2010 ford fusion P144A code - Yellow Bullet Forums
Old 12-29-2011, 08:16 AM   #1
shan
Jus Sayin Attorney Gen
shan's Avatar
Default 2010 ford fusion P144A code
my sister bought a 2010 fusion 9months ago. It was a demo, has 35k miles on it. Check eng light came on, gets a P144A code, emission evap purge line restricted. Dealer wants $400 to fix. Is this not covered under warranty? If not is it an easy fix or not?
shan is offline   Reply With Quote
Old 12-29-2011, 08:23 AM   #2
fstrthnu373
Member
Pullin gears
fstrthnu373's Avatar
Default Re: 2010 ford fusion P144A code
evap canister purge valve located on the intake. replace it and clear code, there is a tsb for this out and I just did one the other day.
fstrthnu373 is offline   Reply With Quote
Old 12-29-2011, 08:25 AM   #3
Luxy72
Launchin
Luxy72's Avatar
Take it to a different dealer...bumper to bumper warranty...3/36k..she's covered.
Luxy72 is offline   Reply With Quote
Old 12-29-2011, 08:44 AM   #4
The Muskrat
The Muskrat's Avatar
X2^^^
The Muskrat is offline   Reply With Quote
Old 12-29-2011, 08:53 AM   #5
shan
shan's Avatar
thanks guys, did a little more research and found this = Emissions equipment is required by Federal law to be covered for five years or 50,000 miles.
Read more: http://www.motortrend.com/cars/2010/...#ixzz1hvZCLb1v
just another dealer trying to make a buck off the unknowing general public
Old 12-29-2011, 09:08 AM   #6
projoe87
Its under 5/50 , tell them to go fuck off. Its covered.
projoe87 is offline   Reply With Quote
Old 12-29-2011, 09:18 AM   #7
04mach18u
04mach18u's Avatar
3/36 OR 5/50 as mentioned, some stuff on the car is actually 8/80. Tell them to piss up a rope. We never do our customers like that. We check EVERY vehichle with less than 100k mileage for warranty coverage before we take it into the customer.
You also need to call FORD @ 1-800-392-FORD(3673)
04mach18u is offline   Reply With Quote
Old 12-29-2011, 09:34 AM   #8
shan
shan's Avatar
just called my sister to let her know some of the stuff i found out and to confirm mileage, it has 37k on it. so the bumper to bumper is a no go. we'll have to see about the 5yr/50k emission is for real or not. Found a few other sites that say only 2yr/24k on emissions
Old 12-29-2011, 09:40 AM   #9
04mach18u
04mach18u's Avatar
those sites are incorrect, pm me the vin, exact mileage, and state that its in.
Old 12-29-2011, 09:56 AM   #10
The Muskrat
The federal 8/80 emissions warranty covers the cat, pcm and datalink connector only if I remember correctly, no solinoids, valves, etc
Old 12-29-2011, 09:58 AM   #11
04mach18u
04mach18u's Avatar
Printable View (51 KB) TSB
11-11-28
  • MIL LAMP ON WITH DTCS P144A, P2196, P2198, P1450, P0455, P0456, AND/OR P0457 BUILT ON OR BEFORE 3/4/2011
Publication Date: November 18, 2011
FORD:
2010-2011 Fusion
2009-2011 EscapeMERCURY:
2010-2011 Milan
2009-2011 Mariner
This article supersedes TSB 11-3-22 to update the Title, Issue Statement, and Service Procedure. ISSUE:
Some 2009-2011 Escape, Mariner, 2010-2011 Fusion and Milan vehicles equipped with a 2.5L DOHC or 3.0L engine built on or before 3/4/2011 may exhibit a leaking/stuck under hood evaporative emission purge valve. This fault will turn on the malfunction indicator lamp (MIL) and set diagnostic trouble codes (DTC) P144A, P2196, P2198, P1450, P0455, P0456, and/or P0457.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
  1. Are any of the following DTCs P144A, P2196, P2198, P1450, P0455, P0456, and/or P0457 present?
    1. No - Do not continue with this article.
    2. Yes - Proceed to Step 2.
  2. Remove the evaporative emission canister. Refer to Workshop Manual (WSM), Section 303-13. Inspect canister for liquid fuel by turning the canister over and watching for signs of liquid fuel exiting the canister. Are there any signs of liquid fuel present?
    1. No - Proceed to Step 3.
    2. Yes - Replace the evaporative emission canister. Refer to WSM, Section 303-13. Proceed to Step 3.
  3. Are P0455, P0456, and/or P0457 the only DTCs present?
    1. No - Refer to the WSM, Section 303-13 to locate the leak. Repair as needed.
    2. Yes - Proceed to Step 4.
  4. Perform IDS leak test, Refer to the Powertrain Control/Emission Diagnosis (PC/ED) pin point text HX. Did the leak test pass?
    1. No - Refer to WSM, Section 303-13. to locate the leak. Repair as needed.
    2. Yes - Replace the under hood evaporative emission canister purge valve. Refer to WSM, Section 303-13 and proceed to Step 5.
  5. Clear stored DTCs.
PART NUMBERPART NAME9U5Z-9C915-HCanister Purge Valve9R3Z-9C985-BCanister (Escape/Mariner)9E5Z-9D653-CCanister (Fusion/Milan)
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATIONDESCRIPTIONTIME111128A2010-2011 Fusion And Milan: Check DTCs, Remove And Inspect The Evaporative Emission Canister, Replace If Necessary Includes Time To Perform The Evaporative Emission System Leak Test0.9 Hr.111128A2009-2011 Escape And Mariner: Check DTCs, Remove And Inspect The Evaporative Emission Canister, Replace If Necessary, Includes Time To Perform The Evaporative Emission System Leak Test1.0 Hr.111128B2010-2011 Fusion And Milan: Check DTCs, Remove And Inspect The Evaporative Emission Canister, Replace If Necessary, And Replace The Evaporative Emission Canister Purge Valve Includes Time To Perform The Evaporative Emission System Leak Test1.0 Hr.111128B2009-2011 Escape And Mariner: Check DTCs, Remove And Inspect The Evaporative Emission Canister, Replace If Necessary, And Replace The Evaporative Emission Canister Purge Valve Includes Time To Perform The Evaporative Emission System Leak Test1.2 Hrs.MT111128For Any Additional Diagnosis Or Repair Related to Pin Point Test HX Use SLTS Operations If Available Or Actual Time.Actual Time
DEALER CODING
BASIC PART NO.CONDITION CODE9C91542
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright 2011 Ford Motor Company
Old 12-29-2011, 09:58 AM   #12
shan
shan's Avatar
Quote:
working on getting you the info.
Old 12-29-2011, 09:59 AM   #13
04mach18u
04mach18u's Avatar
Im not 100 percent sure, I just sell the parts but the tsb I copied makes it look like its covered under base and emissions?
Old 12-29-2011, 10:12 AM   #14
shan
shan's Avatar
pm sent
Old 12-29-2011, 10:15 AM   #15
shan
shan's Avatar
forgot = is in VA
