ls 5.3 max bore - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 06-30-2011, 03:00 PM   #1
Nastynag
Burnout box
Default ls 5.3 max bore
I'm new to this hole ls thing but i came across a real cheap 5.3 that needs a rebuild but i always heard you can't do much more than a good hone on them. I'm not sure what all need to be done to it yet if its no good when i get it apart i can just use the block for mock-up. But my question is how far can you bore them?
Nastynag is offline   Reply With Quote
Old 06-30-2011, 03:31 PM   #2
gieser
Burnout box
Default Re: ls 5.3 max bore
3.90" for the ls1 pistons is about max
gieser is offline   Reply With Quote
Old 07-01-2011, 03:00 AM   #3
racer7088
Yeah we do 3.903 on them all the time.
Erik Koenig
hkracingengines.com
racer7088 is offline   Reply With Quote
Old 07-01-2011, 09:18 AM   #4
deadhorse66
deadhorse66's Avatar
If you were wondering, that's a .120" overbore. I've heard of people doing this, but I'd get a sonic check done. Nothing worse than spending a bunch of money and then collapsing a cylinder wall.
deadhorse66 is offline   Reply With Quote
Old 07-01-2011, 09:20 AM   #5
deadhorse66
Eric, have you ever run into a thin cylinder?
Old 07-01-2011, 01:01 PM   #6
racer7088
Thumbs up Re: ls 5.3 max bore
Quote:
Not so far, you can run a drill rod between the bores and they are pretty thick if you do the math. We cut them in half and they were thicker on the thrust sides as well. We have run several in big NOS like 400 shot and turbos and they have all held up so far.
Erik Koenig
hkracingengines.com
Old 07-01-2011, 02:59 PM   #7
Chicago TDP
Burnout box
Chicago TDP's Avatar
The 5.3L blocks have been making big power....and are much less expensive then buying a LSX block or a 6.0L block....I am running a 4.8L short block and making close to 600 RWHP ...with a little boost.
Chicago TDP is offline   Reply With Quote
Old 07-05-2011, 10:29 PM   #8
SWTWC76
Burnout box
Can these blocks be resleeved for bigger bores or would that be a waste of money?
SWTWC76 is offline   Reply With Quote
Old 07-05-2011, 10:43 PM   #9
94z
Launchin
94z's Avatar
anyone ever just bore one out to 4.00 to see what you would come up with
1999 trans am ws6 -2000 camaro real street/ x275
94z is offline   Reply With Quote
Old 07-05-2011, 10:45 PM   #10
Preacher's Kid
Preacher's Kid's Avatar
depends on if it's an iron block or aluminum block. assuming it's an iron block, i'd absolutely get it sonic checked and go to a 3.903" bore to build an iron 5.7 if you have to bore it. if an aluminum block, then your assumption of doing just a heavy hone is about correct as there's not much material there.
Matt
9.974@135.55 All Motor
"Like" MotorManiaTV on Facebook!
Check out my videos!
Preacher's Kid is offline   Reply With Quote
Old 07-05-2011, 11:36 PM   #11
Billyman
out of work hair dresser
Billyman's Avatar
I'm with Erik. I haven't seen a 5.3 block that was remotely questionable for a 3.903" or 3.905" bore. I've been saying this stuff over and over for a few years now........................................I just wait for Pro Stock John to come along and argue about it.
Quote:
Originally Posted by Monty Mikho View Post
If you can't dazzle them with brilliance.. baffle them with bullshit
Quote:
Originally Posted by Plato
"Wise men talk because they have something to say; fools talk because they have to say something."
Billyman is offline   Reply With Quote
Old 07-07-2011, 01:11 AM   #12
BattleSausage
Spooled up
I've got one sitting here that I was planning to take out to at least the stock 3.898, probably more like the 3.905 like most do. However, I've been wanting to see someone take one out to 4" on a moderate build and see how it holds up but I haven't seen anyone do so as of yet. I'd love to do it myself but my budget is a bit tighter than most of the folks on here.
BattleSausage is offline   Reply With Quote
Old 07-07-2011, 01:48 AM   #13
jon6.0
jon6.0's Avatar
Why not just get a 6.0L block if you want a 4" bore?
2011 C6 Corvette, Pfadt 1 3/4 headers, Vortech T-trim, Dallas Performance direct drive, ported intake manifold, Pfadt sways and shocks, Pfadt trans mounts, McLeod RXT clutch, Corsa axleback
jon6.0 is offline   Reply With Quote
Old 07-07-2011, 03:04 AM   #14
BattleSausage
Spooled up
Quote:
Because I want to see what I can do with the LM7 I have. I already know what I can do with an LQ4/9 but I already have the 5.3 so why not use it. Why don't you ask GM why they aren't still using the gen 1 sbc for everything since they already knew what it was capable of...since that question is as relevant.
Old 07-07-2011, 04:15 AM   #15
jon6.0
jon6.0's Avatar
Way to respond by being a dick.
So because you already have this block you are going to go through the trouble of sonic checking it, boring it, and hope it works. Hmm. Seems easier to just get a 6.0 block. Do what you want though.
