Timing retarding with locked out dist. - Page 8 - Yellow Bullet Forums
Old 11-03-2011, 08:14 PM   #106
holyshift
holyshift's Avatar
Default Re: Timing retarding with locked out dist.
Weird,ok so I charged the battery cause while I was trying to start it it was struggling,also removed the passenger seat again to check the wires to make sure I didn't pinch anything. Everything looked good,So i threw the charger on and ate dinner,come.back out,turn the key and it kind of kicked back,so I moved the dizzy and boom it fired up. Checked the timing,runs great. I also just moved the battery out back too when I moved my electronics,so Iam assuming low voltage at the battery now affects things worse as compared to before with all my electronics up front. Again sorry to high jack but thought this would be a good thread to post this in.
Long rod 308,all forged,4r70w with Freak Show Converter,76mm VSracing.com turbo,Steve Taylor PRC Carb.
Yea Dude Racing,Big Kid Racing
Best ET:10.75@123 1.44 60' on the sauce
Ride with me http://youtu.be/IxZnUVjoJbM
http://www.facebook.com/pages/Yea-Du...12933502113677
IBEW Local 129 Apprentice 4th year
holyshift is offline   Reply With Quote
Old 11-03-2011, 08:38 PM   #107
colormebad
Billy438Stroker
colormebad's Avatar
Msd couldnt even beleive it' but we already had 2 start retard boxes go bad and cause alot of these same problems...Ran fine hooked straight to ign box...Msd said they have never seen this...I told them they could have seen the boxes i fixed.....
colormebad is offline   Reply With Quote
Old 11-03-2011, 08:51 PM   #108
55sedan
55sedan's Avatar
Quote:
They kept my 3-stage retard box 3-4 weeks & tested it. Invoice said they ran it 8 hours at 4000 and found no problems.
Got it back - same crap.
BBC P/Glide 12 Bolt on Leafs
55sedan is offline   Reply With Quote
Old 11-03-2011, 08:53 PM   #109
55sedan
55sedan's Avatar
holyshift
Hope you find your problem.
Did you run the floating ground?
Old 11-04-2011, 07:02 AM   #110
holyshift
holyshift's Avatar
Yes,its fine now,I dunno what happened,I think the low battery voltage was playing havoc on me,lol. Runs like a champ!
Old 11-04-2011, 07:05 AM   #111
holyshift
holyshift's Avatar
Oh my ground goes back to my battery,along with the main power wire.
Old 11-05-2011, 11:57 AM   #112
Horndog
Quote:
This is good.
What size cable are you running from the battery to the starter?
And are are you running the same size ground cable from the batt to the block?
Jim Horner
" ...oh no, what the fuck was that?
...the motor ... we've thrown a rod.
...is that serious?
...yup."
Horndog is offline   Reply With Quote
Old 11-05-2011, 11:58 AM   #113
Horndog
55, have you been able to solve your "missing" issue yet?
Jim Horner
...is that serious?
...yup."
Old 11-05-2011, 09:10 PM   #114
Mattsv8_03
Member
Pullin gears
Mattsv8_03's Avatar
so did you try a good coil yet. i still think that power tower has no place with a digi box. any blue hvc type coil can keep up just fine
My 82 s10 lb 8.89 at 152.78 on pump E85. 15lbs boost 357"sbc 8.4:1
89 s10 blazer 9.90 nitrous 335" sbc 12.4:1 e85 homemade 750 225 shot
2001 z28 camaro hooker lt ofy flowmaster slp lid bellows. Awaiting the turbo kit I built for it that keeps ac and stock rad location.
2001 tahoe bone stock
1997 gmc yukon 2.5" lift 285/75 tires trailer puller.
Mattsv8_03 is offline   Reply With Quote
Old 11-05-2011, 11:10 PM   #115
55sedan
55sedan's Avatar
Quote:
Yes & No --------- The missing seems to be going hand & hand with the retarding issue.
As it is right now, timing is locked at 36* Still retarding 5*-6* when throttled, still missing going down track.
Took it to "test & tune" last Tuesday night im Byram, MS. (track is only 500' long, but good for tuning)
Made 3 passes, all missing going down track, timing at 36*
5.33 @ 97 w/1.45 60'
5.32 @ 97 w/1.45 60'
5.31 @ 97 w/1.45 60'
Bumped timing up to 41* to compensate for 5* retard.
Went 5.27 @ 98mph w/1.422 60'. Never skipped a beat. This is the best 60' ever in this car.
Also, when timing was at 36* it was hard to crank, kicking back and laboring.
At 41* it starts no problem, never kicks back, doesnt labor, just spins over a split second and starts right up.
Im on a job in New Mexico right now. When I get home I got an "adapt-a-cap" and adjustable rotor cap for it to try.
Also gonna ckeck the green, purple, orange, & black ign wire relationships.
Old 11-05-2011, 11:19 PM   #116
55sedan
55sedan's Avatar
Quote:
Sorry --- I thought you were referring to "awake1630" with the yellow camaro.
No i havent tried another coil yet. But I didnt think my box was digital. I may be wrong. Its a 6AL2 with built in 2-step & rev limiter.
As far as I know, its not a digital box. Ill get on MSD's website and ck it out though.
Old 11-06-2011, 02:42 PM   #117
raceadodge
raceadodge's Avatar
Yes a 6AL-2 is digital box.
raceadodge is offline   Reply With Quote
Old 11-08-2011, 07:54 PM   #118
55sedan
55sedan's Avatar
The 6AL-2 that I have has the rotary dials for 2-step and rev-limit.
Did see one on their web-site that was a "6AL-2 Digital" but it is diff from mine.
Are they both digital boxes?????
Cant remember, but I think it was a MSD tech that told me what coil to use with my box ???????
Old 11-08-2011, 08:52 PM   #119
raceadodge
raceadodge's Avatar
BrandMSD IgnitionManufacturer's Part Number6421Part TypeIgnition BoxesProduct LineMSD 6AL-2 Ignition BoxesSummit Racing Part NumberMSD-6421UPC085132064212Ignition Box OutputCapacitive dischargeCircuitryDigitalRev LimiterYesTiming RetardNoneData AcquisitionNoCD Voltage Output to Coil535 VSpark Output (millijoules)135 MillijoulesMinimum Operating Voltage10 VMaximum Operating Voltage18 VIgnition Box ColorRedCoil IncludedNoWarranty1-yearQuantitySold individually.NotesVibration mounts included.
Old 11-08-2011, 09:20 PM   #120
Mattsv8_03
Member
Pullin gears
Mattsv8_03's Avatar
pullthe tower off the coil. look for corrosion on the ground wrap at the bottom. yes the tower pulls out. i deff say its the coil oil filled round can coils just cant keep up with the newer boxes.
