making A 671 Blower - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged - All Out Automotive
Old 10-20-2011, 01:08 PM   #1
Dzuari
Launchin
Dzuari's Avatar
Default making A 671 Blower
Figured id post this on the bullet, dont really post to much, usually just read but i figured some of you might find this really interesting.
I work for an aluminum Foundry and Production CNC shop in Muncie, IN, Phillips Patterns and Castings. We making American made parts, Im an engineer and pattern maker.
I've designed up a 671 blower and am machine the pattern right now which will be used to make casting then the castings will be machined into the final product.
Im machining the pattern right now, should have castings by next week and ill post the video hopefully by beginning of next month if anyone cares to see it.
If anyone has questions, feel free to ask.
Here is a photo of the CNC machine cutting the pattern, im cutting this in 3" layers of renwood. The layers are just super glued together then i post-process the tool paths and drip-feed it to the machine. This photo is of it doing a Z plan cut and leaving a 0.0500" machine stock.
This photo is the designed pattern i am cutting.
This photo is what the finished casting will look like.
Dzuari is offline   Reply With Quote
Old 10-20-2011, 01:31 PM   #2
Comax Racing
Comax Racing's Avatar
Default Re: making A 671 Blower
Looks good. WOW,SOMEBODY HAS LOTS OF TIME ON THIER HANDS.
Comax Racing is offline   Reply With Quote
Old 10-20-2011, 02:19 PM   #3
blownzoom440
blownzoom440's Avatar
are you going to mod the design in any way from the std 1?[case water cooling,dbl wide intercooler core base?]
http://www.youtube.com/watch?v=UPeXFz7U7R8
Victor alum wedge heads.
A/W intercooled,race gas.
Koleno perf race block cross bolt mains.
firecore50 plug wires,Caltrac's
blownzoom440 is offline   Reply With Quote
Old 10-20-2011, 07:50 PM   #4
BigB
Member
Pullin gears
BigB's Avatar
This will be cool to watch..........
BigB is offline   Reply With Quote
Old 10-21-2011, 02:33 AM   #5
Blown06
Why are you doing this? Are there improvements to be made over what is currently available?
Blown06 is offline   Reply With Quote
Old 10-21-2011, 07:37 AM   #6
blownzoom440
i have an A/W from the blowershop and had the idea for the dbl core cooler that would only be 2" wider than the current case used.if you are interested in my idea i would be glad to give measurements and explane them.good luck on your project.i will be watching as it developes.
Old 10-21-2011, 08:25 AM   #7
mrtimstik
Member
Pullin gears
mrtimstik's Avatar
I will be watching this too. Thanks for sharing.
11 second club
mrtimstik is offline   Reply With Quote
Old 10-21-2011, 08:58 AM   #8
R-code17815
Infidel
R-code17815's Avatar
Kewl!!!
The never ending "Work in Progress"
R-code17815 is offline   Reply With Quote
Old 10-21-2011, 11:13 AM   #9
Dzuari
Launchin
Dzuari's Avatar
Quote:
This is my job but i love doing it and actually drew some of this model on my own time.
Quote:
We've improved the strength a bit by adding some material, on a big bore the walls will be 0.375", our side ribs are a bit thicker than normal i believe 0.4" at the top and almost and 1" at the bottom. the underside pockets are smalls so the bars are thicker, we also have a straight across bar for bolting to the intake, a bit heavier over all but a lot stronger. this one is mainly being manufactured for street use, under 11-12 pounds but doesn't mean it can't run harder .
Quote:
I would be interested in that, we are always looking to make more products and improve on existing ones, we are not still in business because we make bad products .
You can follow the complete build on our facebook page https://www.facebook.com/DiamondPRacing
Here is some more photos that I've been taking, i'm on my third day of machining it right now, the CNC is rough cutting it right now then i will have a finishing cut on it and be done. Then i just have to machine the core boxes and it will be ready to be molded and cast.
finishing cut on the second layer, 0.25" ball mill machined within 0.0005.
Second layer done.
Third layer rough cutting.
Old 10-21-2011, 12:32 PM   #10
Dave Koehler
Launchin
Dave Koehler's Avatar
Dzauri,
You folks pour/cast any Magnesium?
Dave Koehler
Koehler Injection
www.koehlerinjection.com
Fuel Injection - Nitrous Charger - Nitrous Master software - Balancing
Dave Koehler is offline   Reply With Quote
Old 10-21-2011, 01:41 PM   #11
Dzuari
Launchin
Dzuari's Avatar
We pour almag(which is the metal most automotive components are made out of when people say "its a ____ magnesium, they aren't pure magnesium.)
Old 10-21-2011, 02:58 PM   #12
blownzoom440
in this pic it looks like a dbl core can be placed between the opened up case on both sides of the core and still maintain the std bolt space for mounting.the core width is 4.5"wide and the space is 9" and the core ht is 3"and length is 17.75"from the endplate to the water fitting in the other end.the bare core can be viewed on some of the supercharger sites.
Old 10-21-2011, 03:03 PM   #13
blownzoom440
my point of the blower mod is to widen the discharge to the 9"[or close]in a taper over 1" in to the rotors.the intake would need this also maybe with a 1" spacer added.
Old 10-22-2011, 08:47 AM   #14
1970ls8
1970ls8's Avatar
a 'new improved' cooler would be on my list .. as well.
keep us informed.
way to go!
1970ls8 is offline   Reply With Quote
Old 10-22-2011, 07:31 PM   #15
Dzuari
Launchin
Dzuari's Avatar
Heres more photos of the pattern complete, now just have to mount it to a board, flip in and machine the underside, then machine the coreboxes.
I've also made a video of some parts we where machining in our machine shop earlier today, you can see some glimpses of our supercharger parts throughout the video.
http://www.youtube.com/watch?v=b4BmaiBLd00
The black lines you see are just pencil marks
Resources saved on this page: MySQL 1.03%
