vic jr 4150 TB, on a STOCK ls1. check out the gians - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 12-10-2011, 08:31 PM   #1
studderin
studderin's Avatar
Default vic jr 4150 TB, on a STOCK ls1. check out the gians
Stock LS1 (1999) swaped in a 1955 chevy, th400.
LS1 intake, unported TB, (running a 90 bend with a big 9inch cone) LS1 cam, springs, manifolds. Got it running tuned it, made sure it was a good core. Then customer wanted to make it look better with visual things, and wanted this intake.
Only change was a put of the box vic Jr, the rails, and a FAST (accufab) 4150 TB (no spacer) and a 14x3 air cleaner.
Was surprised to see this power curve, 100% stock internal.
New Era Performance
studderin is offline   Reply With Quote
Old 12-10-2011, 08:56 PM   #2
gray86hatch
gray86hatch's Avatar
Default Re: vic jr 4150 TB, on a STOCK ls1. check out the gians
Cool that is a nice bolt on power.
Tim
86 mustang 3000lb
454 FTI LS3 Mast intake FTI hyd roller Holley EFI 275 MT e85
9.24 143.58 1.33 3.73 5.84 116.21
HR Drag Week 2013 ss-BB-NA Winner
LSX here we come
with help from
My wife and daughter's 2
www.flowtechinduction.com
www.boozebrothersracing.com
gray86hatch is offline   Reply With Quote
Old 12-10-2011, 09:59 PM   #3
BrettW@racetech perf
Launchin
Very good gains! Thats the exact intake/tb I just put on my car.
DFWSS.ORG
"Home to some of the worlds fastest street cars!"
Shreveport Street King
79 Malibu BBC/Glide
BrettW@racetech perf is offline   Reply With Quote
Old 12-10-2011, 10:06 PM   #4
LS1DragandPass
Member
Pullin gears
LS1DragandPass's Avatar
nice gain
LS1DragandPass is offline   Reply With Quote
Old 12-11-2011, 05:52 AM   #5
Widow_Maker
Chupa Cabra
Widow_Maker's Avatar
Really wanting to put one on my car. No cowl work to worry about since it's already been done, and I know my car would love the gains from 5000rpm and up, as it doesn't ever go below that on launch, street, who cares about street power...
RTCTTFMF!!!
5.14@137.49 (1.21 60') True Street 275 (3290# RW) SOLD
Smallwood Race Developement
Mcleansville, NC
864-723-2892
Widow_Maker is offline   Reply With Quote
Old 12-11-2011, 10:57 AM   #6
a98ws6
Launchin
a98ws6's Avatar
Any opinions on using a elbow and say a 92mm tb instead of the accufab? Im not talking the low profile elbows that are made to avoid the cowl cutting with the sharp bends. Im talking about the taller elbows like the Wilson or 6061 elbow that require notching the cowl. Im wanting to go vic jr. and a 6061 tall elbow and a NW 92mm in the front.
a98ws6 is offline   Reply With Quote
Old 12-11-2011, 01:53 PM   #7
ShorTuning
LSXTTFMF
Pullin gears
Quote:
You would def need a cam change if you did! Back when I tuned your car when Josh had it there was no intake restriction all the way up to 7K. MAP readings showed this with a flatline all the way up. Your car would be an awesome candidate for the swap though to see real world results because it's a really good working car! But then again how much more RPM is the stock bottom end going to take? I know some that hold up well with extreme high RPM and I see some that don't.
James Short
ShorTuning is offline   Reply With Quote
Old 12-11-2011, 11:41 PM   #8
studderin
studderin's Avatar
Quote:
Try it and see. I have a super vic, and this same TB rails, a carb hat.. 4inch alum tubing..most of the parts already. But have not goteb around to getting it on the car. Also have a tall cast wilson elbow, my 92mm TB bolts to.
This was on a STOCK cam, so its deffinatly not ideal, but it gained a ton of top end over a OEM style
New Era Performance
Old 12-12-2011, 06:19 AM   #9
Ed Curtis
Ed Curtis's Avatar
Tell Mike we need to put a nice camshaft in that project.
Ed Curtis is offline   Reply With Quote
Old 12-12-2011, 12:28 PM   #10
Pro Stock John
Pro Stock John's Avatar
Now swap a FAST 90 or 102 and tells us what happens, I'd be curious. I think that '99 motor also would have picked up measurably with just an LS6 intake swap too.
LSX RECORD LIST
RaceStar, Billet Specialties Dealer
Pro Stock John is offline   Reply With Quote
Old 12-12-2011, 06:39 PM   #11
studderin
studderin's Avatar
some SI guy needs to do this, gain the power band of a cam. I wonder how much more it will turn till the stock springs float?
New Era Performance
Old 12-12-2011, 08:05 PM   #12
LS1NOVA
LS1NOVA's Avatar
Any pics of the engine now? Im doing a 55 LS with this intake just for the looks and stock style air cleaner.
www.One-guys-garage.com
LS1NOVA is offline   Reply With Quote
Old 12-12-2011, 08:17 PM   #13
zmg00camaross
zmg00camaross's Avatar
Thats baddass, And unexpected gains. I would like to see a fast on it for comparison. Studderin you going to sell your fast if you go with a vic jr?
zmg00camaross is offline   Reply With Quote
Old 12-13-2011, 02:37 PM   #14
a98ws6
Launchin
a98ws6's Avatar
Im planning on trying it. Just wish someone else tried it before. Lol
I have a FAST 90 now. Still need a tb for it. Im considering selling it. I would get a vic jr and either the elbow w/92mm tb or a vic jr, accufab, carb hat. The elbow setup is cheaper, but if niether setup makes more power or worse, less power then the FAST intake, ill just keep it. I dont have a cam yet, so if I do go vic jr, I will get a custom cam to go with it. This isnt a street car so im not worried about low end.
Old 12-13-2011, 02:53 PM   #15
Collinsautomotive
wow, so a good single plane intake beats out the composite, over the useful part of the rpm curve, surprised face on.
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
