351w engine builds - Page 2 - Yellow Bullet Forums
Old 08-21-2011, 11:10 AM   #16
Adios
QC for Molson Brewery
Adios's Avatar
Default Re: 351w engine builds
I got a 418 cid stroker(Eagle kit),10.5 to 1 comp,AFR 225's,solid roller (266/274 @.050 -673" lift ,super vic,pro systems 950,
2 inch Hooker super comp's...went 10.21@ 132 off the footbrake
Adios is offline   Reply With Quote
Old 08-21-2011, 11:29 AM   #17
1Clean89
1Clean89's Avatar
my plan are 408cid 13.5 to1 with vic,j heads, vic,jr intake , prosystems 950, 2'' kooks header (260/270@0.50 0.624 lift)hyd roller with a c4 .any guess were that is going to put me with a 3100lbs hatch . and 1 gun 250 shot ....
9.89@135.7 1.40 60Ft. 3340LBS
N/T nitrous passes
427 Ci SBF HYD Roller
Vic Jr heads
Vic Jr intake
IS plate
1Clean89 is offline   Reply With Quote
Old 08-21-2011, 11:44 AM   #18
Notchkid89
Notchkid89's Avatar
I'm building a 351w .030 dome pistons 12.5:1 victor Jr heads and intake, 576/600 lift cam, and I'll be using a horsepower innovations e85 850 base carb. Hooker super comp headers 1 7/8". Looking for a sick ass street toy..
FoxBodyFonz without the fox body haha
Notchkid89 is offline   Reply With Quote
Old 08-21-2011, 12:00 PM   #19
fastass83stang
Spooled up
fastass83stang's Avatar
351w .030 over stock block. stock crank, stock rods good bolts, forged pistons 10.2 to 1 compression. afr 185s ,550 lift hydo roller, motorsports intake on e85. 3600lbs 11.8-12.0 113-115 on motor 9.90s 133 on 250 shot all on e-85. its in the 69 mustang in signature. motor been in car 7 years.
fastass83stang is offline   Reply With Quote
Old 08-21-2011, 12:49 PM   #20
frdboy
Launchin
frdboy's Avatar
Here is my little street car motor
420 SBF 4.040x4.100
69 block Pro-Gram 4-bolt caps
Eagle crank and rods, Malhe pistons
12.7:1
Highports by Duane Busch
Harland Sharp Shafts
Bullet Solid Roller 267/275 .731 lift
Super victor
PRO-SYSTEMS E85 4150
Has went 9.82 so far thru the muffs running on DR's @ 3100 lbs
frdboy is offline   Reply With Quote
Old 08-21-2011, 01:01 PM   #21
deadman455
Pre-Staged
deadman455's Avatar
I got a d4 block,.40 over 11.1 comp. Vic Jr heads and intake Anderson n90 com, hs roller rockers, stock crank and rods a 750 proseries carb. Hoping for around 450 HP.and its going into a tr7 looking for high 10s.
deadman455 is offline   Reply With Quote
Old 08-21-2011, 06:44 PM   #22
slorob
svo w block. 4.135 bore, 4.100 stroke. 205cc tw's. 1 3/4" header, super vic port matched w/pro-systems carb. 10.3-1 compression, pump gas. 657 @ flywheel, going in my 86 stang.
slorob is offline   Reply With Quote
Old 08-22-2011, 11:39 AM   #23
SStrokerAce
SStrokerAce's Avatar
Got a stock block, 4" stroke 408W with some nasty 20°'s, a 2828 and a solid roller for a street car (was a race engine and he sold that car) that's going to make Yates stuff blush.... when it's done I'll put some pics of it up.
Bret
Prof Gordon Blair “Those engine developers who grossly exaggerate their engine’s power as evidence of their genius!” ARE IDIOTS
SStrokerAce is offline   Reply With Quote
Old 08-22-2011, 12:22 PM   #24
jjohnson
jjohnson's Avatar
Dart Block
Ohio Crank 4340 4" stroke
Oliver Billit 6.200 rods
J&E Custom nitrous pistons 14.1:1 comp
Windage Tray
Yates heads 390/270 flow @.600
Victory titanium valves, keepers and retainers
Full jesel j2k rocker set up
PSI springs
Bullet custom Cam under 280 @.050 and under .800 lift
Comp cams solid rollers
Trend custom 7/16 push rods
Edelbrock Y-351 yates intake (fully ported and matched to heads)
Single Dominator 1150 hp
MSD crank trigger and dizzy set up
Star machine complete vacuum pump kit
Fab Shop custom built headers 2", 2 1/8 to 2 1/4 steps with their 4" merge collectors
I know there is more but thats the bassics of how me make nearly 800 hp and 640 lb ft in N/A trim. We built it for a big hit of spray but Ive been running it on the motor for my license and to get used to it before we hit it.
"Greater love hath no man than this, that a man lay down his life for his friends" John 15:13.........The American Soldier!
Thanks to my sponsors:
Don West, www.westracingheads.com
ARC, www.autorod.net
AFCO Radiators, www.afabcorp.com
Josh, www.sweetsofas.com
victory 1 valves, www.titaniumvalve.com
The Fab shop custom headers, www.fabshopheaders.com
jjohnson is offline   Reply With Quote
Old 08-22-2011, 09:22 PM   #25
G-Code
Not Hillary 2016
G-Code's Avatar
The 418" Windsor I designed for my dad. He has a '35 Ford Sedan he is supposed to be putting it in:
10:1 compression, small hyd roller cam it made 525 hp and 525 lbs ft and was all done by 5,800. I only wish I had put a bigger cam in it.
G
Carpe Diem
58.3% of Statistics are made up.
Irony is wasted on the stupid.
G-Code is offline   Reply With Quote
Old 08-22-2011, 11:57 PM   #26
jjohnson
jjohnson's Avatar
^^^^^^^^^love the duel quad set up............ sweet!
Old 08-23-2011, 01:19 AM   #27
G-Code
Not Hillary 2016
G-Code's Avatar
Quote:
Info on it:
http://www.yellowbullet.com/forum/sh...uot%3B+Windsor
I'd sure like to twist it a bit harder. Couple things I'd sure like to try.
G-
Carpe Diem
Old 08-23-2011, 10:45 AM   #28
Chairmanx
Member
Pullin gears
Chairmanx's Avatar
Our new one for the Mustang. Bracket car/street car. Not a max build, but something we can make all the runs we want at our home track in Ubly.
Sunoco 110
351W dart block 9.5 Deck 460"
Callie crank 4.125
Eagle rods 6.300”
Diamond Pistons 4.155 11.2:1 comp
AFR 225 heads
Scorpion Roller Rockers
Comp Cam .696 in/683 exh .278@.050 110*
2924 Super Vic intake
Holley 1000 carb 84 sq jets
MSD AL6 34* Timing
660 HP@ 6700 575 trq@5200
Still looking at Header combos.
Milan, MI 1975
6.07@113 85 Roush power 2013
Chairmanx is offline   Reply With Quote
Old 08-23-2011, 11:22 AM   #29
ndmp40
Quote:
Sunoco 110
Callie crank 4.125
Eagle rods 6.300”
AFR 225 heads
MSD AL6 34* Timing
Wouldnt it be easier to put a head with the cfm capability to feed 460 inches on the motor and put a milder cam in it? Considering its a street car, that is.
If you were building a 460 inch BBC instead, wouldnt the smart money put more cylinder head on that motor?
I am not being critical, just wondering why a big inch motor would have such a small intake port head on it. Since it will be a street car, a bigger head and milder cam would make it more driveable and perform better overall. I see alot of big inch windsors with heads that would not be put on, say a BBC of similar size. Just thinkin.....
ndmp40 is online now   Reply With Quote
Old 08-23-2011, 11:25 AM   #30
Collinsautomotive
Becuase marketing literature from a few companies has people squarely convinced velocity is the only thing that matters in a cylinder head, and many companys "almost none" offer inline heads with the required volume and port hieght etc to build such inline heads.
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
