Chevy TBI guru's please help - Yellow Bullet Forums
Old 11-03-2011, 02:48 PM   #1
victor3ranger
Launchin
Default Chevy TBI guru's please help
I need some help with my truck, I am about to pull my hair out trying to figure out what is causing my truck to run like shit.
It is a 1995 GMC Z71 with a TBI 350.
When driving at any speed it acts like it has water in the gas, spits, coughs, feels like a misfire.
I have been dealing with this off and on for the past year, now it is doing it all the time. At first I thought it might be the ethenol in the gasbut now not so sure.
Changed cap, rotor, wires, plugs, ect, pickup coil, nothing helps. When it is hot and dry outside the problem seems to go away. But when it gets cold or wet it starts back up again.
Would the EGR valve couse something like this? Anything else to check?
Check engine light doesn't come on either.
Anyone got any ideas??
victor3ranger is offline   Reply With Quote
Old 11-03-2011, 02:54 PM   #2
GTA matt
Creepy Ass Cracka
GTA matt's Avatar
Default Re: Chevy TBI guru's please help
Check fuel pressure
GTA matt is offline   Reply With Quote
Old 11-03-2011, 03:06 PM   #3
victor3ranger
Launchin
I have checked the fuel pressure before and it was within spec but I will check that again.
Any other ideas??
Old 11-03-2011, 04:24 PM   #4
projoe87
use a ac delco cap, ive seen those new be an issue.
projoe87 is offline   Reply With Quote
Old 11-03-2011, 04:31 PM   #5
GT 350
Grizzly
Check e.c.t sensor
GT 350 is offline   Reply With Quote
Old 11-03-2011, 04:36 PM   #6
slow3rdgen
slow3rdgen's Avatar
Two problems Ive had with them is the temp sensor for the computer have a short in the wire and cause similar symptoms all the way to the point it would die at lights if you didnt give it gas!
The other is the wiring going to the coil also have a short and it would run shitty, spit sputter and often times not even crank.
goodluck
slow3rdgen is offline   Reply With Quote
Old 11-03-2011, 04:50 PM   #7
victor3ranger
Launchin
GT 350, what is the ect sensor?? where is it located?
slow3rdgen, is the temp sensor on the front of the intake manifold? Also, you talk about a short in the wire going to the coil, do I just check that by tracing the wires from the distributor back to the computer?
And trace the wire from the temp sensor all the way back to make sure its ok???
Thanks for the info guys, keep giving me ideas, this thing is driving me nuts.
Old 11-03-2011, 05:06 PM   #8
tsanchez
tsanchez's Avatar
Had dist shaft bushings cause issues, most of the time all that goes wrong with them is fuel pressure though. Under the dash on right side is the connector for checkig timing, basically bypasses the ecu for timing, disconnect it and drive it, if it quits the misfires etc(will be lazy) then most likely is dist bushings or magnet on shaft cracked.
Could also be a bad ign coil.
tsanchez is online now   Reply With Quote
Old 11-03-2011, 05:09 PM   #9
MrGrim
MrGrim's Avatar
check the knock sensor and the tps
Expecting the world to treat you fairly because you are a good person is like expecting the lion not to attack you because you are a vegetarian.
MrGrim is offline   Reply With Quote
Old 11-03-2011, 05:10 PM   #10
BIGZEKE92
Hit Em In Da Mouf Racing
BIGZEKE92's Avatar
KNOCK SENSOR IS BAD
"Hit Em In Da Mouf Racing " from Dallas.....but now racing in Mississippi "This is a public announcement for the ex-wife that took my car and kids ....I'm back sukka " "Hit Em In Da Mouf " Racing
for instance, a intelligent alien species somewhere in the oldest part of the universe, sent out spores packed with DNA in a explosive manner like a super nova.
BIGZEKE92 is offline   Reply With Quote
Old 11-03-2011, 05:19 PM   #11
victor3ranger
Launchin
BIGZEK, where is the knock sensor located??
tsanchez, I will get in touch with a friend of mine and see if he can check the timing for me.
Is it possible that the injectors could be going bad???
Old 11-03-2011, 05:24 PM   #12
GT 350
Grizzly
Its the sensor right by the thermastat housing in the intake ...the knock sensor should be on the back side of the block at where the bell hosing meets at the top ...or on the side of the block it will look like a white mushroom ...
Old 11-03-2011, 05:24 PM   #13
BIGZEKE92
BIGZEKE92's Avatar
under driver side exhaust manifold ....when they go bad they are trying to adjust timing ....it throws the fuel curve out of wack
Old 11-03-2011, 05:26 PM   #14
victor3ranger
Launchin
Great info guys, those two things should be easy to check and cheap to replace.
Old 11-03-2011, 07:23 PM   #15
tsanchez
tsanchez's Avatar
Knock sensor is on pass side just ahead of starter near motor mount.
