Something's not right??? - Page 7 - Yellow Bullet Forums
Old 10-24-2011, 08:39 PM   #91
trmnatr
Butch
trmnatr's Avatar
Default Re: Something's not right???
If it is 68-72 Chevelle, the best place to mount the Holley Black Pump is behind the rear floor board. If you follow the from on the passenger side, there is a solid piece of frame you can mount it on, and the pump tucks up behind the right rear floor pan and bolts to the frame. It is lower than the tank and will gravity feed here
A big block Chevelle guy tried mounting it here where I did, and all has been fine for him just as it was for me. He went 11.60's, but he did have 3/8" hard line, -08AN is just a little bigger than 3/8" steel line
trmnatr is offline   Reply With Quote
Old 10-27-2011, 03:34 PM   #92
SB chevelle
SB chevelle's Avatar
Those pumps like to push fuel not pull it so they say to run a sump so that it doesn't have to suck through the stock outlet
SB chevelle is offline   Reply With Quote
Resources saved on this page: MySQL 1.18%
