cam recommendation 410 SBC - Page 6 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Valvetrain
Closed Thread
Old 09-26-2011, 10:05 PM   #76
stealthmoderacing
stealthmoderacing's Avatar
Default Re: cam recommendation 410 SBC
the cam that came out of the motor when it supposedly made 660 on the dyno was comp cams 12-726-9
it does not say its a small base circle cam.
here is the link for the cam specs
http://www.compcams.com/Company/CC/c...?csid=322&sb=2
stealthmoderacing is offline
Old 09-26-2011, 11:26 PM   #77
CROWER
CROWER's Avatar
throw some calipers around it and see what lobe size you had in that shortblock then youll really know what it ran with.
CROWER is offline
Old 09-27-2011, 12:03 AM   #78
trmnatr
Butch
trmnatr's Avatar
Measure from the base circle to the peak of the lobe, then minus the lobe lift from that number to see what your base circle is/was
trmnatr is offline
Old 09-27-2011, 08:41 AM   #79
stealthmoderacing
I dont have the cam anymore, when i got the motor apart the cam had some spots in it i didn't like so i called the guy and he said send it back to him and he refunded some of my money.
Old 09-27-2011, 09:54 AM   #80
CROWER
CROWER's Avatar
some spots you didnt like hmmm .. call him up .. have him mic it.
CROWER is offline
Old 09-27-2011, 11:16 AM   #81
stealthmoderacing
it was discolored.... and the rear gear was missing a tooth he was running a front drive distributor. Can't i just call comp cams and have them mic one???
Old 09-27-2011, 11:30 AM   #82
stealthmoderacing
nevermind they said all of them are different
Old 09-27-2011, 01:27 PM   #83
trmnatr
Butch
trmnatr's Avatar
So what is the CURRENT combo? It has went a couple ways through the thread, what exactly is the plan at this moment so you can get more help
trmnatr is offline
Old 09-27-2011, 01:59 PM   #84
stealthmoderacing
to keep the heads i have
Old 09-27-2011, 03:13 PM   #85
cstraub
If we keep the OP's max rpm range cam would be:
800/720
283/281
109 Sep
If we turn the engine to 7000 rpm:
720/690
263/271
108
cstraub is offline
Old 09-27-2011, 03:17 PM   #86
stealthmoderacing
turning it to 7000 seems like a safer way to go correct??
Old 09-27-2011, 05:51 PM   #87
trmnatr
Butch
trmnatr's Avatar
ET Goals???
For 6500rpm I would use this, but shift 800-1200rpm over stall RPM
290/306 @.020"
260/268 @.050"
184/183 @.200"
.670"/.625"
106 lobe center
.960" base circle
.012"/.018" lash
This cam has been 8.40's at 1850 weight, with stud rockers and 5/16" pushrods. A good solid platform would gain no less than two tenths down the 1/4 mile
If you want to raise the RPM up a little in the lights to 7000rpm, but still shifting 800-1200rpm over the stall RPM go with the below camshaft
298/314 @.020"
268/276 @.050"
191/190 @.200"
.670"/.625"
106 lobe center
.960" base circle
.012"/.018" lash
You can go 1.5/1.6 rockers (.670"/.666"), or 1.6/1.6 rockers (.715"/.666"). If using the higher ratio rockers, that would be best.
96886-16 Crane 1.55" Springs
225 @2.000"
255 @1.950"
285 @1.900"
715 @1.250"
750 @1.200"
1.150" coil bind
652 pounds per inch spring rate
Set the seat pressure on the intake valves at 285 seat and 750 open as long as your using shaft mounted rocker arms and 1.6 ratio on the intake. Set the exhaust springs up at 255 seat and 685 open with 1.6 exhaust rockers.
After 20-25 passes, verify spring pressure and shim as needed to maintain this pressure above. You will see a 5 to 10 pound drop. I would also use a Ti Retainers, part number 99634-16 on the 10 Ti Retainers
trmnatr is offline
Old 09-27-2011, 06:12 PM   #88
trmnatr
Butch
trmnatr's Avatar
By the way, if you don't have lifters I would look at the Crane Ultra Pro lifters. I would use no less than a 3/8" .080" pushrod in there, The Crane's will do well. If you can fit 7/16" that would be better yet
One key thing is, make sure there is not excessive clearance where the pushrod passes through the head, so it doesn't have room to flex and cause valve train seperation aka lash up the ramp or over nose
trmnatr is offline
Old 09-28-2011, 02:44 AM   #89
1997bird
Member
Pullin gears
1997bird's Avatar
It all depends on what parts you used in your engine, but your parts will wear less than the same engine at 7500 rpm or 8000 rpm. Just depends on what your goals are for the car to run in the 1/8 or 1/4 mile. This is my take on this engine combo that you have right now:
Crane lobes
299/302 @.020"
270/270 @.050"
191/193 @.200"
.723"/.714" w/1.6 rockers
.018"/.018" lash
110 LSA
108 ICL
Now then this cam is a slightly scaled down version from some Erson lobes that worked very well for my customer's 413 SBC dragster from earlier in the thread. However this Crane cam has more area @.200" than the Erson cam 191/193 vs. 189/191.
1997bird is offline
Old 09-28-2011, 08:48 AM   #90
stealthmoderacing
my car with me in it weighs 1730 on the nose race ready, with my canted valve dry sump motor. I figure my standard sbc is gonna be about 30lbs lighter. so 1700lbs race ready. in all honesty i dont really care what ET it runs aslong as its faster than 8.50 which i think is a pretty easy goal with my light car. In a perfect world i would like to be 5.0's and 8.0's on motor and 4.80' and on a 200 shot. so i guess that would be the goal
Closed Thread
Resources saved on this page: MySQL 0.99%
