typical pushrod length on 9.5 factory block windsor? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain
Old 08-06-2011, 11:47 AM   #1
85gtnsc
Member
Pullin gears
85gtnsc's Avatar
Default typical pushrod length on 9.5 factory block windsor?
i know they vary, but what are most guys seeing for pushrod length on factory 351 blocks with aftermarket heads? mine came out to 8.000 and i am having rockers back off. i am told 8.200 to 8.250 is about normal? we are rechecking my length today and see what happens.
93Coupe-76mm Boss31
85gtnsc is offline   Reply With Quote
Old 08-06-2011, 03:55 PM   #2
Buckeye Rich
Spooled up
Default Re: typical pushrod length on 9.5 factory block windsor?
On my 95 f4 block, with twisted wedge heads, I'm at 8.050 length pushrods.
Buckeye Rich is offline   Reply With Quote
Old 08-10-2011, 09:09 AM   #3
CROWER
CROWER's Avatar
everyones rockers , and heads can vary on this length, put the roller in the middle of valve at 1/2 lift and you gonna be fine , not unusual to use a 8.300"
CROWER is offline   Reply With Quote
Old 09-27-2011, 02:09 PM   #4
arringtonboys
Burnout box
arringtonboys's Avatar
I have high ports an have to use the clev std length 8.400..
81 mustang with 351w stroked to 418, old school high ports flowing 343-248@700 world intake with 1150, fogger/plate....pg 4200 nos coverter, car weights 2950 race ready 28/10.5.
arringtonboys is offline   Reply With Quote
Old 10-01-2011, 02:44 AM   #5
scott foxwell
scott foxwell's Avatar
Quote:
Induction Development Specialties
Retail/wholesale parts sales
Custom cams
423 391 7774
New Canfield BB Chevy heads now available!
Acts 2:38, the perfect answer to the perfect question.
scott foxwell is offline   Reply With Quote
Old 10-01-2011, 02:51 AM   #6
scott foxwell
96 block, zero deck, Dart 170 Pro1 with about .035 off the deck, .041 head gasket, 1.800 installed height, Scorpion 1.72 rockers, 8.35" with the mid lift method...that is, getting the rocker 90* to the valve at mid lift, regardless of where the roller tip is on the valve.
You really need to figure the proper length for your specific combination.
Custom cams
423 391 7774
Old 12-28-2011, 10:14 PM   #7
Cobra720
Burnout box
79 Block .010 in the hole, KC Brodix LH F 195 heads, retainer height 1.9, Scorpions 1.6 rockers, Comp hydraulic 832 lifter. Mid Lift method, pushrod length 8.550"
Cobra720 is offline   Reply With Quote
Resources saved on this page: MySQL 2.17%
