C-12 vs Sunoco Blue - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Racing Fuels
Old 11-21-2007, 05:20 PM   #1
classrcr
Burnout box
Default C-12 vs Sunoco Blue
Been using C-12 in a bbc with 11 to 1 will Sunoco Blue be equal as far as performance and tune up?
classrcr is offline   Reply With Quote
Old 11-22-2007, 10:19 AM   #2
Pooch565
Pooch565's Avatar
Default
Are you spraying nitrous? If not, I have found C12 is a more consistent fuel in bracket racing. It isn't affected by the change in temp and humidity as drastically as other fuels. As far as all out power. C12 will make a couple more HP, but you won't see a huge difference in ET. Hope this helps.
Jason
Jason Rueckert
Regional Manager
VP Racing Fuels -Midwest
812 878 2026
jason@vpracingfuels.com
Pooch565 is offline   Reply With Quote
Old 11-22-2007, 11:18 PM   #3
joesmithz28
Default
Why not try some MS109??? or VP113?
joesmithz28 is offline   Reply With Quote
Old 01-04-2008, 06:02 AM   #4
scot9055
scot9055's Avatar
Default
I noticed that the sunoco fuel doesn't evaporate and gum up the carb like the vp so if it fits your application I would go with it
scot9055 is offline   Reply With Quote
Resources saved on this page: MySQL 2.25%
