Cast Aluminum Block Issues - Page 2 - Yellow Bullet Forums
Old 06-28-2011, 10:57 PM   #16
mrhockey
mrhockey's Avatar
Default Re: Cast Aluminum Block Issues
Thanks for the reply. The bore is a 4.155 and I am running studs with the balls on the end so they don't bottom out and we have MAYBE put 1100hp to it this year on just a couple of occasions. Nothing crazy or 40lbs of boost or anything. Does that sound like an issue there? Why suddenly are the bores the wrong size? Did the manufacturer do his machining of the holes wrong of did they just suddenly all change. I think my builder put sleeves in 4,5 and 6. The OD of the sleeve doesn't match the manufacturers stock sizes they said they weren't theirs but we have an invoice from them for the purchase. They don't know how that size sleeve got on their shelf to ship out. Not really an issue since the machine shop could compensate for that but a strange screw up.
Cylinder bore Sleeve OD
1. 4.272 /4.272
2. 4.272 /4.272
3. 4.2725 /4.272
4. 4.282 /4.2815
5. 4.2725 /4.272
6. 4.2825 /4.282
7. 4.272 /4.272
8. 4.280 /4.282
2017 Jr Dragster MARKETING PARTNERS:
LUCAS OIL / BOCCELLAS AUTO / NGK SPARK PLUGS / CLARK INDUSTRIAL SUPPLY / DJ SAFETY / CRAW'S RACING / LUCAS OIL RACING TV
Call Me For Pricing On:
JESEL
ACTION CAM NX
DJ SAFETY
HOLESHOT WHEELS
GZ MOTORSPORTS VACUUM PUMPS
NICKELS PERFORMANCE WAREHOUSE
WWW.MARSCHANMOTORSPORTS.COM
mrhockey is offline   Reply With Quote
Old 06-28-2011, 11:13 PM   #17
Collinsautomotive
1. 4.272 /4.272
2. 4.272 /4.272
3. 4.2725 /4.272
4. 4.282 /4.2815
5. 4.2725 /4.272
6. 4.2825 /4.282
7. 4.272 /4.272
8. 4.280 /4.282
If you feeling creative, you could find a way to get the fastner to more evenly load in the block, but it would require alot of welding and milling to accomplish.
the studs aren't the proble, the problem is a lack of material strength around the tops of the bore where the head is trying to yank the deck off. with iron its not such a big concern as Iron has a much higher strength then aliminum by volume, the LS! blocks have a huge improvement here as the head bolt boss's are not attach to the cylinder bores and are rooted into the block structure in a much stronger manner.
Pretty much any motor with a tight bore space, large bore, aluminum contruction and a traditional 5 bolt layout, is going to have trouble with alof of cylinder pressure.
Henry Ford, on the stock market
Quote:
"As betting at the race ring adds neither strength nor speed to the horse, so the exchange of shares in the stock market adds no capital to business, no increase in the production and no purchasing power to the market."
Old 06-29-2011, 08:14 AM   #18
mrhockey
mrhockey's Avatar
Yeah I can see that the studs are close, but why SUDDENLY are the bores all the same size as the sleeves? I can understand distortion at the tops of the cylinders but not an expanding bore where there is suddenly no press. They are trying to say it's from the repair of the block. Why am I the only one with this problem? It's all Uratchkos fault for telling me to get a spread rail, raised cam block. Should have kept the old Little M!
JESEL
ACTION CAM NX
DJ SAFETY
HOLESHOT WHEELS
Old 06-29-2011, 10:58 AM   #19
69chicken
69chicken's Avatar
I would bet Chris was referring to a Dart I.E. block. Still though I can't see any reason you should be having these problems @ that H.P. level unless it's a defective block casting. I think if this was mine I would want a new block with new sleeves or your $$$$$ back.
69chicken is offline   Reply With Quote
Old 06-29-2011, 11:03 AM   #20
mrhockey
mrhockey's Avatar
That's what I want. I don't want to put any more money into that block. My machine shop offered to prep a new block for me at no charge which is cool but we will see. I still haven't heard from them today after a long email sent last night. Not trying to sound like sour grapes here but it just doesn't make sense.
JESEL
ACTION CAM NX
DJ SAFETY
HOLESHOT WHEELS
Old 06-29-2011, 07:54 PM   #21
RCM Racing engines
RCM Racing engines's Avatar
Brodix has been having CASTING issues, not that you said it's a brodix.......BUT, i know of 2 BBC blocks recently that went back for repair
Sleeves were collapsing between the cylinders.....aluminum was breaking.....and the sleeves moved all around
These were tall deck BBC's making anywhere from 1140hp- 1210hp
I have a aluminum BBC 532 going together and i hope i don't have this $hit happen to me........ i wasn't impressed with there machine work
anyway, i mean really who makes 3 seperate passes 4 inches wide on a deck surface....... or leaves big chunks hanging off the sleeves after
Crank/ rod clearancing......... not IMPRESSED at all...............................especially for $ 5 K ++
Just an old' Mennonite..........
RCM Racing engines is offline   Reply With Quote
Old 06-29-2011, 08:28 PM   #22
mrhockey
mrhockey's Avatar
Thanks for that input RCM. Very informative.
JESEL
ACTION CAM NX
DJ SAFETY
HOLESHOT WHEELS
Old 06-29-2011, 08:48 PM   #23
kountryboy2
Friendly Shit Stirrer
Quote:
Originally Posted by Collinsautomotive View Post
you answer lies with the head bolts and how they clamp the head to the block. SBC is a bad motor for aluminum and big power with aluminum block. the head bolts try to yank the deck off the motor, the bigger the bore the bigger the problem is.
There are head studs that will fix that problem They start at $70.00 each.
kountryboy2 is offline   Reply With Quote
Old 06-29-2011, 08:51 PM   #24
kountryboy2
So anyway this block now needs 8 sleeves I am told by the manufacturer. Suddenly not only do the 3 sleeves put in by my engine builder not have the right press but the other 5 put in by the factory a year ago do not either. They are pretty much all the same size as the bore. My builder ordered oversize sleeves so they could clean up the bores and waited for them and put them in with a .003 press. The manufacturer still has not addressed or told me how the sleeves could have been so out of round and haven't told me where they measured their cylinders at. They are trying to say maybe the engine builder put the sleeves back in cold instead of heating the block in the oven again. Wrong! They said the welds and repairs look good but are trying to explain how they happened. It doesn't matter.........they were fixed and aren't cracked but now everything is moving around. The builder tells me the block is stress relieving itself and moving around and if I pay to get it fixed it's going to happen again. He bets me his shop it will. I am starting to lose faith and the highroad is eroding by the minute.
Do you know how hot the block got in the oven? How long was it in the oven?
Old 06-29-2011, 09:04 PM   #25
mrhockey
mrhockey's Avatar
Quote:
No sir I don't. I am trusting the builders and their building higher end stuff using cast and billet aluminum blocks and their knowledge. I might have to pass on the $70 head bolts too.
JESEL
ACTION CAM NX
DJ SAFETY
HOLESHOT WHEELS
Old 06-29-2011, 09:56 PM   #26
582nova
Member
Pullin gears
582nova's Avatar
im getting ready to purchase a 10.2 deck for a 632cui.my engine builder wants to fill it to the water ports.ill have to ask him if he is aware of these problems.how much weight will i really lose if the aluminum block is filled?
582nova is offline   Reply With Quote
Old 06-29-2011, 10:10 PM   #27
mrhockey
mrhockey's Avatar
i thought about filling mine halfway but was told by the manufacturer to not worry about it but i also didn't want to take away from the main reason i bought the block, to lose 90lbs on the nose.
JESEL
ACTION CAM NX
DJ SAFETY
HOLESHOT WHEELS
Old 06-29-2011, 10:33 PM   #28
JB Arms
JB Arms's Avatar
Mine was filled about an inch or so at the bottom for reinforcement. I have a dart block, newer design. That's got to be a nightmare and you don't want it to happen again. Howard
JB Arms is offline   Reply With Quote
Old 06-29-2011, 11:44 PM   #29
Collinsautomotive
Slowly cooling aluminum hardens it, quneching it anneals it.
Old 06-29-2011, 11:45 PM   #30
Collinsautomotive
How is a head stud going to stop the bore and deck from pulling to the point of deformation, its not like the fastner broke, the material around the stud is yeilding.
