Vega front disc brakes - Yellow Bullet Forums
Old 11-28-2011, 11:25 AM   #1
dkline
dkline's Avatar
Default Vega front disc brakes
Anybody know of a spindle that works with Vega factory control arms? Trying to put some disc brakes on but do not want to do the weld on Aerospace kit. I think it would be best to just swap the spindle. Thanks in advance.
Doug Kline
Precision Chassis, Inc.
(484) 932-8031
View our page: http://www.facebook.com/pages/Precis...0719439?ref=hl
dkline is offline   Reply With Quote
Old 11-28-2011, 11:26 AM   #2
blown64vette
Launchin
Default Re: Vega front disc brakes
S-10 spindles bolt up to the stock control arms, but you have to use a ball joint spacer. Definitely the cheapest and easiest way to convert to discs and 5 lug.
blown64vette is offline   Reply With Quote
Old 11-28-2011, 11:29 AM   #3
ryan4057
ryan4057's Avatar
My dad put aerospace on his vega all the way around, There was no welding required. A little trimming is all. He goes 9.0's no prob stopping eather
ryan4057 is offline   Reply With Quote
Old 11-28-2011, 12:57 PM   #4
HR1140
Burnout box
HR1140's Avatar
Having done both the S-10 spindle swap, and the aerospace kit, I would have to say I prefer sticking with the stock vega spindles. All that is required is to cut off the original caliper ears, and weld on a tab for a third mounting bolt... Easy!
The advantage to going with the S-10 swap is availability of brake kits, and ball joints. But you will have to track down the spindles and get the spacers from V-8 monza. Either way you will have about the same amount of work so stick with what you got.
HR1140 is offline   Reply With Quote
Old 11-28-2011, 01:00 PM   #5
dkline
dkline's Avatar
Thanks!!
Doug Kline
(484) 932-8031
Old 11-28-2011, 05:46 PM   #6
Lafnbowtie
Lafnbowtie's Avatar
Quote:
Yep, seen it done but its been awhile, good swap though!!
Lafnbowtie is offline   Reply With Quote
Old 11-28-2011, 05:57 PM   #7
psyco66
Spooled up
psyco66's Avatar
Bought my vega and it had the s-10 set up on it. I put stock vega spindals back on and did the aerospace kit. You do have to weld the tab on. Very easy.
70 Vega 355sbc 10:1 on a 200 shot. 8.87 at 155. Street car.
psyco66 is offline   Reply With Quote
Old 11-28-2011, 06:50 PM   #8
mrss01
mrss01's Avatar
x2 aerospace easy to install and stop good too.
mrss01 is offline   Reply With Quote
Old 11-28-2011, 07:05 PM   #9
apacheracing
apacheracing's Avatar
Location: Where there is Cold Beer Drag Racing and Hot Women
Anyone have pictures????
apacheracing is offline   Reply With Quote
Old 11-29-2011, 11:57 AM   #10
HR1140
Burnout box
HR1140's Avatar
I have some pics of the spindles when I was assembling the brakes. I'll post them when I get home.
Old 11-29-2011, 12:09 PM   #11
mike s
Member
Pullin gears
mike s's Avatar
PM Sent...
mike s is offline   Reply With Quote
Old 11-29-2011, 09:52 PM   #12
KILLER01SONOMA
Spooled up
im doin the s10 swap on my 76 hatch did the the axles and spindles in fron with the v8monza.com adapters workin good so far
KILLER01SONOMA is offline   Reply With Quote
Old 12-03-2011, 03:09 PM   #13
overkillrc
7.86 @ 8800DA 3365lb 275s
overkillrc's Avatar
i offer tubular control arms that use S10 ball joints and correct for the camber change and I add caster. i also do them for vega ball joints but don't recommend it the ball joints are no where near as strong as the S10's. if you want to stick with the stock spindles i recommend still using the S10 ball joints and just ream out the spindle taper to match the S10 BJ's
Justin Kill
Overkill Race Cars 970-581-8134
Loveland, CO
www.overkillracecars.com
H-body control arms and parts
http://www.overkillracecars.com/Products.html
overkillrc is offline   Reply With Quote
Old 12-03-2011, 04:08 PM   #14
Doug Paddock
its blingtiffic
Doug Paddock's Avatar
Quote:
^^^^^Mr. H Body himself^^^^^
TVC. (Team Vertically Challenged) Honorary Member!
Special Thanks to
Justin Overkill Racecars
Krusty,Meg and Neil at PBK
Hyperaktive Tuning. Joe is the BEST!!
Josh Lindsey Best kept secret in small tire racing! Bruder Bros!
M&M Transmissions, Marty at Chance!
The "Shock Nerd" Mark Menscer Motorsports
The Grey Ghost 6.53 @ 232 SCSN 1/4 mile DR winner
El Jefe Worlds Fastest Coyote Powered Mustang 215.4 standing mile not even trying!
Doug Paddock is offline   Reply With Quote
Resources saved on this page: MySQL 1.04%
