   #8
Mike Oxlong
Spooled up
Mike Oxlong's Avatar
i have always used a ngk-8 thats what ken jones tells pretty much all of his customers to run, seems to work fine.
JR Meritt
95 gt drag radial, yates headed N/A 433sbf
2008 true radial champ at I57
thanks to marcus at www.mandrhouseofspeed.com
Mike Oxlong is offline   Reply With Quote
Old 01-23-2012, 09:08 PM   #9
SQ329L
SQ329L's Avatar
Garage
Same thing everybody else has said, NGK-8 on motor, and NGK-9 if your going to spray it with alky. I have ran -7s in an 18 degree 421 SBC with 15.5 compression on alky, ran great, and started very easily.
SQ329L is offline   Reply With Quote
Old 01-23-2012, 09:42 PM   #10
9secondart
Burnout box
Thanks a bunch, Sounds like I will be switching to NGK's. Will try both 8 and 9's with a .025 and .030 gap
Many thanks!
C'mon hot weather!
Ray
Old 01-23-2012, 10:28 PM   #11
Mike Oxlong
Spooled up
you can get the plugs from napa, they are pretty cheap also.
JR Meritt
Resources saved on this page: MySQL 2.22%
