griner brake which one - Page 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 11-29-2011, 09:13 PM   #16
JShelton
Default Re: griner brake which one
Quote:
Originally Posted by grinertech View Post
Hey ! This is Griner
That Brake is old, old, old, But there is nothing wrong with it. It will still work better than any thing bought elsewhere.
That is the cast aluminum version (pre 1992), don't confuse it with the billet version. It will back up without poking the trans brake button, and it is much in demand by certain people that don't like the reverse safety feature.
One important upgrade, It appears that it has the black rubber balls. They need to be replaced with the white nylon type balls. This is most important !!!!
PM me a address and I will send them to you.
Steve Griner
You da man! Hows that for imfo and service!
JShelton is offline   Reply With Quote
Old 11-30-2011, 08:00 AM   #17
04 turbo
Member
Pullin gears
04 turbo's Avatar
Thanks for thr replies.
Hutch,jshelton and Griner him self thanks alot pm sent
04 turbo is offline   Reply With Quote
Old 12-01-2011, 08:23 PM   #18
grinertech
Launchin
Quote:
Originally Posted by 04 turbo View Post
is it still a good brake behind a 632 and three kits in a 3000lbs car
It will still work better than any thing bought elsewhere but bear in mind, But you need to know that there is a turbo version that has the low band clamped on all the way through low gear.
Two prototypes were tested in turbo cars with data loggers at the end of this season to see if there was any ill effects such as band overlap, and there was none.
Also, with the low band clamped on, the low sprag is protected against any damage if you encounter tire shake.
But the best part, Trans brake setup is instant. just breath on the switch and I repeat, "It Is Instant." This is great for spooling and staging at the same time.
Got your PM and the shuttle balls are going out next week. Here are some pictures of the new "B Type" valve body.
[IMG][/IMG]
[IMG]
[/IMG]
grinertech is offline   Reply With Quote
Old 12-01-2011, 10:11 PM   #19
chris718
Steve from a quick look its looking like you finally started feeding the high gear thru the reverse passage.Now the 2 things I had over on you with an iron casting(no band on in lo and use of the stock 3rd gear passage)cannot be used for a comparison of the 2 anymore.There is nothing left for me to complain about.Youve beat me but the sequel will be a billet version as well.Remeber,its guys like you that inspire guys like me.Thanks.Putting my personal feelings aside,I give you alot of respect in the design department,you are a true legend in the field.
Cristoforos Kokkonis,GM automatic transmission specialist.
chris718 is offline   Reply With Quote
Old 12-01-2011, 10:32 PM   #20
Streetracer09
Antiquated Member
Chris, I havn't seen those 200r4 parts I inquired about last week. Let me know if you shipped them I am scared that UPS lost them.
S. Griner, Thats an Awsome looking valve body. We have installed a few for customers and there top notch all the way. Also, kudos for the great customer service here. I always think it's neat to see your old products surface after 20 years still in one piece.
Streetracer09 is offline   Reply With Quote
Old 12-01-2011, 10:48 PM   #21
rick90lx
rick90lx's Avatar
Steve Griner
Sending upgraded parts for a second hand piece that's 20 yr's old, says so much about your character!
383
S480
highports
TH400
UCC converter
Holley Dominator EFI
rick90lx is offline   Reply With Quote
Old 12-01-2011, 11:09 PM   #22
Streetracer09
Antiquated Member
^^^ X2 Even if they are just rubber check balls, lol!
Old 12-01-2011, 11:30 PM   #23
chris718
http://www.youtube.com/watch?v=Jk8D7...eature=related
Resources saved on this page: MySQL 1.14%
