"BIG" fuel injectors (these may help some guys out) - Page 3 - Yellow Bullet Forums
Old 01-18-2008, 12:22 AM   #31
njc.corp
njc.corp's Avatar
Question
Quote:
Originally Posted by twinturbogt View Post
The reason they run so many injectors on morans car is because that thing needs a ton of fuel to make the sick power it does . methanol takes on average 2.4 times more than gas and moran makes 5 times more power than normal people .
how much power is he making-rough guess-??/
NJCLSX ENGINES- PARTS/SALES/PERFORMANCE
www.njclsx.com
sales@njclsx.com
PH-61 03 9331-6757
FRE--ENGINES
www.Nitrousoutlet.com
www.ptcrace.com
www.straubtechnologies.com
njc.corp is offline   Reply With Quote
Old 01-18-2008, 01:05 AM   #32
2fastturbos
Spooled up
2fastturbos's Avatar
Default
Quote:
Originally Posted by Jeremy Glass View Post
Dont you mean 40-50% more fuel then gasoline?
you'll see when your car gets running, at bigger boost numbers it uses A LOT of fuel. twinturbogt isn't that far off.
2fastturbos is offline   Reply With Quote
Old 01-18-2008, 01:05 AM   #33
2fastturbos
Spooled up
Default
Quote:
Our car makes in the heighborhood of 3600HP
Old 01-18-2008, 01:17 AM   #34
njc.corp
njc.corp's Avatar
Cool
Quote:
thanks
Nick--
www.njclsx.com
sales@njclsx.com
PH-61 03 9331-6757
FRE--ENGINES
www.ptcrace.com
Old 01-18-2008, 02:42 AM   #35
johan
Launchin
johan's Avatar
Default
2.4 times more off methanol then gas will hurt your engine, I have tried...
You need to be somewhere around 3 times more, perhaps 3.5 times more.........
When guys like Mike make close to 4000hp that is a lots of meth !
johan is offline   Reply With Quote
Old 01-18-2008, 11:31 AM   #36
Rodrigues
Member
Pullin gears
Rodrigues's Avatar
Default
Yup... You'll be looking at an enriched a/f of:
100% Gasoline @ 20,000 BTU's/lb 11:1 to 13:1
100% Ethanol @ 11,500 BTU's/lb 4.3:1 to 8.2:1
100% Methanol @ 8,600 BTU's/lb 3:1 to 5.9:1
100% Nitro "Top Fuel" @ 4,900 BTU's/lb a/f of 1.1:1 to 1.7:1
Rodrigues is offline   Reply With Quote
Old 01-18-2008, 12:36 PM   #37
twinturbogt
My Own Worst Enemy
twinturbogt's Avatar
Default
yes jeremy that is what i ment . and 2.4 is only a reference point to start at , more power takes more fuel .
Jeff Paynter
Disclaimer: All views and opinions posted are mine and solely mine and are not to be held against anybody else.
Special Thanks to Proline Race Engines, Hyperformance Motorsports, M&M Transmission, Hyperaktive Performance Solutions,Tim Webb, Visa Platinum and most importantly my Wife.
I see you're playing stupid again.............looks like you're winning too.
twinturbogt is offline   Reply With Quote
Old 01-18-2008, 03:28 PM   #38
Jeremy Glass
The Enemy
Jeremy Glass's Avatar
Default
I believe it. Petty will have me going in the right direction.
Jeremy Glass is offline   Reply With Quote
Old 01-18-2008, 03:58 PM   #39
waterpog
Member
Pullin gears
waterpog's Avatar
Default
Good news is that those 650lb/hr injectors he's talking about are about 4X the size of the 160's and most of the big boys (moran aside) are getting along pretty damn well with just 3 sets of 160's so they should be plenty for the rest of us mere mortals and won't require the extra effort and expense of setting the motor and EFI system up for 16 or 24 injectors.
waterpog is offline   Reply With Quote
Old 01-29-2008, 05:39 PM   #40
Brett
Burnout box
Default
if there's anybody looking for a BIG injector, Moran Motorsports is releasing their own line of fully adjustable, billet injectors. They are available anywhere from 225 lbs/hr to 650 lbs/hr. With many years of R&D in this product, we have finally come up with a one of a kind design that allows us to deliver a great product of utmost quality. The best thing about these, are that they are compatible with just about every aftermarket injection system available. make sure to check out the write up in next months Hot Rod Magazine. thanks guys!
You guys got a contact number so I can get some more info on these?
Brett is offline   Reply With Quote
Old 01-29-2008, 06:37 PM   #41
redvictor
from across the pond...
redvictor's Avatar
Garage
Default
i heard about these this week in the UK. at least 4 years of development...
If they work AND last it'll be a injector revolution.
Gone from this place...
redvictor is offline   Reply With Quote
Old 01-29-2008, 07:11 PM   #42
gryphon68
gryphon68's Avatar
Default
Quote:
How many people are idling on one set 160's and bring in the other two sets with staging? Switching to an injector 3x bigger and you lose that option.
gryphon68 is offline   Reply With Quote
Old 01-29-2008, 07:19 PM   #43
redvictor
redvictor's Avatar
Garage
Default
Quote:
i'm running with 300# per cylinder at idle with gas. The EFI is running at 1.1%,so trying to run 450# at idle on gas would be difficult. Alcohol race motors are completely different.
Old 01-29-2008, 07:49 PM   #44
gryphon68
gryphon68's Avatar
Default
Quote:
Quick and dirty calculation 300x1.1%=3.3 lbs, 3x for Gas to Meth =9.9lbs from 450# injectors is still only 2.2%, so its not near as bad, but still a bit of a resolution issue. A tenth of a percent (the resolution limit on most ECU's) is still almost 5% more/less fuel per step at idle.
Old 01-29-2008, 08:08 PM   #45
Brett
Burnout box
Default
Does anyone have some specs on these new 650lb injectors?
i.e. Opening time, min and max duration, max current draw and some pics and pricing if possible.
