looking for Foxbody hatch mini tub progress pics - Yellow Bullet Forums
Old 12-16-2011, 09:54 PM   #1
the mex
the mex's Avatar
Default looking for Foxbody hatch mini tub progress pics
Looking for pics of foxbody hatch mini tub pics as tou were doing the work....what all was cut,did you replace outer wheel tub or use factory,etc...looking for the best way to do it.
the mex is online now   Reply With Quote
Old 12-16-2011, 10:00 PM   #2
dragstang
dragstang's Avatar
Default Re: looking for Foxbody hatch mini tub progress pics
http://www.wolferacecraft.com/instal...usminitub.aspx
Coy Miller Racing
Engine Development
Racing Engines & Components
Cylinder Head Development
5 Axis CNC Porting
Computerized Dyno Facility
Phone (540) 433-0545
dragstang is offline   Reply With Quote
Old 12-16-2011, 10:01 PM   #3
the mex
the mex's Avatar
Quote:
Originally Posted by dragstang View Post
Damn,that was easy.lol.thanks
Old 12-16-2011, 10:02 PM   #4
Dragpny
Member
Pullin gears
Dragpny's Avatar
Muscle Mustang Fast Ford had a great write up with DMC on an install. Check their site.
92 Mustang
25.5
LS Powered on the Spray
Powerglide
Dragpny is offline   Reply With Quote
Old 12-16-2011, 10:16 PM   #5
dwhetstine
dwhetstine's Avatar
Location: Southern Maryland, The home of 10oz Bud Light's.
Here is some pics of mine.
http://www.yellowbullet.com/forum/sh...ght=dwhetstine
''Life's tough ... But it's even tougher if you're stupid.''
- John Wayne
SBF/F1R/X275
4.59@158, 7.13@194.
A to B wins 80% of the time.
2009 OSBA 275 Drag Radial Champion
275 RTCTTFMF
Thanks to TIM ESSICK MOTORSPORTS
dwhetstine is offline   Reply With Quote
Old 12-17-2011, 10:54 AM   #6
the mex
the mex's Avatar
Im wanting to run a 315 radial and a 29w and still have my car sitting low.do I need to replace the outer wheel well or is the stock outer fine for that?
Old 12-17-2011, 11:13 AM   #7
ToneLoc
Member
Pullin gears
ToneLoc's Avatar
http://www.Teamzmotorsports.net/category_s/163.htm
ToneLoc is offline   Reply With Quote
Old 12-17-2011, 11:43 AM   #8
lukesbuell
Spooled up
lukesbuell's Avatar
I did team Z that made it petty easy did have to cut the lip off the outer wheel well with my 325's
lukesbuell is offline   Reply With Quote
Old 12-17-2011, 11:01 PM   #9
jmayabb
Member
Pullin gears
jmayabb's Avatar
http://www.joemayabbracing.com/pictures.html
4.98 @ 146
Stock Suspension
All Motor
Joe's Race Parts
From Mild to Wild...
And Everything In Between
http://www.joesraceparts.com
____________________________________
Special Thanks To:
Joe's Race Parts, Mike Adams Race Cars, Santhuff Shocks & Struts, Reactor Products, Bradco Engineering
jmayabb is offline   Reply With Quote
Old 12-17-2011, 11:44 PM   #10
jevans
jevans's Avatar
Quote:
If your going to be running a 315 or 29.5 tire, I would replace the stock outer tub also. It will limit how low you can sit the car down. A full tub will let you sit the car down and you won't have to worry about any issues with rubbing.
J E T Race Cars
" The difference is in the detail "
jevans is offline   Reply With Quote
Old 12-18-2011, 12:06 AM   #11
stroked90hatch
Spooled up
stroked90hatch's Avatar
Team z mini tubs....
stroked90hatch is offline   Reply With Quote
Old 12-18-2011, 12:18 AM   #12
Colt
Ask me about my Weiner!..
Colt's Avatar
I'm going to try and get mine done this winter.. I've been running a IRS, just to see how far you can push one with good parts.. Never been able to break it, but I cant run shit for a tire, which makes it a death trap at the 1/8th, nobody will prep to or past the 1/8. Once I get in a good gear and that turbo starts really boostin the car wont stay straight... So... It's time for that shit to go.. Even more so because I'm going to a turbo 408, it will be a death trap with that kind of power.
Here's what I'm curious about, the fuel cell? I thought you had to have a fire wall in order to run the fuel cell inside the car? My car is a hatch.. I haven't figured out what I'm going to do there yet.. I've seen a few hatchbacks running fuel cells inside the car, but with no fire wall...
Colt is offline   Reply With Quote
Old 12-18-2011, 12:33 AM   #13
mycomputerhatesme
THREAD KILLER
mycomputerhatesme's Avatar
I did mine at a buddy's house a while back. If you have any fab skill you can save some coin, its simple to do
#1 cut out inner wheel well
#2 notch rear frame rail
#3 trace pattern of the outside wheel well, move it in against the frame rail and mark the bottom to create the inner panel of the tub.
#4 measure from the outer well to the inner rail and be sure to give yourself some overlap for spot welding or rivits and final trimming.
#5 take cardboard patterns to a sheet metal shop and have them duplicated in the material of your choice and tell hem you want pittsburgh seam. tape them together in the shape they will be in the car so they can see what you want.
#6 final trim and weld/rivet
#7 relocate upper shock mounts
I have about twenty five dollars in material when I do them.
those pics are with a 275 radial, a 315 fits with plenty of room
mycomputerhatesme is offline   Reply With Quote
Old 12-18-2011, 12:33 AM   #14
9secondlx
9secondlx's Avatar
Mini tubbed with stock tank and coilovers..
9secondlx is offline   Reply With Quote
Old 12-18-2011, 12:40 AM   #15
mycomputerhatesme
THREAD KILLER
Colt I just build a sheetmetal bulkhead that meets the hatch behind the glass. It's either that, encase the cell or sump the stocker. I like to narrow and sump the stock tank, it leaves a lot more room for intercooler tanks etc.
