th400 direct clutch question - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Transmission - Hutch's Transmission Service
Old 07-13-2011, 08:05 PM   #1
BigS1975
BigS1975's Avatar
Default th400 direct clutch question
How many froctions and steels go in the drum? The drum i have has a beveled steel at the bottom and 4 steels and 4 frictions after it then the pressure plate.I know clearance should be .050-.070.Is this correct?
BigS1975 is offline   Reply With Quote
Old 07-13-2011, 09:37 PM   #2
Whitby Transmission
Spooled up
Whitby Transmission's Avatar
Default Re: th400 direct clutch question
most times five frictions work just fine. No wavy steels. How much power are you going to throw at it?
Whitby Transmission is offline   Reply With Quote
Old 07-14-2011, 12:23 AM   #3
Hutch
Moderator
Hutch's Avatar
Bevelled steel at the bottom sounds like a late model setup with the low cut alum piston. You don't use that stuff in a performance trans.
Hutch
www.hutchtrans.com
519-453-4318
Hutch is offline   Reply With Quote
Old 07-14-2011, 07:56 AM   #4
BigS1975
BigS1975's Avatar
I had it behind a 800 horse BBC.Its going behind one with about 700.It has been behind 1100 hp power adder motor.
Resources saved on this page: MySQL 2.35%
