Wiring Bosch 5 pin relay diagram - Yellow Bullet Forums
Old 01-17-2012, 12:28 AM   #1
2madre
Burnout box
2madre's Avatar
Default Wiring Bosch 5 pin relay diagram
So many different ways for wiring this relay. 85,86,87,87a,30.wiring fuel pumps from a moroso switch panel with a built in 20 amp fuse.
One relay for each pump, then one for fan and another for nitrous.
2madre is offline   Reply With Quote
Old 01-17-2012, 01:04 AM   #2
rod cole
Spooled up
Default Re: Wiring Bosch 5 pin relay diagram
it is on the relay itself. From memory the controled wires are 30 and 87 and 87a depending if you want it pulled on or off. 30 going to the batt with the larger wires the other going to the pump fan whatever from 87 or 87a. The other two go to the switch and ground. Meening ground one take the other to the switch usually lighter gauge wire. The pic on relay the thing that looks like a stick with something around it represents the electromagnet in the relay. The other thing represents the 30 wire it toggles between two contacts representing 87 and 87a depending if you want it closed all the time and open when the magnet is applied or vice versa. Hope this helps.
rod cole is offline   Reply With Quote
Old 01-17-2012, 01:38 AM   #3
bmwmech
Spooled up
87-87a are outputs to pump, fan,or other things, but 87a could be hot when the relay is not on also most bosch relay has a diagram on it. 86 is power to the 87-87a posts . 85 is power to relay coil 30 is ground for relaycoil
bmwmech is offline   Reply With Quote
Old 01-17-2012, 02:05 AM   #4
spike218
Launchin
85 ground,30 battery pos.,86 toggle switch,& 87 to what ever your powering up, 87a not used
spike218 is offline   Reply With Quote
Old 01-17-2012, 03:36 AM   #5
bmwmech
Spooled up
You are correct on 85 and 30 I guess 5 years away from BMW's has wasted my brain.
Old 01-17-2012, 06:36 AM   #6
Blitzkrieg Motorsports
Blitzkrieg Motorsports's Avatar
Quick internet search but I would switch the source to pin 30.
Dennis Equitz
Caledonia, WI
262.835.1339
dennis.equitz@blitzkriegmotorsports.com
www.blitzkriegmotorsports.com
Precision Turbo, NLR, Big Stuff; Holley EFI, F.A.S.T., Strange Engineering, R.J. Race Cars/Quartermax Components, Deutsch Connectors, Pro-Glass Windows, SPD Exhaust, Racepak, Stroud, Prolite Batteries and many more!
WE ARE NOW A DEALER FOR PROLITE BATTERIES - CALL US FOR YOU BATTERY NEEDS!
--Custom Laser Cutting, Machining, and Design Services--
Blitzkrieg Motorsports is offline   Reply With Quote
Resources saved on this page: MySQL 2.30%
