Dodge Death Rattle - Yellow Bullet Forums
Old 07-15-2011, 01:41 PM   #1
Bobalos
Bobalos's Avatar
Default Dodge Death Rattle
if you guys have a dodge truck with the front end problem that makes the front end shake violently, Ive just heard that Dodge is doing a recall on those trucks. as I understand it, its 10 years of 4x4 trucks that have the issue the worst.
check into it.
Bob
You are who you are, when nobody is looking.
Bobalos is offline   Reply With Quote
Old 07-15-2011, 01:44 PM   #2
Speedyws6
Speedyws6's Avatar
Default Re: Dodge Death Rattle
Nope... Its an inspection and "possible" replacement of the left tie rod on 2008-2011 trucks. And some other year models that may have received this tire rod due to repairs.
Speedyws6 is offline   Reply With Quote
Old 07-15-2011, 02:06 PM   #3
MEAN_SBC
TURBOBULLET.COM BITCHES!
MEAN_SBC's Avatar
Mine rides like a caddy...
Brant Campbell
Worlds Fastest MPH Car on 275's
6.92@212.09
2011 PSCA XDR/TT5 Champion
2011 PSCA Sin City Shootout Champion
Thanks To The Following:
MEAN_SBC is offline   Reply With Quote
Old 07-15-2011, 02:09 PM   #4
Bersaglieri
Pre-Staged
Bersaglieri's Avatar
Used to be the track bars on the old ones that caused the death wobble. I bought a lifetime one from Napa, and once every 4 years I go lay it on the counter and get a new one.
-Dustin-
Bersaglieri is offline   Reply With Quote
Old 07-15-2011, 02:25 PM   #5
BONER
There's a recall or TSB on these trucks for this problem. You guys need to call your local dealer if you own one of these trucks.
Jesus Christ. STFU already.
BONER is offline   Reply With Quote
Old 07-15-2011, 02:26 PM   #6
Bobalos
Bobalos's Avatar
Quote:
One of the dudes here has one & he found one last night that was quite a bit larger in scope. he said that it covered 10 or 11 years of trucks. I will ask him to dig it up.
Bob
Old 07-15-2011, 02:27 PM   #7
Bobalos
Bobalos's Avatar
Quote:
thats cause it is a Caddy. duh...................... look @ the key you dope.
LOL
Old 07-15-2011, 02:37 PM   #8
Bobalos
Bobalos's Avatar
http://www.insideline.com/dodge/chry...am-trucks.html
"loss of directional stability". ROFLOL.
Quote:
Just the Facts:
  • Chrysler is recalling 242,780 2003-'11 Dodge Ram trucks because a fracture of the left tie rod ball stud could occur, leading to a potential loss of directional stability, according to the NHTSA.
  • The recalled trucks include the 2008-'11 Dodge Ram 2500/3500 4x4, 2008-'11 Dodge Ram 3500 Cab Chassis 4x2 and the 2008 Dodge Ram 1500 Mega Cab 4x4, as well as 2003-'08 Dodge Ram 2500/3500 trucks that may have received the affected tie rod assembly as a replacement part.
  • Chrysler has not yet provided NHTSA with a schedule for the recall.
WASHINGTON Chrysler is recalling 242,780 2003-'11 Dodge Ram trucks because a fracture of the left tie rod ball stud could occur, leading to a potential loss of directional stability, according to the National Highway Traffic Safety Administration.
"The left tie rod ball stud may fracture," said NHTSA in its recalls summary of the defect. "This condition tends to occur during low-speed parking lot-type maneuvers when the customer is making a tight turn. This condition could result in the potential loss of directional stability in the left hand front wheel, increasing the risk of a crash."
"There have been a few minor accidents and one minor injury," wrote Vince Muniga, Chrysler spokesman, in response to an e-mailed query from Inside Line on Wednesday about the recall.
In other documentation filed with the federal government, Chrysler said this recall is linked to a January 2011 recall of Dodge Ram 4500/5500 trucks to replace the left outer tie rod.
In the current recall, Chrysler's documentation said "analysis of complaints revealed an unusual increase in reports of left outer tie rod ball studs fracturing."
Dodge dealers will inspect the tie rod ends for "relative orientation," said Chrysler. They will replace the left outer tie rod as required and perform a front end toe alignment as needed. Chrysler has not yet provided NHTSA with a schedule for the recall. Owners can contact Chrysler at 1-800-853-1403.
Inside Line says: If you own one of the aforementioned Dodge Ram trucks, be aware that a recall is in the works.
Old 07-15-2011, 03:15 PM   #9
SS4Luck
Member
Pullin gears
If you have the problem try calling Carli Suspenions. We used to do a lot of business with them at my old work and they have a front end kit to fix the problem regardless of what your using the truck for. Just hope they dont refer you to my old boss/job
SS4Luck is offline   Reply With Quote
Old 07-15-2011, 03:40 PM   #10
DR10107
DR10107's Avatar
a good friend of mine has an 06 4x4 cummins, was doing this real bad! if you hit a harsh bump on the hwy above 70mph it was fukn crazy! had to get below 40mph before it would stop! He put all 08 steering and front end parts on it, had it aligned several different ways (so called fixes from other forums) and still did it. he ended up putting some crazy ass heavy duty front end parts from "KORE" on it, I mean steering box brakets, big ass steering stabilizer, etc. and it did stop it from ever happening again but he spent about 4K on eveything! including some Toyo commercial tires which were also recommended! and about 4 days on my lift! those trucks are flat out junk! ride like total shit! interier is crap, trans is a complete piece of shit! about the size of a c4! as soon as you put a little more power in it, it slips like crazy. already had to put an injector in it (50k miles on it) had to put brakes on it already!!?? WTF! Don't understand the Dodge truck guys? what is so great about these trucks besides the long block? and the fact you can buy one used really cheap!
Matt Butrim
MB Racing
Crew chief for "Big Green" X275-4.61@156 F1x
4.74@151 f1r 2013
First F1R in the .80's
Thanks to :
PROCHARGER_Roche Racing Engines_UPR Products_Diamond pistons_Trans-specialtys_Pat's Performance Converters_Chiseled Performance_Woolford bro's chassis_MPS-Maryland performance specialties_VP racing fuels_J&S Performance
*Procharger dealer*
DR10107 is offline   Reply With Quote
Old 07-15-2011, 03:41 PM   #11
UnderPressure
Ice Cream Wolfpack
UnderPressure's Avatar
I thought Dodges were supposed to rattle
Quote:
Originally Posted by 66shovel View Post
weld a chain to it and use that 305 for what god intended, a fucking boat anchor!!!
Quote:
Originally Posted by Fordpowerfred View Post
ISIS wasn't a problem until Obama pulled out early....which is exactly what your dad should have done.
UnderPressure is offline   Reply With Quote
Old 07-15-2011, 03:43 PM   #12
Bobalos
Bobalos's Avatar
Quote:
they are, I meant the "Death Wobble".
http://www.youtube.com/watch?v=z6H5EH261gw
Bob
Old 07-15-2011, 03:59 PM   #13
UnderPressure
Ice Cream Wolfpack
Bob
They aren't supposed to do that???
Old 07-15-2011, 04:02 PM   #14
BONER
Bob
GODDAMN!!!! The dash looked like it was gonna fly out of that thing!
Old 07-15-2011, 04:15 PM   #15
Bobalos
Bobalos's Avatar
I kinda dont think so. can you imagine towing & that starts happening through a corner????
Bob
