Timing retarding with locked out dist. - Page 6 - Yellow Bullet Forums
Old 10-26-2011, 10:49 PM   #76
WeDgiE
WeDgiE's Avatar
Default Re: Timing retarding with locked out dist.
Quote:
Originally Posted by awake1630 View Post
thats the new box right?
sorry this is the one I have
http://www.summitracing.com/parts/MSD-6520/
WeDgiE is offline   Reply With Quote
Old 10-26-2011, 10:50 PM   #77
awake1630
Member
Pullin gears
awake1630's Avatar
i am wanting to mount my coil and box in the glove box. i hate the way the firewall looks with things on it. Trying to keep it clean looking.
Now what wires should never be ran near each other?
The box is a new style MSD 6A Digital and a blaster SS coil.
Here is a pic of where the setup is gonna be.
http://i1217.photobucket.com/albums/...0/IMG_0231.jpg
1969 Camaro
10.83 @ 123.33
1.53 - 60 foot
SBC
Brodix track 1 2.08/1.60
Ford Aod
4.33 gears
4 wheel Disc brakes
E85
awake1630 is offline   Reply With Quote
Old 10-26-2011, 10:52 PM   #78
WeDgiE
WeDgiE's Avatar
Quote:
Originally Posted by 55sedan View Post
Am I reading this right, ----------- You put in a diff type of 6al box and kept the 3-stage retard box,
So your problem was the 6al2 box?
got rid of the the stage 3 retard box all together! I have a new ignition box all together now! the old box worked fine without the retard on it.
Old 10-26-2011, 10:53 PM   #79
awake1630
Member
Pullin gears
awake1630's Avatar
1969 Camaro
10.83 @ 123.33
1.53 - 60 foot
SBC
Ford Aod
4.33 gears
4 wheel Disc brakes
E85
Old 10-26-2011, 10:57 PM   #80
55sedan
55sedan's Avatar
The way I understand it, the MSD wire (orange & black 2-wire harness that actually goes from box to dizzy) should not be close to the coil wire or any 12v power wire.
BBC P/Glide 12 Bolt on Leafs
55sedan is offline   Reply With Quote
Old 10-26-2011, 11:03 PM   #81
55sedan
55sedan's Avatar
Quote:
OK thanks. -----------Yeah I did away with my 3-stage retard also. There was no doubt in my mind something was wrong with that box.
My only issue now is it retards about 5* when reving. If I add the extra 5* to the timing, its fine.
Old 10-26-2011, 11:07 PM   #82
awake1630
Member
Pullin gears
awake1630's Avatar
thats strange that MSD puts the 12V power wire and Pos and Neg wires right next to that Black/orange and black/purple harness.
1969 Camaro
10.83 @ 123.33
1.53 - 60 foot
SBC
Ford Aod
4.33 gears
4 wheel Disc brakes
E85
Old 10-27-2011, 12:40 PM   #83
55sedan
55sedan's Avatar
Yeah, Im sure the coil wire affects it more than a 12v power wire.
Doesnt hurt to be on the safe side though.
Old 10-28-2011, 10:45 AM   #84
twobad
Member
Pullin gears
twobad's Avatar
if switching the wires(pick up) made it not start at all that may be a indication of a problem-bc base timing shouldnt change when reversednly when rpms increase.at least thats the way mine worked when it was wired wrong. hopefully your new dist will cure it g.l.
twobad is offline   Reply With Quote
Old 10-28-2011, 04:49 PM   #85
yeti
At the distributor connector, purple does not go to purple in the extension to the box. Distributor wires are purple and orange. MSD wire harness is purple and green. Distributor purple goes to green and distributor orange goes to purple in the MSD harness. Purple does not go to purple.
yeti is offline   Reply With Quote
Old 10-28-2011, 08:05 PM   #86
awake1630
Member
Pullin gears
awake1630's Avatar
on a blaster ss coil. Is it possible for the (+ -) studs with wires from the msd box;
Is it possible form the to arc if they are to close to something metal?
What distance should it be away from anything?
1969 Camaro
10.83 @ 123.33
1.53 - 60 foot
SBC
Ford Aod
4.33 gears
4 wheel Disc brakes
E85
Old 10-28-2011, 09:50 PM   #87
youngengines
youngengines's Avatar
Quote:
I was working at a engine shop a few years ago. We did a hooters pro cup engine and it came back with burnt pistons. We put a couple pistons in it , dynoed it and it came back again with burnt pistons. We found out they had been through a couple other engine builders before us with the same problem. We told them to put the engine in the car and bring it to the shop before firing it. (after more pistons and dynoing). They brought the car up and it kicked back when trying to fire it. We checked and the wires on the MSD dist were backwards. We switched them and it fired up fine. Hard to believe a hooters pro cup team didnt have anyone on the crew that could check timing isnt it?
youngengines is offline   Reply With Quote
Old 10-29-2011, 07:50 AM   #88
barnym17
If you ever worked with some you would believe it .
barnym17 is offline   Reply With Quote
Old 10-29-2011, 11:02 AM   #89
Mattsv8_03
Member
Pullin gears
Mattsv8_03's Avatar
hey can u try one thing for me? ditch the damn power tower blaster 3 coil. and get a hvc or hvc blue coil these are what should be used with digital boxes. please try it.
My 82 s10 lb 8.89 at 152.78 on pump E85. 15lbs boost 357"sbc 8.4:1
89 s10 blazer 9.90 nitrous 335" sbc 12.4:1 e85 homemade 750 225 shot
2001 z28 camaro hooker lt ofy flowmaster slp lid bellows. Awaiting the turbo kit I built for it that keeps ac and stock rad location.
2001 tahoe bone stock
1997 gmc yukon 2.5" lift 285/75 tires trailer puller.
Mattsv8_03 is offline   Reply With Quote
Old 10-29-2011, 11:04 AM   #90
Mattsv8_03
Member
Pullin gears
Mattsv8_03's Avatar
http://www.jegs.com/i/MSD-Ignition/1...oductId=747810
this is the one i use with my sbc turbo motor and its a flawless match to a digital box.
i dont think the oil filled round coils can keep up with a digital box. check the specs for yours against this one.
