griner brake which one - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 11-28-2011, 06:42 PM   #1
04 turbo
Member
Pullin gears
04 turbo's Avatar
Default griner brake which one
gut had a friend give me a th400 griner brake and trying to find out which one it is.
has two check balls in it and no part number that i can find.
thanks
rich
04 turbo is offline   Reply With Quote
Old 11-28-2011, 06:52 PM   #2
04 turbo
Member
Pullin gears
04 turbo's Avatar
Default Re: griner brake which one
does have gold sep plate
Old 11-28-2011, 07:37 PM   #3
JShelton
any #'s stamped on the sep. plate?
JShelton is offline   Reply With Quote
Old 11-28-2011, 08:38 PM   #4
Hutch
Moderator
Hutch's Avatar
Should be a number CNC machined right into the VB. Post a pic and we'll ID it here. Should only have 1 big plastic check ball.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 11-28-2011, 09:02 PM   #5
04 turbo
Member
Pullin gears
04 turbo's Avatar
two 1/2 inch balls,i will try post a pic in the morning.
thanks
Old 11-29-2011, 01:10 AM   #6
Hutch
Moderator
Hutch's Avatar
May be the old cast brakes. Back then there was only 1 valve body and it was a 3speed reverse manual.
Hutch
www.hutchtrans.com
519-453-4318
Old 11-29-2011, 06:49 AM   #7
04 turbo
Member
Pullin gears
04 turbo's Avatar
Old 11-29-2011, 06:50 AM   #8
04 turbo
Member
Pullin gears
04 turbo's Avatar
Old 11-29-2011, 06:50 AM   #9
04 turbo
Member
Pullin gears
04 turbo's Avatar
Old 11-29-2011, 08:55 AM   #10
DOTracer
DOTracer's Avatar
Solenoid missing.
DOTracer is offline   Reply With Quote
Old 11-29-2011, 09:20 AM   #11
04 turbo
Member
Pullin gears
04 turbo's Avatar
i have the solenoid just not in the pics
Old 11-29-2011, 12:44 PM   #12
Hutch
Moderator
Hutch's Avatar
Thats an early cast model and im pretty sure it still retained the 34G10 part number.
Hutch
www.hutchtrans.com
519-453-4318
Old 11-29-2011, 02:27 PM   #13
04 turbo
Member
Pullin gears
04 turbo's Avatar
Thanks Hutch
Old 11-29-2011, 02:39 PM   #14
04 turbo
Member
Pullin gears
04 turbo's Avatar
is it still a good brake behind a 632 and three kits in a 3000lbs car
Old 11-29-2011, 08:46 PM   #15
grinertech
Launchin
Hey ! This is Griner
That Brake is old, old, old, But there is nothing wrong with it. It will still work better than any thing bought elsewhere.
That is the cast aluminum version (pre 1992), don't confuse it with the billet version. It will back up without poking the trans brake button, and it is much in demand by certain people that don't like the reverse safety feature.
One important upgrade, It appears that it has the black rubber balls. They need to be replaced with the white nylon type balls. This is most important !!!!
PM me a address and I will send them to you.
Steve Griner
grinertech is offline   Reply With Quote
