ported victor jr's or afr 205's - Yellow Bullet Forums
Old 08-10-2011, 05:07 AM   #1
lxteasy
Spooled up
Default ported victor jr's or afr 205's
Which is a better route to take on my combo. I have a 13.5 to 1 357w that will be on the jug. Should i send my victor jrs to tea for there cnc port and valve job or buy afr 205's?.
lxteasy is offline   Reply With Quote
Old 08-10-2011, 06:42 AM   #2
Badboss351
Badboss351's Avatar
Default Re: ported victor jr's or afr 205's
Unless this is a high rpm screamer, you would be surprised how little work the jrs need to fit the bill. There is alot of info needed to make a better recommendation.
XSR built S/S 446" nitrous SBF
Dealer for:
Ultimate Converter Concepts
Baseline Susp.
CV Products/Xceldyne
many more.......
Badboss351 is offline   Reply With Quote
Old 08-10-2011, 07:03 AM   #3
lxteasy
Spooled up
I spin the motor to 7k. I will be spraying 200 to 300 shot through it. I run the victor jr intake, 950 prosytems carb. Motors in a foxbody with a c4 and 4:10 gears. Want to run 9.50's or faster with the setup. Thats why i want to get the heads done. Unless its possible with leaving them the way they come.
Old 08-10-2011, 08:50 AM   #4
Badboss351
Badboss351's Avatar
I'd do a nice bowl job, good vj, some port matching/plenum work on int., What are the cam specs? I did a similar setup for a local guy, but he has old school hps, and on 90 jet in plate he went mid nines.
Dealer for:
Baseline Susp.
many more.......
Old 08-10-2011, 10:15 AM   #5
lxteasy
Spooled up
valve lift .654 in/ex, and duration is .260 .272 @.050. 108 lobe seperation
Old 08-10-2011, 10:31 AM   #6
Sam Vincent
Sam Vincent's Avatar
they will do the job nicely ported. TEA has a very good cnc program for them. has a very strong exh port. great for nitrous
sponsors:
Nitrous Express, Diamond, JESEL, Marcella Manifolds, M/T, VP racing fuel, GRP, Bullet Cams, RacePak, Leashed Elect, ATI performance
Vincent Performance
Graham KY
270-977-1893
Dealer:
Diamond, Trend, TotalSeal, BulletCams, Morel, Jesel, Brodix, Moroso, Manton, GRP, Callies, PSI~PAC, Stef's, Nitrous Express, TrickFlow, TotalEngineAirflow, PTC converters, William's Perf, ProLite batt, UltraPro Machine, Danny Bee, ATI Perf, MOSER Engineering, Sonnax Industries, PST shafts...
Sam Vincent is offline   Reply With Quote
Resources saved on this page: MySQL 2.30%
