SBC 15 Degree intake - Yellow Bullet Forums
Old 11-19-2011, 01:09 PM   #1
mudder81573
Spooled up
mudder81573's Avatar
Default SBC 15 Degree intake
Please bear with me, I am trying to learn...
What makes a 15-18 degree intakes different than a 23 degree intake?
Is the intake gasket surface angle different? Runner location? Bolt pattern?
Thanks for informing the stupid.....
mudder81573 is offline   Reply With Quote
Old 11-19-2011, 01:28 PM   #2
Butch Kemp
Butch Kemp's Avatar
Default Re: SBC 15 Degree intake
the heads are "layed" over more the closer the valve angle gets to zero...so
the intake you use for a 23 degree head would need approximately a 1" spacer for a 10 degree head.
Took my bat and ball to play in ultra street.
ET record holder 4.773
Do it right the first time
Keep your promises
Dream BIG
Thanks to:
Chris Uratchko
Mickey Thompson tires
Marty Chance
Dean marinis
Butch Kemp is offline   Reply With Quote
Old 11-19-2011, 03:39 PM   #3
JeffMcKC
JeffMcKC's Avatar
The intake face angle on a 15* or 18* they are the same a 23* is different like Butch says, but a 18X from brodix uses the same as a 23* the spacer would have to be a wedge shape to fit a 23* to a 18*
"IF IT DOES NOT HAVE A TRAILER HITCH ITS A RACE CAR!!!"
TRZ Dealer
2012 Winner SSSB/NA 9.67 @ 139MPH
2007 Winner SB/NA Drag Week 9.98
Thanks Curtis @ RFD Heads and Intakes
http://www.raceflowdevelopment.com/
JeffMcKC is offline   Reply With Quote
Old 11-19-2011, 03:50 PM   #4
Vinny V
Vinny V's Avatar
depends on head ,some have a 10 deg face which is common on 23 deg heads .Some 15 and 18 deg have a 5 deg face.I used to cut about .065 off of 5 deg face vertically to port entrance back in the day because 10 deg face manifolds were only thing available.
Vinny V is offline   Reply With Quote
Old 11-19-2011, 09:23 PM   #5
mudder81573
Spooled up
Thanks guys for the info, trying to make up my mind which direction to go for the next build. I have a bunch of 23 deg stuff laying around, just seeing if it's usable for 15-18 deg heads.
Old 11-20-2011, 09:07 AM   #6
JeffMcKC
JeffMcKC's Avatar
How big is the motor?
Just geussing the volume will be to small anyways
TRZ Dealer
Old 11-20-2011, 11:54 AM   #7
mudder81573
Spooled up
I want to reuse my Enderle injection that is on a Edelbrock victor tunnel ram. I am leaning towards doing a 421.
Old 11-20-2011, 12:01 PM   #8
RCM Racing engines
RCM Racing engines's Avatar
your 15-18* true heads have a 5* intake face, 23 is 10* as mentioned, but also the true 18* and 15* have raised runners
23 degree stuff will not fit or work very well unless you want to spend way to much time and $$$ in my opinion......
Just an old' Mennonite..........
RCM Racing engines is online now   Reply With Quote
Old 11-20-2011, 12:59 PM   #9
mudder81573
Spooled up
That is what I am seeing, might as well spend the extra cash and get a matched combo.
Thanks guys, appreciate the help.
Old 11-21-2011, 03:14 PM   #10
Vinny V
Vinny V's Avatar
I have put that intake on many 5 deg face heads.It can be a job but like i mentioned earlier you have to cut intake face pad vertically and get it to 10 deg then i cut spacers with laser to raise the manifold to port location.You have to make end pieces to fit between intake and block and use a adjustable collar dizzy but it can be done.Back in the day there wasnt much choice for intakes like now.Just something for you to think about.
Old 11-21-2011, 03:29 PM   #11
Vinny V
Vinny V's Avatar
I do have some different sbc spacers cut to 1206 and 1263 gaskets in .100 and .125 and .250 amd .387 and some end plate spacers as well.
Resources saved on this page: MySQL 1.08%
