Need imput on G Body rear suspension setup - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Stock Suspension - TRZ Motorsports
Old 08-01-2011, 11:08 PM   #1
stevehemi
Member
Pullin gears
stevehemi's Avatar
Default Need imput on G Body rear suspension setup
1980 Malibu, Big Block, Th400, 9" Ford rear, 28" tall rear tire.
What do you think? I will try to answer any questions. Haven't had it to the track but on the street it doesn't seem to lift the front end like it should. Coil overs 130 lb springs in the rear and trick springs and 90/10's in the front.
When you got em by the balls their hearts and minds will follow.
stevehemi is offline   Reply With Quote
Old 08-02-2011, 08:49 AM   #2
TRZ Motorsports
Moderator
TRZ Motorsports's Avatar
Default Re: Need imput on G Body rear suspension setup
54% on the nose might be a little much unless you're on a perfect track. Can you move weight from the front to the back to get that more around 51% or so?
www.trzmotorsports.com
ph. 407-933-7385 fax 407-933-7589
Dealers for: Strange, QA1, AFCO, Menscer, Santhuff, Double AA, Racecraft, Moser, Baer, Spaghetti Menders, Tim McAmis, etc...
Friend us (TRZ Motorsports) on Facebook!
Follow us (t_r_z_motorsports) on Instagram!
TRZ Motorsports is offline   Reply With Quote
Old 08-27-2011, 08:55 AM   #3
stevehemi
Member
Pullin gears
stevehemi's Avatar
Ok, I didn't ignore your response. It took me this long to get a new set of heads. Swapping from steel to aluminum. I will re-weight when done. How do the angles on the control arms and such look?
Old 08-27-2011, 12:48 PM   #4
Drag Radial
SOFA KING WHAT?
Drag Radial's Avatar
How free does the front end move? What are the front springs rated at?
Quote:
Originally Posted by Monte Smith View Post
You CAN'T make rules based on what guys HAVE..........you have to make rules based on the POTENTIAL on any given combo. FAIR is next to impossible..............plus FAIR is a place where they have rides and pigs are judged, has nothing to do with racing..............LOL!!!
Monte Smith
Drag Radial is offline   Reply With Quote
Old 08-28-2011, 10:29 AM   #5
stevehemi
Member
Pullin gears
stevehemi's Avatar
Front end seems pretty free. Bushings move freely.
Shocks set at 90/10
COIL SPRING RATE (LBS./IN.) 250
Old 08-28-2011, 12:02 PM   #6
TRZ Motorsports
Moderator
What kind of power are you going to be making... just says BBC. Could be a high 9 sec. car, or a high 7 sec. car. Your power level will determine if your control arms geometry is fine. For a bunch of power (1000 hp or more), you might wanna lower the lower control arms on the frame side to get it closer to level or else it looks like it might hit the tire a little too hard.
Old 08-29-2011, 12:48 PM   #7
JeffMcKC
JeffMcKC's Avatar
When you say front bushings move easy its relitive. If you have stock rubber or simalar I would change that first
"IF IT DOES NOT HAVE A TRAILER HITCH ITS A RACE CAR!!!"
TRZ Dealer
2012 Winner SSSB/NA 9.67 @ 139MPH
2007 Winner SB/NA Drag Week 9.98
Thanks Curtis @ RFD Heads and Intakes
http://www.raceflowdevelopment.com/
JeffMcKC is offline   Reply With Quote
Old 08-29-2011, 10:46 PM   #8
stevehemi
Member
Pullin gears
stevehemi's Avatar
555 cu in, about 850 - 900 HP
Th-400 W/ brake, 5000 stall 9" converter
410 Gears - 9" , 295 55 15 M/T Drag radials
Yes Stock bushings in the front end,
Old 08-29-2011, 10:49 PM   #9
stevehemi
Member
Pullin gears
stevehemi's Avatar
As far as leveling out the lower control arms, that's not a problem. I put the brackets for that on the diff before I installed it.
Old 09-01-2011, 11:32 AM   #10
HEADSUP
TRUE STREET #441
HEADSUP's Avatar
You gotta get the bottom bar as parrallel to the ground as possible and get those Frt to rear weights closer. My Regal is 3264 and with me in it, the weights are 1634 frt and 1630 rear. We have 250 pounds of ballast in the car also.
HEADSUP is offline   Reply With Quote
Old 09-01-2011, 10:01 PM   #11
JeffMcKC
JeffMcKC's Avatar
I would put the Global west bushing kit in the front cheap and makes a ton of difference, your shock is being controld by the bushings up front
TRZ Dealer
Old 12-07-2011, 03:56 AM   #12
stevehemi
Member
Pullin gears
stevehemi's Avatar
SOOO. I absorbed every bodies advice. Swapped the steel heads out for aluminum. Figured I took 100 lbs off the frt end. Took it to the track track finally. With only 32 degrees of timing the results made me very happy.
!.34...60' 9.66 @137. Can't wait til spring to really dial it in.
PS Oh yeah BTW I have to get the chassis certed and a comp lic before I go back.
At least that's what the track requested...lol
Old 12-07-2011, 04:14 AM   #13
SS_Sean
SS_Sean's Avatar
Nice!
Did you re-weigh the car? What changes did you make to your rear control arms. 1.34 60' is respectable.
1978 Chevy Malibu
540, Rons Toilet, BTE PG, 25.5B/backhalf
8.89@150mph, 1.30 60'
SS_Sean is offline   Reply With Quote
Old 12-07-2011, 05:44 AM   #14
shagwag
Member
Pullin gears
shagwag's Avatar
Nice!
www.tntraceshop.com
1983 Malibu wagon
8.40@161
5.38@130
Small turbo 409sbc
shagwag is offline   Reply With Quote
Old 12-07-2011, 06:51 AM   #15
protobuild
protobuild's Avatar
Good info, I need to look over my set up again.
Old Crank Racing.
protobuild is offline   Reply With Quote
Resources saved on this page: MySQL 1.03%
