PG Case??? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 08-29-2011, 06:44 PM   #1
10.5 Olds
Member
Pullin gears
Default PG Case???
Currently have a stock case pg with a JW bell on it. I am looking at upgrading to a different case when trans is getting freshened. Any benefit with going to a 1 piece case? (Dedenbear/Reid) Or.......since I have the JW bell already.....just opt for the case available from JW,or ATI and reuse the bell? Any of these cases better than others? Also looks like I cannot use my bell on the ATI case unless I use an adapter ring.....correct?
Wisconsin's own "STROKER ACE"
THANKS TO- PETE "DA HUT" GILLIS
AND........ MIKE "The SENNSATION" SENN FOR HIS "SENNY SIDE UP" NITROUS TUNES
10.5 Olds is offline   Reply With Quote
Old 08-29-2011, 07:34 PM   #2
redvictor
from across the pond...
redvictor's Avatar
Garage
Default Re: PG Case???
Reid case if you want the best. JW fits JW,but i don't like the bell on the pump. Reid case bell is on it's own flange,not on the pump.
Gone from this place...
redvictor is offline   Reply With Quote
Old 08-30-2011, 08:21 PM   #3
10.5 Olds
Member
Pullin gears
1pc case over any of the other 2pc units???
Resources saved on this page: MySQL 1.15%
