gm L88 snowflake aluminum heads - Yellow Bullet Forums
Old 07-23-2011, 09:24 PM   #1
anorexicvega
anorexicvega's Avatar
Default gm L88 snowflake aluminum heads
seems these heads are prone to breaking the rocker arm stud boss. would shaft mounted rockers be less likely to break them?
anorexicvega is offline   Reply With Quote
Old 07-23-2011, 09:37 PM   #2
DewRonInc
DewRonInc's Avatar
Default Re: gm L88 snowflake aluminum heads
Yup.....
Fears Racing Components
DewRonInc is offline   Reply With Quote
Old 07-23-2011, 10:39 PM   #3
Outlaw Nova
Outlaw Nova's Avatar
why spend a grand for shaft mount rockers on a 50 year old casting?
Outlaw Nova is offline   Reply With Quote
Old 07-23-2011, 10:49 PM   #4
Pat McCarthy
Pat McCarthy's Avatar
Garage
Quote:
YEP just had a set of them in the shop was some of a better set of casting i have fixed i told the guy sell them to a resto guy and buy a new set of head .there getting big dollar for them heads. if not all screwed up most are. shaft rockers would help them from busting but then you may want to put better seats in the heads if that as not been done . then new heads then start looking better
IRISH DIPLOMACY... THE ABILITY TO TELL SOMEONE TO GO TO HELL ..SO THAT THEY LOOK FORWARD TO THE TRIP!! www.mccarthyperformance.com
Pat McCarthy is offline   Reply With Quote
Old 07-23-2011, 10:57 PM   #5
DewRonInc
DewRonInc's Avatar
X2, Yup again....
Old 07-23-2011, 11:02 PM   #6
anorexicvega
well...i kinda have to use them, or the heavy cast iron factory ones..........figured of the production heads...... they would be the best, and fit under stock height valvecovers
Old 07-23-2011, 11:04 PM   #7
anorexicvega
used shaft rockers are a grand?
Old 07-23-2011, 11:30 PM   #8
DewRonInc
DewRonInc's Avatar
Well, if you can find them to fit, no, that will be a large undertaking......
Old 07-23-2011, 11:33 PM   #9
anorexicvega
hmmm...that sucks.....i gotta use a production head......and cast iron heads dont help ya to stay on top of the mud
Old 07-23-2011, 11:37 PM   #10
Pat McCarthy
Garage
i used the T&D s but for lower dollar deal you may want to look at the PBM yellow tera setup spelling wrong ? someone may have used them on here i have not
Old 07-23-2011, 11:39 PM   #11
DewRonInc
DewRonInc's Avatar
Probe Industries or maybe Comp cams. The comp units are pretty good for the money, T&D would be my choice if Budget would allow.....
Old 07-24-2011, 12:01 AM   #12
anorexicvega
it possible for any small block combo with factory heads make more power then a 5?? ci bb with l88 heads?
Old 07-24-2011, 04:14 AM   #13
wizbang
wizbang's Avatar
If you use longer threaded studs , you won't break the exh stands off.
Even the T&D's will let the stands break off, if you don't use longer bolts. They have fixed the short bolt problem in the newer instl kits.
wizbang is offline   Reply With Quote
Old 07-24-2011, 09:17 AM   #14
mayhem
mayhem's Avatar
Define Factory heads.....
Can you use pro stock style stuff with GM part numbers?
You could get into a older olds or pontiac head at a fair price and make good/great power.
mayhem is offline   Reply With Quote
Old 07-24-2011, 09:54 AM   #15
anorexicvega
factory as in...they came installed on a car or truck from the factory......or copo
