Hertz and its affect on noids - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Nitrous - Induction Solutions
Old 12-09-2011, 08:39 AM   #1
trink408
trink408's Avatar
Question Hertz and its affect on noids
I'm wondering if someone can explain what changing the Hertz on your nitrous controller does to the solenoid, especially in relation to pulsing the noid?
I've been told to try different Hertz settings on my controller when progressing the noid at low percentages, and that different noids, like a trashcan, require different settings than a standard solenoid. I would like to have a better understanding of the impact of changing this Hertz value.
Kevin
BlackDog Racing...
www.kevintrinkner.com/racing
trink408 is offline   Reply With Quote
Old 12-09-2011, 09:00 AM   #2
ernie's 5oh
ernie's 5oh's Avatar
Garage
Default Re: Hertz and its affect on noids
Well hertz is a measurement of cycles per second, if you didn't already know that. Now from my experience the smaller the plunger the higher the hertz can be and the smoother the delivery of nitrous or fuel will be, now with the trash can noid the plunger is huge and can't cycle as fast so the plunger doesn't even get a chance to open till higher percentage on the progressive. Best thing to do is to bench test each noid using the same psi and voltage to see what works for you. Hope this helps.
450 sbf for 2014 holley efi
IS 2 stage fogger
best 60' 1.12
Best 1/8 4.84@145.85
Best 1/4 7.55@181.76
Thanks to:
PSP
Sam Vincent
Monte Smith
Steve Johnsons
ernie's 5oh is offline   Reply With Quote
Old 12-09-2011, 09:12 AM   #3
Induction-Solutions
Moderator
Induction-Solutions's Avatar
As mentioned above, the plunger size is a part of it. But as mentioned a trash can solenoid works best at slower hertz. One of the other main reasons is the coil size. When hertz is to fast, the coil cannot saturate with enough power to operate and move plunger. When you slow it down, the on and off periods become longer in time, hence better control and reaction.. SJ
Steve Johnson
www.InductionSolutions.com
www.woodys-plumbing.com
http://www.facebook.com/#!/pages/Ind...06171102739096
815-341-8853 Cell
352-593-5900 Parts/Shop
NOSMAN1@aol.com
Induction-Solutions is offline   Reply With Quote
Old 12-09-2011, 06:18 PM   #4
93slowhite
Spooled up
93slowhite's Avatar
So steve since you have to run a lower hertz with a larger plunger thus less opening/closing cycles per sec. do you then have less adjustment with a trash can noid on a controller and if so is it a noticible one ?
93slowhite is offline   Reply With Quote
Old 12-09-2011, 06:28 PM   #5
ernie's 5oh
Garage
Well the bigger the noid the harder it is to tune it to progressive it softer.
It's harder to make a 400 hit leave softer with a trash can noid then it is with a smaller noid if your using a progressive box.
IS 2 stage fogger
best 60' 1.12
Thanks to:
PSP
Sam Vincent
Monte Smith
Steve Johnsons
Old 12-09-2011, 10:52 PM   #6
HotStreet3134
HotStreet3134's Avatar
Quote:
Originally Posted by lepus View Post
so trevor..what works best with the pulsoids..
Ryan
8.2 Deck Mafia
https://www.facebook.com/groups/990915504268296/
Thanks to:
Toby's High Performance Racing Engines
Fast Lane Nitrous Racing Systems
Steffey Racing Fabrication
LAS Performance
Nitrous Pro Flow
HotStreet3134 is offline   Reply With Quote
Old 12-09-2011, 11:23 PM   #7
Widow_Maker
Chupa Cabra
Widow_Maker's Avatar
I see another cat fight coming...
RTCTTFMF!!!
5.14@137.49 (1.21 60') True Street 275 (3290# RW) SOLD
Smallwood Race Developement
Mcleansville, NC
864-723-2892
Widow_Maker is offline   Reply With Quote
Old 12-10-2011, 08:43 AM   #8
oldman1946
really getting old with these two spaming the board like they have socal1320.
oldman1946 is offline   Reply With Quote
Old 12-10-2011, 09:24 AM   #9
Doug F
If you want best peformance, run a 16v system. It mostly has to do with the energy the coil has, vs the force needed cycle the plunger. The more energy the better. Some small solenoids don't have the coil strength to get pulsed properly. The lower the frequency, the "better" they mechanically operate, but ideally a higher frequency makes the system better theoretically.
Doug F is offline   Reply With Quote
Old 12-10-2011, 09:52 AM   #10
HotStreet3134
Might want to check the thread again. You haven't provided any "cutting edge knowledge".
It seems everytime you enter this forum it's to throw a SALES pitch!
Ryan
8.2 Deck Mafia
Thanks to:
LAS Performance
Nitrous Pro Flow
Old 12-10-2011, 09:54 AM   #11
Trevor Langfield
Launchin
Keep your head in the sand then, your loss not mine!!!
Trevor Langfield is offline   Reply With Quote
Old 12-10-2011, 10:27 AM   #12
Induction-Solutions
Moderator
Quote:
No you still have the same adjustability. Your range of percentages and time is still there to work with.. It will actually just be more responsive to changes from what I see.. SJ
Steve Johnson
815-341-8853 Cell
NOSMAN1@aol.com
Old 12-10-2011, 10:29 AM   #13
Induction-Solutions
Moderator
I do not agree with this statement. You'll be really surprised I think if you just slow down hertz and try it.. SJ
Steve Johnson
815-341-8853 Cell
NOSMAN1@aol.com
Old 12-10-2011, 10:35 AM   #14
93slowhite
Spooled up
93slowhite's Avatar
Really wish there could just be answers to the questions and not the pissing contest..... i know i need all the helpful non solicited tech info i can get , im not a pro team im just a guy trying not to blow his stuff up .... and would really appreciate any knowlege you expierienced racers are willing to share and ofcourse former racers now moderators
Old 12-10-2011, 10:36 AM   #15
Trevor Langfield
Launchin
Steve are you responsible for removing my posts on this thread or have you condoned it or are you not aware of it.
In your instructions, it states that posts would be deleted only if a persons 'main' aim was to promote their products and yet my main aim is to educate and pass on my extensive knowledge on this subject. I made NO mention of my own products, I didn't link to any of my products and I don't have a HUGE BANNER with contact details in each of my posts, as say Monte does, so can you please explain why my posts on this thread have been deleted?
