TH400 CONVERTER INTO A POWERGLIDE - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 11-15-2011, 11:39 AM   #1
04 turbo
Member
Pullin gears
04 turbo's Avatar
Default TH400 CONVERTER INTO A POWERGLIDE
put a th400 converter in to a powerglide.
is the stall or anything else going to change.
thanks
04 turbo is offline   Reply With Quote
Old 11-15-2011, 01:09 PM   #2
frtlnrbuick
My little SBC...
frtlnrbuick's Avatar
Default Re: TH400 CONVERTER INTO A POWERGLIDE
It should go up some due to the lower gear ratio.
Jim
I'm the other N/A car in Limited Street.
Quote:
Originally Posted by Mark O'Neal
I'm as certain that you have a point as I am that you are failing to get it across.
frtlnrbuick is offline   Reply With Quote
Old 11-15-2011, 04:10 PM   #3
JShelton
Just a little heads up turbo, If you go with a turbo input splined shaft in your P/G you have to make sure the converter is set up to support the shaft or the stator support itself is set up to support the shaft. Not sure if your aware of this so I thought I'd throw it out there.
JShelton is offline   Reply With Quote
Old 11-15-2011, 08:20 PM   #4
slow8.0
slow8.0's Avatar
So just because a trans is advertised as "having a turbo splined input shaft" does'nt mean you can throw a converter out of a TH400 in it correct?
________________________________
No one is always busy....It just depends what number you are on their priority list.
slow8.0 is offline   Reply With Quote
Old 11-16-2011, 11:24 AM   #5
JShelton
Quote:
Originally Posted by slow8.0 View Post
So just because a trans is advertised as "having a turbo spline input shaft" doesn't mean you can throw a converter out of a TH400 in it correct?
Depends, If the stator support is set up to support the shaft...yes. If not then the converter has to be set up with the support. There are different designs and combinations so you have to have all your ducks in a row sort of speak.
Old 11-16-2011, 01:12 PM   #6
04 turbo
Member
Pullin gears
04 turbo's Avatar
Yes the glide has a bushing in it,the only thing we changed was the trans,th400 to a powerglide turbo input shaft w/bushing.i was not sure if anything would change because the converter was built for a th400 trans.
Old 11-16-2011, 01:27 PM   #7
JShelton
Quote:
Run it!
Old 11-16-2011, 02:42 PM   #8
jmwj03
Spooled up
I was just about to post a similar question...I rebuilt my PG and used a new stator and input shaft set up for the TH converters. After assembling, I had the extra bushing as I was told if the bushing ins't in the converter, you will need to install this. Is the bushing being installed in the converter that obvious? Will I know just by looking? I was told installing both would be as big a no-no as not installing either of them. Can someone describe what the bushing looks like in the converter? I know...stupid questions to some of you, but this is my first PG.
jmwj03 is offline   Reply With Quote
Old 11-16-2011, 04:36 PM   #9
JShelton
If the input shaft is designed to run with a bushing I use them weather the converter has the support in it or not and have never had an issue with it. If you know the manufacture of the converter and have a part # the manufacture should be able to tell you if it has one. If you are pulling this converter out of a th350 or 400 and just putting it in your powerglide chances are it doesn't have the support in the converter. Hope this helps.
Old 11-16-2011, 04:56 PM   #10
DirtyD0g
Pre-Staged
Any 30 spline if the bushing was installed into the stator support will work, most aftermarket converters use a bushing anyway because it is better to hold a shaft at both ends than at one end and the center. True stall will not change at all, depending on ratio the footbrake stall may vary a little bit.
Alan
DirtyD0g is offline   Reply With Quote
Old 11-16-2011, 06:25 PM   #11
04 turbo
Member
Pullin gears
04 turbo's Avatar
Hutch what do you think
Old 11-16-2011, 07:59 PM   #12
SS632
SS632's Avatar
Quote:
X2, I just used my th350 converter in a glide with the turbo spline shaft a did not know anything about a bushing, FTI converter.
SS632 is offline   Reply With Quote
Old 11-16-2011, 08:00 PM   #13
slow8.0
slow8.0's Avatar
What will happen if the trans doesnt have the (support)bushing installed?
Old 11-16-2011, 08:01 PM   #14
Hutch
Moderator
Hutch's Avatar
Other than all the support bushing information that is most important , the stall will increase slightly but it won't be much. Maybe 150-250 rpm higher in low gear and the same shift drop on the 1-2 as the 2-3 of the T400
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 11-16-2011, 08:04 PM   #15
Hutch
Moderator
Hutch's Avatar
If the converter has one then you are alright. If neither has one it will make a mess and there are also input shafts that require a bushing just for oil circuit completion. Many input shafts have no provision for a bushing so it can ONLY be installed in the converter.
Most all good converters have a bushing installed regardless of transmission using a "turbo" shaft.
Hutch
www.hutchtrans.com
519-453-4318
Resources saved on this page: MySQL 0.99%
