Best place to inject water/meth - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Supercharged - All Out Automotive
Old 10-17-2011, 04:48 AM   #1
Wayne In NZ
Pre-Staged
Wayne In NZ's Avatar
Default Best place to inject water/meth
I know it has been probably covered but i cant find it.
I have it injecting into the top of the roots blower.
Is it better to inject it into the manifold after the blower?
Lets say that the blower demands 1000cfm at max power.
Normally it would suck it through the carburettor.
The carburettor in turn would venturi in the alloted amount of fuel dependant on the tuning of the carbuettor in order to achieve the desired exhaust gases to give a good air/ fuel ratio, and optimum power.
Now......
If we feed some of the blower demand by direct injecting into the top of the blower the equivalent to say....200cfm of injectant, then the blower would now only demand 800cfm from the carbuettor.
Therefore the carbuettor would now venturi in the alloted amount of fuel dependant on the above tuning scenario, but at 800cfm and not 1000cfm.
And then make about the same power.
If we injected below the carbuettor then the blower would still demand 1000cfm through the carburettor AND the engine would get that PLUS the injectant
Any thoughts would be appreciated.
Wayne In NZ is offline   Reply With Quote
Old 10-18-2011, 01:19 AM   #2
Wayne In NZ
Pre-Staged
Default Re: Best place to inject water/meth
Anyone???
Old 10-18-2011, 09:07 AM   #3
blownzoom440
blownzoom440's Avatar
you provide fuel not cfm with injection and in turn change carb jetting to adjust to it.
http://www.youtube.com/watch?v=UPeXFz7U7R8
Victor alum wedge heads.
A/W intercooled,race gas.
Koleno perf race block cross bolt mains.
firecore50 plug wires,Caltrac's
blownzoom440 is offline   Reply With Quote
Old 10-18-2011, 02:36 PM   #4
Wayne In NZ
Pre-Staged
Thanks for your reply.
I am currently injecting 650cc/minute of 50/50 water/meth into the top of the blower but am only making 8Hp extra.
355 sbc at 8.5:1 Comp ratio
Forged pistons, hyd lifters, 1.6 roller rockers
B&M super street charger cam,
duration at 0.0065 lift: Intake 282 deg, Exhaust 292 deg, Overlap 59 deg.
duration at 0.050 lift: Intake 234 deg, Exhaust 244 deg, overlap 11 deg.
lift at cam: Intake 0.3254", Exhust 0.3400".
lift at cam: Intake 0.488", Exhaust 0.510".
Edelbrock Performer RPM heads, 64cc chambers.
MSD 6BTM ignition. 17deg at idle, 35deg total, all in by about 2400rpm
boost retard set to "0" when injecting on premium pump gas.
B&M 162 at 2.4:1 OD, making 6 psi, 8psi with water/meth through it
QFT 850 blower carb
Hooker super comp headers, twin 2.5" system. "x" pipe, Hooker Areochamber mufflers. turn downs before diff.
I have posted some dyno plots here. http://www.cardomain.com/ride/310662...evrolet-camaro
I am wondering if I am simlpy injecting at the wrong place or just not enough.
We noted the IAT without the injection it was 86C at max power and with the injection it was 49C.
Also at 5500rpm there was slight detonation.
We were unable to add any timing, which is what I was expecting to do.... more timing.....more hp.
Any help would be gratly appreeciated.
I have a meet at the end of this month and was hoping to have this well sorted before then.
Wayne
Old 10-18-2011, 03:41 PM   #5
Mr.Chev
Mr.Chev's Avatar
my 350 picked up 50 hp over pump vs pump and meth/water, but only 10 more than race fuel vs pump and meth/water.
I make about 14.5 pounds of boost with no detonation on pump gas, I also run the btm and run 36 total with a third of a degree being pulled per pound.
As for the amount of meth/water, I cant say how much I used the big jets supplied and the controller varies the amount according to the boost, its on at 4 pounds and full spray by 8. I was happy as I can run pump fuel with a race fuel tune. so are you saying with the pump gas and meth you cannot run a race gas tune?
or did you just go from race fuel to pump meth? and keep the tune the same, or was it always pump gas?, on the dyno I had to go down one jet size in the primaries to achieve the same a/f as before the meth. also mine is spayed under the carbs.
Mr.Chev is online now   Reply With Quote
Old 10-18-2011, 10:34 PM   #6
jstahemi
Garage
Anybody have tenp sensors for IAT above the blower and in the intake manifofd??Is it directionally proportional when the water / meth is injected.Would it pay to use a perimiter plate for thr meth injection??
jstahemi is offline   Reply With Quote
Old 10-18-2011, 11:29 PM   #7
MYTURN
Member
Pullin gears
MYTURN's Avatar
u should pull some timing out still. maybe half per pound. you could spark knocking
i would say if you didnt have meth working you would have detonated and blew head gasket
MYTURN is offline   Reply With Quote
Old 10-19-2011, 03:03 AM   #8
Wayne In NZ
Pre-Staged
Thanks for your replies guys.
We had a structured day.
base run on pump gas.
pump gas plus water only
pump gas plus water/meth 50/50
A few of the dyno plots are here...... http://www.cardomain.com/ride/310662...evrolet-camaro
I wonder if it is the plugs complaining. they are set to 0.035" gap, dont aske me the heat range but they looked ok.
We also reduced the size of the secondaries to lean it up a bit as the AFR was too fat with the water/meth.
Still puzzled
darined fuel tank and did avgas only
then avgas plus water/meth 50/50
Old 10-25-2011, 02:53 AM   #9
MYTURN
Member
Pullin gears
MYTURN's Avatar
how good is the meth spraying. if the pressure is down, for some reason, on meth pump it might not have a good pattern.
Old 10-25-2011, 11:50 AM   #10
camaroman7d
Member
Pullin gears
camaroman7d's Avatar
Are you injecting it through the carb? I inject mine under the carb and above the blower. I was told this was the ideal place. I don't have any dyno sheets testing one way against another.
Royce (NO XQSSS) Bradley
1961 Buick Skylark
1970 Nova
www.facebook.com/driveyourjunk
http://www.youtube.com/watch?v=DSLsGgDjFXE
camaroman7d is offline   Reply With Quote
Old 10-27-2011, 02:30 AM   #11
Wayne In NZ
Pre-Staged
Hi guys
Thanks again for all your input.
I have tapped the jets into the top of the blower housing. One just in front of the carb adaptor and one just behind it.
I am using an Aquamist system which maintains 160psi at all times and if there is a flow problem I get a failsafe warning si I dont believe it is a flow failure problem.
I can only guess that I either need to go 100% methanol or 100% water or stick more in at 50/50.
I am guessing though, someone here should know what works and what doesnt.
Cheers
Old 10-27-2011, 03:38 AM   #12
beno598
Pre-Staged
beno598's Avatar
50/50 works best for me
beno598 is offline   Reply With Quote
Old 10-27-2011, 11:29 AM   #13
camaroman7d
Member
Pullin gears
I run 50/50 as well. I have 4 jets, two under the rear carb and two under the front. I machined my carb adapter plate and installed the nozzles on each side. The kit I have is an old AIS (Alcohol Injection Systems). I run 12psi of boost on 91 octane and start spraying at 6psi. Like I said I have an old system so no controller, it's either on or off.
1961 Buick Skylark
1970 Nova
Old 10-27-2011, 01:20 PM   #14
Wayne In NZ
Pre-Staged
How much do you guys actually inject in a minute at full flow?
Cheers
Old 10-30-2011, 07:30 PM   #15
camaroman7d
Member
Pullin gears
I can't answer that. like I said my system is old with no controller, the pump comes on at 6psi and stay on until I am under 6psi of boost.
1961 Buick Skylark
1970 Nova
