15x12 on gbody? - Page 2 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 10-14-2011, 07:08 PM   #16
CB Motorsports
Default Re: 15x12 on gbody?
I'll be putting 12's under my Monte, I moved my frame rails in 3" per side,followed by a big notch. Gained 4 5/16" on each side.
CB Motorsports is offline   Reply With Quote
Old 10-14-2011, 11:31 PM   #17
78buickregal
www.ULTRA-CARBON.com
78buickregal's Avatar
Quote:
Originally Posted by 7secondmalibu View Post
Did it in person. That's how I got my car to sit so low with 315's. Of course mine are on 10's and not 12's, but I did push out the quarter panel.
I got my 315s to fit on a 10 inch rim without spreading the rear quarters. Just a max notch and minitub, but it did rub the inner lip of the fender when making a tight turn. And the car was low. Not quite as low as yours, I bet, but it was nowhere near stock height. 15x12 definitely wouldn't have worked on my car.
Carbon Fiber Malibu Trunk Lid Video... http://www.youtube.com/watch?v=mC-1T...ature=youtu.be
Carbon Fiber goodies for your race car!
78buickregal is offline   Reply With Quote
Old 10-14-2011, 11:59 PM   #18
SS_Sean
SS_Sean's Avatar
http://www.yellowbullet.com/forum/sh...ad.php?t=96199
1978 Chevy Malibu
540, Rons Toilet, BTE PG
Under construction, 25.5B/backhalf
Thanks to:
www.robeckcustomfabrication.com
www.killerrons.com
www.cachassisworks.com
www.trzmotorsports.com
SS_Sean is offline   Reply With Quote
Old 10-15-2011, 12:18 AM   #19
5-door
Member
Pullin gears
5-door's Avatar
Quote:
Originally Posted by Jim Craig View Post
I've got 15 x 12's with 315's on my '83 Cutlass -- mini-tubbed and a little notch.
I can believe that on a Cutlass. Your quarters don't flare in like a Malibu does. I know for a fact that a 15 x 12 rim and a 315 tire won't fit a Malibu, even with a max frame notch.
John
www.jtraceshop.com
5-door is offline   Reply With Quote
Old 03-26-2012, 07:49 PM   #20
cornfeed
Spooled up
Quote:
But it will fit a regal I know and you'll see this year on spring street lol
cornfeed is offline   Reply With Quote
Old 03-28-2012, 03:03 PM   #21
maliburick
Member
Pullin gears
maliburick's Avatar
15 x 12 is impossible to fit on a G-body, unless you move the frame rail in, or tub it. Even a full notch is not enough. A 15 x 12 might fit with a 275 radial, but anything bigger is impossible on a 15 x 12 rim.
ITS VERY POSSIBLE. MY BUDDY HAS A 15X12 ON A 315 DR ON HIS MALIBU AND STILL HAS PART OF THE STOCK RAIL LEFT. THE TUBE DID HAVE TO BE EXTENDED THO.
maliburick is offline   Reply With Quote
Old 03-28-2012, 04:56 PM   #22
DOTracer
DOTracer's Avatar
Quote:
I'd have to see it to believe it. A 315 M/T on a 12" rim measures 14" through the section. My car is max notched to where only the inside skin is left. I have barely 14 1/2" from the quarter panel (lip completely gone) to the frame. 315 on a 10" rim is as tight as I would feel comfortable running, but that's with the tire tucked under the car, not the car sitting up and the tire direclty under the wheel lip.
DOTracer is offline   Reply With Quote
Old 03-28-2012, 07:27 PM   #23
maliburick
Member
Pullin gears
maliburick's Avatar
CHECK OUT SCOTT BITZER'S NEXT TIME U SEE IT.
Old 03-28-2012, 07:29 PM   #24
DOTracer
DOTracer's Avatar
Pretty sure they moved the frame rails on his car.
Old 03-28-2012, 09:45 PM   #25
HardonParts
Chinese buffet destroyer
HardonParts's Avatar
do you have any more info on how you pushed the 1/4 out with a jack? i'd like to do that with mine. i run 29.5x10.5 on weld pro star with 15x10 with 6.5 bs on a stock length 12 bolt. i need to trim the lip on the wheel well,it rubs during hard turns. how much extra room can you get by pushing out the 1/4? i need to do some body work on mine so i dont mind if its dented slightly.
1978 Chevy Malibu BBC, Nitrous, 25.5 X275 Drag Radial
Motor City Outlaws c.c
HardonParts is offline   Reply With Quote
Old 03-28-2012, 10:01 PM   #26
excelerater1
Senor Frog
excelerater1's Avatar
cheaters,12s
excelerater1 is offline   Reply With Quote
Old 03-29-2012, 11:18 AM   #27
TRZ Mike
Moderator
Launchin
Quote:
Originally Posted by excelerater1 View Post
cheaters,12s
^^Truth!
Unless the car is a 4x4, Ive never seen one sitting with the tire tucked in the wheel well on 12" wheels with the frame in the stock location.
Mike Braasch
ph. 407-933-7385 fax 407-933-7589
Dealers for: Strange, QA-1, AFCO, Santhuff, JRI Shocks, Racecraft Inc., Spaghetti Menders...
Like our page on Facebook for Product Updates, New Releases and Announcements!
TRZ Mike is offline   Reply With Quote
Old 03-30-2012, 08:04 PM   #28
maliburick
Member
Pullin gears
maliburick's Avatar
Quote:
No he didn't
Old 03-30-2012, 08:15 PM   #29
DOTracer
DOTracer's Avatar
No he didn't
OK, What ever you say. He's got the only Malibu on the planet that can fit a 12" wheel with a 315 (14"+ section width) with stock location inner frame rail.
Have him bring it by my shop and well put his and mine up on stands, take the back wheels off and take measurements.
I'm serious. He knows how to get here since it's my frame that's under his car (at least the back section prior to the wreck).
Resources saved on this page: MySQL 1.06%
