Pro mod nitrous care, still banging ? - Page 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Pro Modified
Pro Modified Talk about Pro-Mod racing with censorship...
Old 01-24-2012, 09:14 PM   #16
BobWatson
BobWatson's Avatar
Default Re: Pro mod nitrous care, still banging ?
Quote:
Originally Posted by cold69bird View Post
I hear ya, i have always done it too with a cast manifold and one carb--when they pop it isnt that big of a deal usually, Pop a sheet metal intake with splits on top and you tear up several hundred dollars worth of shit and need a new pair of underwear!!!! we might go back to it but i'll leave that up to the owner of the car
BURST PANELS.......
IT PAYS TO LEAVE FIRST
BobWatson is offline   Reply With Quote
Old 01-25-2012, 08:29 AM   #17
buschmec
First round fodder...
buschmec's Avatar
its all in the setup guys and gals. if you run a clutch with big systems your gonna want to bang it. dump the clutch with a cough and your gonna need a scoop. MOST of the cars that launch the scoop have another issue that happens to pop up at that time. we have always banged and to this date have never had an issue, we bring the car to 2500 and bump each kit. don't know if i would try it from idle.
Working to make her faster....4.90@139
Thanks to Troy Balsters, Greg Buschmeyer , Rick Vineyard , John McDonough, Mike and Ty Chaney, Chris and Jolene Bryant, and many others.
buschmec is offline   Reply With Quote
Old 01-25-2012, 08:45 AM   #18
cold69bird
Member
Pullin gears
cold69bird's Avatar
Quote:
Originally Posted by BobWatson View Post
BURST PANELS.......
Blew both of them and the top off of the manifold!!!
My Ride:
Little ole small block on 275's
331 cu.in.
pt 98/88
C&S methanol blowthrough carb
Glide & PTC convertor
Gettin there slowly---5.40's @ 135mph in the 1/8th so far
cold69bird is offline   Reply With Quote
Old 01-26-2012, 11:24 AM   #19
Monte Smith
The nitrous guy
BURST PANELS.......
No way a couple 1" sized holes, are going to save the top of your manifold, if it coughs. Waste of time to even install them. You want to attempt to save your manifold in the event of a backfire, put the top on with plastic bolts.
Monte
Monte Smith
Motorsports Technical Representative
Nitrous Oxide Systems
www.montesmithperformance.com
gtxmonte@msn.com
ph. 256-783-3418
Monte Smith is offline   Reply With Quote
Old 01-26-2012, 11:43 AM   #20
Yvonne
Yvonne's Avatar
Quote:
Monte
That way the carbs can now become flying shrapnel as well? The burst panels are meant to help the release of pressure. Kind of like the holes a fireman chops in a burning roof with an ax. Its not meant to save the roof, its meant to control the continuing blasts. I've seen two dominators still bolted to the top of an intake that was split in half with both halves vertical east/west. The main point being the carbs were still bolted to the intake. With plastic screws you risk large pieces of flying debris at crew members and track personnel. Did we not see a picture of a well-known pro mod car and the carb was sitting on the ground next to the car at the starting line just this last year? Racers, please use the burst panels!
Yvonne is offline   Reply With Quote
Old 01-26-2012, 11:56 AM   #21
marc1166
Member
Pullin gears
marc1166's Avatar
Fultons spring loaded reliefs worked just fine for me in this situation. The previous old school pop-off discs (burst panels) ended up lifting the manifold top. The new spring loaded reliefs relieve that pressure without damage. I've actually saw a quick flame flash from inside the car when it happened on my car. Motor stumbled for a quick second, fired that system again (Cleanly this time) and I made the run.
Had this happen with another sheet metal manifold motor with an IS Solutions pop off as well. Motor stumbled and shut off. Re-fired...purged again, and made the run. No damage.
As Bushmec said above, that same stumble on the launch will create some interesting after effects.
marc1166 is offline   Reply With Quote
Old 01-26-2012, 01:01 PM   #22
BobWatson
BobWatson's Avatar
And that's the "TRUTH"
Old 01-26-2012, 01:02 PM   #23
K I RACING
K I RACING's Avatar
The burst panel plate or spring loaded will not save you from a real boomer.
There fine on a sneeze.
The plastic bolts are the only thing that seems to save it.
Then thether the top plate to the intake this keeps it somewhat in place so the fuel lines don't get ripped off that's were your seeing the fires.
K I RACING is offline   Reply With Quote
Old 01-26-2012, 04:24 PM   #24
Blownalky
Screwed and Loving It
Blownalky's Avatar
Sounds like you nitrous folks now need straps and a ballistic bag just like us blower guys. Shhh, don't let NHRA or SFI hear about it.
Blownalky is offline   Reply With Quote
Old 01-26-2012, 04:45 PM   #25
K I RACING
K I RACING's Avatar
[QUOTE=Blownalky;7947757]Sounds like you nitrous folks now need straps and a ballistic bag just like us blower guys. Shhh, don't let NHRA or SFI hear about it.[/
Like anything else it don't happen all the time.
Really easy to strap it so it cant get air born..
Old 01-26-2012, 04:52 PM   #26
van o 69
Member
Pullin gears
like this? http://www.youtube.com/watch?v=4qE2W-c0aKE
van o 69 is offline   Reply With Quote
Old 01-26-2012, 05:56 PM   #27
mrdragster1970
T/S 368E
mrdragster1970's Avatar
A whole page full of reasons why the purge works fine in my book, including when the clutch & Lenco were still in the car!!
I have a ton of used BBC-Dragrace-Trucks- 4 sale, personally listed items only.
For my babies, we will always remember.
In memory of Chris
Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Old 01-26-2012, 06:52 PM   #28
wd40
wd40's Avatar
Quote:
You could always use some of them NASCAR aproved carburetor tethers.
wd40 is offline   Reply With Quote
Resources saved on this page: MySQL 1.03%
