Dexron VI transmission fluid - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 08-26-2011, 10:50 PM   #1
mikep379
Spooled up
Default Dexron VI transmission fluid
Can I still use the Dexron III transmission fluid instead of using the Dexron VI fluid.This is for a 2006 Chevy Monte Carlo with 3.5 V6 automatic.The Dexron VI is harder to find and is double the price of the Dexron III.I figured the fluids were still about the same just a GM sales tactic but wanted to be sure.Thanks
mikep379 is offline   Reply With Quote
Old 08-27-2011, 12:22 AM   #2
doublesperformance
Member
Pullin gears
doublesperformance's Avatar
Default Re: Dexron VI transmission fluid
Every Walmart and Autozone I've been to keeps the Dexron VI in stock. Its a fully synthetic fluid and that's why its more expensive. I'd put the recommended fluid back in the car. Its gonna be less than $50 to change the fluid and filter if you do it yourself
doublesperformance is offline   Reply With Quote
Old 08-27-2011, 07:35 PM   #3
E.R. Racing
E.R. Racing's Avatar
Quote:
Yes you can, but it may shift a little firmer due to the difference in fluid, as the transmission is calibrated to the dextron 6. Won't harm a thing, as long as you use a quality fluid.
I support our troops, do you?
E.R. Racing is offline   Reply With Quote
Old 08-27-2011, 10:42 PM   #4
LTLHOMER
LTLHOMER's Avatar
Quote:
Dex VI is not a full synthetic.
'98 Mustang
5.7 HEMI, Work Turbochargers, Big Stuff 3
Hyperaktive Performance Solutions
LTLHOMER is offline   Reply With Quote
Resources saved on this page: MySQL 1.14%
