SBC Cam Recomendation - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain - LGM Racing and Development
Old 10-11-2011, 07:11 AM   #1
MelloYello
Launchin
MelloYello's Avatar
Default SBC Cam Recomendation
Here it goes...
SBC
4.040 357ci
Dart Pro 1 Platinum 215 w/some mild port work.
2925 s. victor with allot of plenum work.
12.6 compression.
5000rpm converter.
4.86 gear.
3400lbs.
What n/a solid roller would fit this build?
trmnatr need not reply.
Thanks!
Don't tell me what your gonna do...Tell me what you've done!
MelloYello is offline   Reply With Quote
Old 10-11-2011, 09:36 AM   #2
CROWER
CROWER's Avatar
Default Re: SBC Cam Recomendation
lol... i like your begining and i like you already....
does it run yet ? or new build never fired it yet
CROWER is offline   Reply With Quote
Old 10-11-2011, 10:32 AM   #3
MelloYello
Launchin
MelloYello's Avatar
No sense in beating around the bush
It is a new build sitting on the stand but never fired.
The converter is an untested piece as well. Its supposed to be 4800-5200. Actual car weight should be closer to 3200lbs with my fat ass on board.
Thanks!
Old 10-11-2011, 11:32 AM   #4
CROWER
CROWER's Avatar
3 spd ? or pg ... titanium valves or steel
Old 10-11-2011, 01:03 PM   #5
trmnatr
Butch
trmnatr's Avatar
307/313 @.020"
278/284 @.050"
199/204 @.200"
.723"/.678"
106 lobe center
.020"/.022" lash
With correct clearances, keep the valve train stable with a stud girdle or shaft mounts and your close to the 10.0 mark in that combo. That combo as cast will run 10's and should sixty foot high 1.3's to low 1.4's
trmnatr is offline   Reply With Quote
Old 10-11-2011, 01:57 PM   #6
MelloYello
Launchin
MelloYello's Avatar
Quote:
Th400 with steel valves. This is a street more strip orientated setup. 7500 rpm would be theoretical max rpm give or take a few 100.
Thanks!
Old 10-11-2011, 02:00 PM   #7
lun40119
I like IceCream
lun40119's Avatar
Quote:
Originally Posted by trmnatr View Post
307/313 @.020"
278/284 @.050"
199/204 @.200"
.723"/.678"
106 lobe center
.020"/.022" lash
Oooof............the cam posted above is WAY too long for your combo!!! Do not put a 278 @ .050 lobe in a 357 and expect it to move a 3400lb beast to 330'. It isn't going to happen!!!
Jake
Team Clueless
Optimize the Compromise...
Quote:
Originally Posted by Chris Uratchko View Post
Hell no, big blocks are for dump trucks!!!
lun40119 is offline   Reply With Quote
Old 10-11-2011, 02:02 PM   #8
lun40119
I like IceCream
lun40119's Avatar
Quote:
Thanks!
I am 272 at .050 on a 402" 23 head deal and it peaks at 8100-8200. Beware of what you read on the net dude.......especially from guys that don't even race!!!
Jake
Team Clueless
Old 10-11-2011, 02:25 PM   #9
jdbss85
Launchin
Quote:
UH JAKE................And your lift isssssssssss ????
jdbss85 is offline   Reply With Quote
Old 10-11-2011, 02:33 PM   #10
lun40119
I like IceCream
lun40119's Avatar
Quote:
.468.......
Jake
Team Clueless
Old 10-11-2011, 04:16 PM   #11
MelloYello
Launchin
MelloYello's Avatar
I agree. It was disregarded.
The cam that's currently installed in the motor is 266/274 @.050 -.640/.640-108.
Its what I had sitting collecting dust so I stabbed it in. I am now questioning it before the motor gets installed.
Thanks!
Old 10-11-2011, 05:58 PM   #12
1997bird
Member
Pullin gears
1997bird's Avatar
Here it goes...
SBC
4.040 357ci
12.6 compression.
5000rpm converter.
4.86 gear.
3400lbs.
Thanks!
Are you looking for a off of the shelf grind cam or a custom? Also what do you have for valve springs on these heads?
1997bird is offline   Reply With Quote
Old 10-11-2011, 07:37 PM   #13
MCEcomp
Member
Pullin gears
MCEcomp's Avatar
Thats a blanket statement jake.....my car is 3400lb with a 358chev and sportsman 2 heads and 278@.050
1.37to 60' 9.90@134
MCEcomp is offline   Reply With Quote
Old 10-11-2011, 08:02 PM   #14
lun40119
I like IceCream
lun40119's Avatar
What weight? How much compression?
Jake
Team Clueless
Old 10-11-2011, 08:03 PM   #15
MelloYello
Launchin
MelloYello's Avatar
Quote:
If an off the shelf grind fits that works for me but a custom deal is fine too.
Springs are Comp 954, they lists them as 210 @ 1.90/ 524 @ 1.25 coil bind 1.17. They are setup @ 1.90 with a Ti retainer.
Thanks!
