GM TECHS BUICK RAINIER - Yellow Bullet Forums
Old 10-03-2011, 03:47 PM   #1
AssHat
Spooled up
AssHat's Avatar
Default GM TECHS BUICK RAINIER
I'm working on a 05 Buick Rainier awd. The problem is it feels like it has a spool in it ,but when I pulled the diff. cover every thing looks fine and both wheels turn independent of each other. Another shop quoted a rear. I'm not so sure. Any ideas?
AssHat is offline   Reply With Quote
Old 10-03-2011, 03:55 PM   #2
369dragster
Member
Pullin gears
369dragster's Avatar
Default Re: GM TECHS BUICK RAINIER
Are the tires all the same size?
Ken
369dragster is offline   Reply With Quote
Old 10-03-2011, 03:55 PM   #3
61-4SPEED
61-4SPEED's Avatar
well asshat, spend 3 days with a 20# sledge beating the rear rotors off and take all the emergency brake shit off and throw it in the fucking garbage... just a thought
91 VETTE FOR SALE
THANKS TO:
JK CUSTOM FABRICATION
NEW EAGLE PA
61-4SPEED is offline   Reply With Quote
Old 10-03-2011, 03:56 PM   #4
jamie2028
Launchin
jamie2028's Avatar
if its awd check for matching size and brand tires. i have seen some of them with same size but 2 of one brand and 2 of another brand and it makes the tcase bind which makes it feel as if the rearend is a locked diff. you can measure the rollout(circ) of the tires and see the difference . awd tires must be same size, same brand and preferably same tread depth, have seen 2 new and 2old do the same thing
jamie2028 is offline   Reply With Quote
Old 10-03-2011, 04:02 PM   #5
AssHat
Spooled up
AssHat's Avatar
Looks like 4 new firestones all the same size.
Old 10-03-2011, 04:19 PM   #6
MercilessMike
MercilessMike's Avatar
http://www.gminsidenews.com/forums/f...raining-68760/
http://townhall-talk.edmunds.com/dir...ew/.f0ff256/74
http://www.carcomplaints.com/Buick/R...ign_flaw.shtml
MercilessMike is offline   Reply With Quote
Old 10-03-2011, 04:25 PM   #7
malibuandy
Member
Pullin gears
malibuandy's Avatar
Check the front diff actuator - being stuck on, or the encoder motor on the transfer case for being in the wrong position. Changed a bunch of the encoder motors.
78 Malibu 355 th350 4.10's
OSCA 11.90 competitor
best pass 10.95@122 on 125hp NOS
If she's bored she should've been stroked.
malibuandy is offline   Reply With Quote
Old 10-03-2011, 04:36 PM   #8
AssHat
Spooled up
AssHat's Avatar
Thank you for the leeds. I will report back.
Old 10-03-2011, 04:38 PM   #9
spidergearsman
spidergearsman's Avatar
AWD ...the encoder turns on and off when you make turns , check for codes
spidergearsman is offline   Reply With Quote
Old 10-03-2011, 04:46 PM   #10
Rubbernuts
Launchin
Rubbernuts's Avatar
Quote:
Still measure the diameter of the tire, we have seen new tires and one be different measurement causing the issue. Just a thought.
X275 work in progress
408" 9.2 deck Vortech
Stay tuned
Rubbernuts is offline   Reply With Quote
Old 10-05-2011, 10:31 AM   #11
AssHat
Spooled up
AssHat's Avatar
Quote:
how do you check this?
Old 10-05-2011, 10:32 AM   #12
AssHat
Spooled up
AssHat's Avatar
There are no codes.
Old 10-20-2011, 08:39 AM   #13
AssHat
Spooled up
AssHat's Avatar
You got it thanks for the help.
