Who rebuilds their own engines? (at home garage) - Yellow Bullet Forums
Old 01-02-2012, 12:06 PM   #1
jaidedeye
Default Who rebuilds their own engines? (at home garage)
going to freshen up my motor...it isnt blown or anything, im just going to strip the block, hone the cylinders, new bearings, new rings, new freeze plugs, new oil pump, gaskets etc....who else does this? any advice?
ive rebuilt motors before but just seeing how many of you guys do and if you have any tips or tricks
thanks
jaidedeye is offline   Reply With Quote
Old 01-02-2012, 12:17 PM   #2
AUSBY
Launchin
Default Re: Who rebuilds their own engines? (at home garage)
i do. once its stripped i soak it with mean green and pressure wash it. then use air to blow it dry and go through all the galleys and threads.
AUSBY is offline   Reply With Quote
Old 01-02-2012, 12:38 PM   #3
bones427
bones427's Avatar
I do. Always had problems after other guys build my stuff. Lots of cleaning and check everything!
bones427 is offline   Reply With Quote
Old 01-02-2012, 12:42 PM   #4
Badboss351
Badboss351's Avatar
Id take it to a performance shop, let them hone it. That is a very important step in building a good running engine. Clean, clean, and clean. Also keep a close eye on clearences!
XSR built S/S 446" nitrous SBF
Dealer for:
Ultimate Converter Concepts
Baseline Susp.
CV Products/Xceldyne
many more.......
Badboss351 is offline   Reply With Quote
Old 01-02-2012, 01:39 PM   #5
jaidedeye
thanks guys...once i get the heads pulled and pistons removed im going to get a really good look at the cylinders. if i can hone them without any high or low spots in the cylinders i will just run with it..if there are variances in the walls it will go to the machine shop. im going to pull all the galley plugs, freeze plugs etc and really clean the block out
Old 01-02-2012, 01:51 PM   #6
MichaelP
MichaelP's Avatar
Quote:
That's what I do when freshening up. LOL, last time I freshened up a SBC that had cracked the compression rings in 3 cylinders, I found those 3 cylinders with severe out-of-round conditions, but it was July 4th weekend and I wanted to get the car back together. Of course those 3 cylinders broke the rings again within about 60 passes. Presumably you have a decent dial bore gauge and micrometers? I figure mine have paid for themselves MANY times over by doing my own clearance checking and assembly.
1999 Chevy Silverado Pro Stock Diesel - under construction. LBZ Duramax, GT4202R over GT5541R, Sponsored by ISSPRO and Chris Alston's Chassisworks
1973 Vega Super-Gas car, 481" BBC
1974 Vega bracket car, 350" SBC
1973 Pontiac T/A 455
1992 GMC Typhoon
1973 Chevy Blazer with Pontiac 400
1995 F350 Crew Cab Dually - intake, exhaust, chip, injectors
2000 VW Jetta TDI - Kerma tuning, Der Chimera clutch
MichaelP is offline   Reply With Quote
Old 01-02-2012, 01:58 PM   #7
55sedan
55sedan's Avatar
Quote:
x2 !!!!!!!!!!
I let the machine shop do the hone and cam bearings. Do the rest myself.
As said before, lots of cleaning. A steam cleaner is my choice for final cleaning the block. Get it hot as you can, then blow dry with air.
What moisture you cant get with an air blower, will evaporate from the heat.
I also use alot of soap with the steam cleaner, this seems to cut down on the surface rust till you can get it coated & painted.
Also, the best thing Ive found to put on metal surfaces that you dont want painted and also dont want to rust is "3in1" machine oil.
JMO
BBC P/Glide 12 Bolt on Leafs
55sedan is offline   Reply With Quote
Old 01-02-2012, 02:18 PM   #8
jaidedeye
Quote:
yep, sure do...they are worth their weight in gold
Old 01-02-2012, 05:28 PM   #9
rdub79
Platinum Member
rdub79's Avatar
Another thing to remember is to make sure your assembly tools are clean, inside of sockets especially.
I have a separate set that I only use for engine assembly.
88' Junk-N-Da-Trunk
rdub79 is offline   Reply With Quote
Old 01-02-2012, 06:04 PM   #10
BADBLACKZ
Stuck in Lidsville
BADBLACKZ's Avatar
I could never trust anyone else to do mine...........
1970 RS Z28, 427 s.b. 4 speed street car. If it wasn't for you Ford guys.........I wouldn't be so fucking cool !
BADBLACKZ is offline   Reply With Quote
Old 01-02-2012, 06:06 PM   #11
Coloradoracer
Coloradoracer's Avatar
I don't do the major machine work or valve job, but everything else I do myself. Cam bearings, checking clearances, file fitting rings, etc.....For me it was cheaper to buy the tools to do things right than to continue to pay a machine shop. Nice thing is, if I have to tear down for repair, and no machine work is needed, I can have it back together as long as I have parts. Besides, it's my "me" time and very enjoyable for me. I love doing it.
Mark Goulette
Owner and driver, Livin' the Dream Racing Dragster
Speed kills but it's better than going slow!
www.livinthedreamracing.com
Authorized Amsoil Dealer
Coloradoracer is offline   Reply With Quote
Old 01-02-2012, 06:43 PM   #12
jaidedeye
tore the motor down to the bare block.....cylinders look great...still slight crosshatching and cylinders measured out round...just gonna lightly hone them...cam bearings look brand new still but the crank and rod bearings show some wear..a few into the copper..crank looks really good. just a light polish on it and i will be good...all journals spec'ed out good and my clearances are still within spec for the .001 oversize bearings im picking up..good news
Old 01-02-2012, 07:06 PM   #13
JShelton
I would check the journals for out of roundness, If theres any at all I would have the crank ground to the next under size. I'm not a big fan of running .001 undersize brgns on a polished standard crank. JMO! You have to buy brgns anyway and a crank grind aint that expensive.
JShelton is offline   Reply With Quote
Old 01-02-2012, 07:06 PM   #14
rdub79
Platinum Member
rdub79's Avatar
What motor? Any pics?
88' Junk-N-Da-Trunk
Old 01-02-2012, 07:18 PM   #15
jaidedeye
Quote:
stock block 302..
here is whats left..lol
Resources saved on this page: MySQL 2.06%
