496 cu.in or 540.cu.in BBC. Will it make a big difference??? - Yellow Bullet Forums
Old 11-09-2011, 02:49 AM   #1
protobuild
protobuild's Avatar
Default 496 cu.in or 540.cu.in BBC. Will it make a big difference???
Looking to build a new short block. Is there that much gain in moving up from a 496 to a 540 cu.in other than 44 inches. Already have cnc,d heads, Intake, new cam, fogger etc.
Help ?? before I break the piggy bank.
Old Crank Racing.
protobuild is offline   Reply With Quote
Old 11-09-2011, 03:20 AM   #2
55sedan
55sedan's Avatar
Default Re: 496 cu.in or 540.cu.in BBC. Will it make a big difference???
If had it to do over, I would spend the extra 1500-1700 for a 4.5 block and went 540.
JMO
BBC P/Glide 12 Bolt on Leafs
55sedan is offline   Reply With Quote
Old 11-09-2011, 03:30 AM   #3
TD626C
Member
Pullin gears
TD626C's Avatar
agree^^^^^^^^^then its just a slug swap to go 555 or 565
TD626C is offline   Reply With Quote
Old 11-09-2011, 10:40 AM   #4
mrdragster1970
T/S 368E
mrdragster1970's Avatar
Depends on the heads.
I have a ton of used BBC-Dragrace-Trucks- 4 sale, personally listed items only.
For my babies, we will always remember.
In memory of Chris
Costa, you will never meet a nicer guy. I will never forget your kindness, when I needed it.
mrdragster1970 is offline   Reply With Quote
Old 11-09-2011, 11:21 AM   #5
bracketchev1221
Go for the 540. But like was said, you would probably need at least a 335 cnc head for it.
http://s30.photobucket.com/albums/c306/bracketchev1221/chevelle%20pics/?action=view&current=DSC01615.jpg
Best ET so far 9.03 148 @ 3200 lbs.
bracketchev1221 is offline   Reply With Quote
Old 11-09-2011, 01:21 PM   #6
protobuild
protobuild's Avatar
Thank,s guys. The heads I have purchased is a set of canfield 320's ported by cfe. That was one of the limits I was in question about also. I was told they would work well on a 496 but rpm would have to move up to get them to work on anything smaller.
Thanks again for the input.
Old Crank Racing.
Old 11-09-2011, 01:26 PM   #7
protobuild
protobuild's Avatar
I will probably go with the bigger cu.in. build to save the expense of boring over the added cost of a 4.500 new block. Bore and hone (496) vs. just hone to size. ?
Old Crank Racing.
Old 11-09-2011, 01:48 PM   #8
JShelton
What block do you plan on running?
JShelton is offline   Reply With Quote
Old 11-09-2011, 02:17 PM   #9
Niroz
Member
Pullin gears
Niroz's Avatar
Go with the 540 ! The best choice all the way
Niroz is offline   Reply With Quote
Old 11-09-2011, 02:20 PM   #10
protobuild
protobuild's Avatar
Considering a dart block. But I am lookin for the best bargain that will still allow me some overbore and have enough wall thickness to be safe for a moderate power adder.
Old Crank Racing.
Old 11-09-2011, 03:11 PM   #11
mrdragster1970
T/S 368E
If you can afford a big bore block, you will have plenty of meat to start at 4.500 and work up for years, or it blows up.
With those heads, you will not gain as much as with a bigger head, at least I didn't, and I'm now trying to upgrade due to running out of air.
If I was doing a budget build, I would get the best small bore block I can afford, and start at 482" and have meat left over.
Good luck.
In memory of Chris
Old 11-09-2011, 03:47 PM   #12
JShelton
Quote:
I agree with mrdragster go with the dart block,tune your shit safely and get lots of yrs service out of it!
Old 11-09-2011, 07:45 PM   #13
REDNOVA
Launchin
If you're gonna spend the money for a Dart block I would go with the 4.500 bore block. Then you can make it just about any size you want from 509 to 598 by just swapping the rotating assembly. Buy the big bore block once, you won't be sorry you did. Good luck, keep us posted.
REDNOVA is offline   Reply With Quote
Old 11-09-2011, 08:33 PM   #14
Bob Deniker
Bob Deniker's Avatar
I would do a 532. JMO, but that combo has worked well for me.
Bob Deniker is offline   Reply With Quote
Old 11-09-2011, 08:49 PM   #15
tvwilkes
Launchin
tvwilkes's Avatar
Go with the 4.500 bore. The cylinder heads will flow more on the larger bore size. The chambers in your heads are machined for a 4.500 bore as well.
tvwilkes is offline   Reply With Quote
Resources saved on this page: MySQL 1.03%
