pump gas 496 - Page 8 - Yellow Bullet Forums
Old 12-09-2011, 03:10 PM   #106
Bolt
Bolt's Avatar
Default Re: pump gas 496
Quote:
Originally Posted by scott foxwell View Post
496 has a really short rod and a heavy piston, along with a small bore. I don't see it as a "high rpm" combination- not to say some aren't doing it or that you "can't" do it. I just think the returns are diminishing, but to answer your question, 8500rpm changes everything and yes, the bigger head would be more effecient. I wouldn't change the port for 150-300 shot of NOS, or for E85. Neither of those will "help" the bigger port.
I went and looked at the weight of my piston it is 650 grhams. I would not consider that heavy. If it was a 540 or 565 it would be considerably more. They have the same rod ratio and stroke as a 496 and they run up @ 8,500 R.P.M. and more all the time. That is a 1.59:1 rod ratio I think not so bad.
Bolt is offline   Reply With Quote
Old 12-09-2011, 04:51 PM   #107
scott foxwell
scott foxwell's Avatar
Quote:
Didn't say you couldn't, I just said the returns are diminshing. You're not taking into account the bore. How much more power do you think you'll make at 8500 than you will at 7200? The heads (mainly the intake valve) you'll need to turn that rpm will be completely compromised by the 4.31 bore unless they're a custom head designed for that application.
FYI a Mahle 38cc dome piston for a 540 weighs 590g, and the 565 piston weighs 624g.
Induction Development Specialties
Retail/wholesale parts sales
Custom cams
423 391 7774
New Canfield BB Chevy heads now available!
Acts 2:38, the perfect answer to the perfect question.
scott foxwell is offline   Reply With Quote
Old 12-09-2011, 06:16 PM   #108
Bolt
Bolt's Avatar
I see your point Scott. I probably shouldnt have used my pistons as an example as they are heavier than most 496 pistons wich wiegh in around 550 grams. Mine are heavier because of the domes.
My point is though I dont think its like the old days when you had a TRW slug @750 or 800 grams.
Could you show the math for a 8,500 RPM 496 for comparison sakes like you did a 7,200 RPM 496? I think it would be helpful to the thread!
Old 12-10-2011, 12:09 PM   #109
Scott McMullen
Let the Clutch Out
Scott McMullen's Avatar
So whats your guys thoughts of putting something like the Dart Oval 275cc Head on a 496?
Dart Pro 1 275cc Oval port
Lift Int Exh
.200 154 137
.300 225 175
.400 284 210
.500 318 233
.600 341 249
.700 352 258
Scott McMullen is offline   Reply With Quote
Old 12-10-2011, 12:31 PM   #110
lun40119
I like IceCream
lun40119's Avatar
I know where you got that pic.........Scott.
Jake
Team Clueless
Optimize the Compromise...
Quote:
Originally Posted by Chris Uratchko View Post
Hell no, big blocks are for dump trucks!!!
lun40119 is offline   Reply With Quote
Old 12-10-2011, 12:40 PM   #111
Scott McMullen
Let the Clutch Out
Quote:
It was the only good one I could Find LOL
Old 12-10-2011, 01:06 PM   #112
lun40119
I like IceCream
lun40119's Avatar
I know that guy that owns that shop...............Ive used his dyno a bunch of times. Pretty cool fella!!!
Jake
Team Clueless
Old 12-10-2011, 02:55 PM   #113
Ron Miller
Ron Miller's Avatar
Lift Int Exh
.200 154 137
.300 225 175
.400 284 210
.500 318 233
.600 341 249
.700 352 258
Close to 3,000.00 dollars for a pair. You can do wonders with a pair of 049/781 for less money and not worry about header fit.
Ron Miller
Brownstown,Michigan
Ron Miller is offline   Reply With Quote
Old 12-10-2011, 04:43 PM   #114
TEEBONE
Spooled up
TEEBONE's Avatar
Quote:
x2
TEEBONE is offline   Reply With Quote
Old 12-10-2011, 06:06 PM   #115
Bolt
Bolt's Avatar
Anyone want some 049/781 heads I have a set I no longer need.
Old 12-10-2011, 09:10 PM   #116
Monte442
Monte442's Avatar
What shape are they in ? I have been looking for a set.
Monte442 is offline   Reply With Quote
Old 12-10-2011, 10:05 PM   #117
Darracq
Spooled up
I think i have seen them before also, didnt think there were that much though. I would get a set of brodix race rites.
Darracq is offline   Reply With Quote
Old 12-11-2011, 01:38 AM   #118
Bolt
Bolt's Avatar
Quote:
Pm sent
Old 12-11-2011, 02:33 AM   #119
cboggs
cboggs's Avatar
Bolt, .. the 489 that I built for my now sold car, .. the RFD 24 jr heads (2.25" valve, 3.5 sq in ) , 282 .800" cam, JE pistons, . . 875 hp , .. is that good for these combos?
Race Flow Development
http://www.raceflowdevelopment.com
757-222-9717
WD- Brodix-Dart-Edelbrock
cboggs is offline   Reply With Quote
Old 12-11-2011, 03:12 AM   #120
blue66
Spooled up
blue66's Avatar
Quote:
He will need to run on pump gas and last approx 1000 miles of street drivng. WHat are the "jr" heads, did I miss them on your site?
66 Chevelle SS
N/A, 496ci, Pump gas, no dominator, no spool, no electric fuel pump, no electric water pump, no big tires, full interior.
1.37
6.21 @ 109.7
9.82 @ 134.9
Gettin it done on 9"
http://youtu.be/Au6Lq7rH9Ak
"Keep your hopes up and your pedal down"....Rowdy
blue66 is offline   Reply With Quote
Resources saved on this page: MySQL 1.04%
