BBC 427 combos.. - Yellow Bullet Forums
Old 07-20-2011, 09:28 PM   #1
nosnerd
SomeWhat Jaded
nosnerd's Avatar
Default BBC 427 combos..
back in the day( the early/late 80s depending on your neck of the woods) the 427 was a popular combo...
what was your combo at the time and what did it do>>>???
am i showing my age here ??lol
you know-back when you ran a holley strip dominator or a team G with a CC290 (or CC310) crane stick and 4.88s
"IGNORANCE SHOULD BE FUCKIN' PAINFUL"
522/798hp + NOS/I.S plate
Doin' it on 315's at full weight, ladies
*ULTRA PERFORMANCE and FABRICATION *
www.DandDPerformance.ca
nosnerd is offline   Reply With Quote
Old 07-20-2011, 09:50 PM   #2
kwigracing
kwigracing's Avatar
Default Re: BBC 427 combos..
Ha, I had one, a destroked 454, but, it had 990's ,a Team G, 850 Holley and a Crane 660 something solid cam. Went 650's. Old Crane rockers and a stud girdle. 89 or so.
Ya gotta be in it, to win it.
Kenny
kwigracing is offline   Reply With Quote
Old 07-20-2011, 09:58 PM   #3
k.pascoe
Launchin
Not Mine, but back in the late '80s early '90s buddy of mine had a '68 Camaro with a L88 headed 427 with a 4 speed and a Dana. Simple ladder bars, and a cage; would go 10.20s when the trans would stay together. The sound of that engine at 8500rpms would make you almost cry. God that car was cool!!!
k.pascoe is offline   Reply With Quote
Old 07-20-2011, 10:00 PM   #4
Chris_69_SS
Launchin
Chris_69_SS's Avatar
cc 290 & 310 cams were (are) awesome performers.
Chris_69_SS is offline   Reply With Quote
Old 07-20-2011, 10:05 PM   #5
VegaEddie
VegaEddie's Avatar
Had a .060 over 427 in my Vega a few years ago. 1050 Dominator, Edelbrock 454R manifold, 990s, Lunati solid roller (was an alky cam that was a bit too big for the engine on gas), 13:1 pistons, 8" converter, glide, 4.88s on 14x32s at 3100lbs. Went 9.80s spinning it to 8200. Probably would have picked up a tenth or two with the right cam and a good set of oval ports.
VegaEddie is offline   Reply With Quote
Old 07-20-2011, 10:08 PM   #6
rodsnracecars
still have the 427 from mine pretty nice old setup In a 69 Chevelle it went 10.0s, would leave and carry the front tires up and out past the 60' unless you really leaned on it then the rear bumber was the limit, then the oil pan and headers. Ran it with a tunnel ram and 2 750s and then a good 1050 dominator. Need to freshin it up take a little compression out, and throw a fogger on it and run it on the street.
rodsnracecars is offline   Reply With Quote
Old 07-20-2011, 10:22 PM   #7
bob g
bob g's Avatar
i had a 427 in my box 64 nova post car with a straight axle,tilt nose[steel] ford top loader,l88 heads .3rd design l88 cam[shifted that bitch at 8200]. drove it all over back and fourth to work, had it clocked at 142 in the long island expressway one night. only maintenance was change the plugs and points once a month.ahhhhh the good ole days the early 70's and ran it on crown high test,[cheaper and faster than sunoco 260]
vendors- AFCO SHOCKS,HOLESHOT WHEELS, MICKEY THOMPSON TIRES/SANDERS WHEELS/S&W/TRZ/TEAM Z/STRANGE/GLASSTEK/VFN/MOSER,MOTOR CITY BODY PARTS..Dealer for Menscer Motorsports shocks..... also just added pro lite batteries to our dealer list.......
WE ALSO BUILD HEADERS,AND DO WIRING
life is like a race, the closer you get to the end the faster it seems to go........
bob g is offline   Reply With Quote
Old 07-20-2011, 10:30 PM   #8
ethelkilledfred
ethelkilledfred's Avatar
One of my favroite motor combo's. Here is one off the net.
The Bug From Hell 427 Big Block Chevy
http://www.youtube.com/watch?v=waN4a..._order&list=UL
ethelkilledfred is offline   Reply With Quote
Old 07-20-2011, 10:31 PM   #9
DougA
DougA's Avatar
Old school here,still running mine,427,4 speed,4:88's.Click on my vid if you want to hear it whine.
DougA is offline   Reply With Quote
Old 07-20-2011, 10:42 PM   #10
Prostreet_632
broke phucker
Prostreet_632's Avatar
427/ oval port heads/turbo 400 and 4.88 and it was still slow 11.50s back in 89/90 days.
Prostreet_632 is offline   Reply With Quote
Old 07-20-2011, 10:45 PM   #11
HOTROD22859
HOTROD22859's Avatar
My 427 should be together in 2 months. '445' block going .030, brand new GM nitrided crank, Compstar rods, SRP 30cc domes, 049 ovals, 2.19-1.88, Crower 258/264 .600 .600 on 107 lobe center, Jesel shafts and a Brodix HV2008 with a QFX 4700 2 circuit 1050. Just bowl work/unshrouding on the heads.
HOTROD22859 is offline   Reply With Quote
Old 07-20-2011, 10:47 PM   #12
Keyser Söze
Spooled up
Keyser Söze's Avatar
Back in the 70's I had a 454 in a 67 Camaro. 4.56 12 bolt, TH 400.
It hauled ass!!!
Then I wrapped it around a telephone pole.
Nothing really to do with having a 427. I just wanted to share...
Keyser Söze is offline   Reply With Quote
Old 07-20-2011, 11:06 PM   #13
mike s
Member
Pullin gears
mike s's Avatar
Still have mine.Ran it before anybody know what a procharger was.Also have a set of 074 L88 heads..ported from a 70s pro stocker..And they do spin up there.
mike s is offline   Reply With Quote
Old 07-20-2011, 11:34 PM   #14
jmink427
Mstr Of Useless Knowledge
jmink427's Avatar
Back in the? Thats what I got now! Damn I'm that far behind the times...
.060 over 454 block
3.76" Gm Steel crank
049 oval port heads
Cam Motion Solid Flat Tappet Cam
Holley Strip Dominator Intake
Trw 2308AF Pistons I think the yield like a 11.7 C.R
Topped off With a Mark Sullens Holley HP 950 E85 Carburetor
4159 lbs.
jmink427 is offline   Reply With Quote
Old 07-20-2011, 11:51 PM   #15
ten5nova
Beer me!!
ten5nova's Avatar
I know a guy that had one in a 64 Chevelle in the early 90's, I don't remember specifics, do know he had GM rectangle port heads, probably a solid flat tappet cam of some kind, etc. it went 11.1's on motor at around 4300 feet elevation. It was a very basic combo, but worked very well. RPM was eventually the demise of this engine!!
ten5nova is offline   Reply With Quote
Resources saved on this page: MySQL 2.11%
