Best Electric Trailer Jack - Yellow Bullet Forums
Old 11-27-2011, 07:46 PM   #1
tenfiveracer
In the Beams.
tenfiveracer's Avatar
Default Best Electric Trailer Jack
For the 28 foot haulmark. Mine took a dump .
Any ideas?? Getting one with an emergency manual Crank is a must
tenfiveracer is offline   Reply With Quote
Old 11-27-2011, 07:53 PM   #2
colormebad
Billy438Stroker
colormebad's Avatar
Default Re: Best Electric Trailer Jack
We been using the old satellite jack/motors here for years..The hammerblow jack was stong to the bone... They mount the same way...
colormebad is offline   Reply With Quote
Old 11-27-2011, 07:54 PM   #3
frizyme
Member
Pullin gears
frizyme's Avatar
atwood are very good i install them all the time at work customers are really happy with them
frizyme is offline   Reply With Quote
Old 11-27-2011, 07:57 PM   #4
montys 55
montys 55's Avatar
Barker Electric Power Trailer Jacks works for me.
http://www.towshop.com/barker_electric_jacks.htm
montys 55 is offline   Reply With Quote
Old 11-27-2011, 08:03 PM   #5
SUPERSTOCKRACER
SUPERSTOCKRACER's Avatar
i just got one from northern tool. $169.00 best thing i ever bought to lift my 34 foot trailer.no more cranking.
SUPERSTOCKRACER is offline   Reply With Quote
Old 11-27-2011, 08:16 PM   #6
Bad News
Bad News's Avatar
Best...... Attwood 3500 pound. Cheapest no.
My 10 year old just lost the upper bearing inside the tube. Called Attwood as there was not enough left to match up. The nice lady said I was the first one to need that piece. She had one on the shelf and would send it to me no charge.
IDIOT MAGNET
Bad News is offline   Reply With Quote
Old 11-27-2011, 08:22 PM   #7
slowstang101
slowstang101's Avatar
dont mean to high jack but do they use battery power from the truck or a separate battery inside the trailer
2000 Mustang - SBF, PT106 on Ethanol
slowstang101 is offline   Reply With Quote
Old 11-27-2011, 08:26 PM   #8
Mean Green
Mean Green's Avatar
Atwood in use here, good piece. I have a separate batt. in trailer,
Look out Ultra...Here I come.
Mean Green is offline   Reply With Quote
Old 11-27-2011, 08:38 PM   #9
junks10
Spooled up
Quote:
i was using a battery charger on mine.. i let a buddy borrow it and he wired it into a wire off the trailer plug...
junks10 is offline   Reply With Quote
Old 11-27-2011, 09:46 PM   #10
tenfiveracer
In the Beams.
I was looking at that one Ted , BTW how did you do yesterday. I didn't qualify for promod but got some good info on the last run..
I'm running the 2500 now and it's just getting slower and slower and finally quit cranking..
Ill take a look at it ..
there's also a brute force 4500 available too....
Old 11-27-2011, 09:48 PM   #11
SlickVic
SlickVic's Avatar
I have an Ultra Fab..the switch would stick going down but i used that to my advantage until i forgot to unstick it one time and the switch burnt up. Resorted to just twisting the hot wire and grounds depending if i want to go up or down just because im lazy and haven't took time to fix it.
slickvic@slickvicracing.com
www.slickvicracing.com
302-786-1078
Necksgen REV, HANS, and Simpson Hybrids available!
Carrying all your safety items, engine components, chassis pieces, wheels, tires, and custom fabrication of any part, big or small!! Contact me for all our current specials!!
SlickVic is offline   Reply With Quote
Old 11-27-2011, 10:04 PM   #12
tenfiveracer
In the Beams.
I might also just run 16 volts to my 2500 electric jack , it might work better. But dont like the fact that it doesnt have a manual override...
Old 11-27-2011, 10:46 PM   #13
clwill
clwill's Avatar
Had them all. The BEST one, by far, is the Bulldog jack: http://www.bulldogproducts.net/conte...7530%20&part=0
This thing is quiet as a whisper, rated to over 4000lbs, and best of all, has a drop foot. You pull up, drop the foot, and then you don't have to run the jack more than a foot or so. And if you're like me, and need to jack the trailer up to get the car out smoothly, the drop foot makes it so you can jack it up a ton to get the car out.
I love this thing. I've told everyone I know about it. Best invention since sliced bread.
clwill is offline   Reply With Quote
Old 11-27-2011, 11:18 PM   #14
clwill
clwill's Avatar
By the way, the Bulldog doesn't need a manual crank that you have to keep track of. A 3/4" socket is all you need. Open a little flap, there's the nut, crank away.
Old 11-27-2011, 11:30 PM   #15
Seattle_Mike
Seattle_Mike's Avatar
Thanks for the tip...did you get it locally? Price? I've got a Barker 3,500 and it seems marginal.
68 Camaro ProMod - 848ci - M&M 3 Speed
www.yvonnelucasracing.com
Seattle_Mike is offline   Reply With Quote
