Ran out of Valve Lapping Compound..... - Yellow Bullet Forums
Old 06-09-2011, 11:38 PM   #1
Roller
Spooled up
Default Ran out of Valve Lapping Compound.....
I just got my heads back from the machine shop and wanted to check out the valve job and lap the valves, but Ive run out of compound. Closest thing I have is valve grinding compound. I know the consistency isnt exactly the same but can grinding compound be used to lap valves? Anyone know for sure? I dont think itll ruin anything but I wanted to ask first. Any help is appreciated.
Roller is offline   Reply With Quote
Old 06-10-2011, 10:43 AM   #2
revolutionary
revolutionary's Avatar
Default Re: Ran out of Valve Lapping Compound.....
grit and oil mixed together. You can always run to any auto parts store and typically by the silicone are small tubes of lapping compound
Daryl
Revolutionary Performance and Machine
revolutionary is offline   Reply With Quote
Old 06-10-2011, 06:23 PM   #3
REDRKT
Spooled up
REDRKT's Avatar
I personally would NEVER use any sort of grit/abrasive on valve faces/seats . I use dykem, or magic marker.....
REDRKT is offline   Reply With Quote
Old 06-10-2011, 06:28 PM   #4
Chad Speier
Chad Speier's Avatar
The good ole valve bounce test will give you an idea..
VFactor NATION
SRH Speier Racing Heads
785.623.0963
Chad Speier is offline   Reply With Quote
Old 06-10-2011, 06:31 PM   #5
82bird
Member
Pullin gears
82bird's Avatar
why need to go over the machinsist work?
Jones Performance
82bird is offline   Reply With Quote
Old 06-10-2011, 08:40 PM   #6
jeff klei
Member
Pullin gears
Unless you have complete trust in your machinist..........
jeff klei is offline   Reply With Quote
Old 06-10-2011, 08:56 PM   #7
LilJohn
LilJohn's Avatar
Machinist should have lapped them in. Every set I assembled for the 2 years I did it got lapped in.
888-583-4408
www.LilJohnsMotorsports.com
LJMSJohn@gmail.com
Dealer for Brian Tooley Racing, Bullet Cams, Comp Cams, Borg Warner, Garrett, Forced Inductions, Callies, Wiseco, Billet Atomizer Injectors , Ultimate Converter Concepts, and many more.
Some men want the glory of being like John Force. Me, I wanna be Austin Coil.
Like us on Facebook:
https://www.facebook.com/?sk=nf#!/Li...sportSolutions
LilJohn is offline   Reply With Quote
Old 06-10-2011, 10:56 PM   #8
shawns engines
shawns engines's Avatar
I also like to lap the valves in after a valve job. Lets me know exactly where the seat is on the face of the valve and lets me see that the valve seat has no runout. i also use a starett guage to check the concentricity but like to lap them in for sure
shawns engines is offline   Reply With Quote
Old 06-11-2011, 12:34 AM   #9
Roller
Spooled up
Yeah, I tend to not trust any machinist no matter who it is or how good their reputation. Even the absolute best make mistakes every now and then and I cant afford mistakes at this point in time. None of the auto part stores around here have any lapping compound. Is there anything that I can use as a substitute?
Old 06-11-2011, 01:12 AM   #10
Bob Hollinshead
Launchin
Use auto paint rubbing/buffing compound, it is a finer grit and I think it does a much better job.
Bob Hollinshead is offline   Reply With Quote
Old 06-11-2011, 03:03 AM   #11
dover1320
dover1320's Avatar
If you don't check, how do you know. If you don't know how can you get it fixed before you tear up more? Then who's fault is it or who's bill? Not to say machinist are bad, but we are human. Double checkin never hurt no one .
dover1320 is offline   Reply With Quote
Old 06-11-2011, 07:54 AM   #12
Roller
Spooled up
I'm of the opinion that no matter how badly a machinists pooched a job its entirely your fault if you don't catch it before assembly. The double checking of specs is key. Ill try auto paint rubbing compound.
Old 06-11-2011, 11:04 AM   #13
OldSStroker
Spooled up
Try this for lapping compounds. Online ordering is easy.
http://www.mcmaster.com/#clover-lapp...pounds/=cp93m7
"Being able to "think outside the box" presupposes you were able to think in it." --Bob Lutz
"There are some people who, if they don't already know, you can't tell 'em."--Yogi Berra
OldSStroker is offline   Reply With Quote
Old 06-11-2011, 12:45 PM   #14
Chris Uratchko
Moderator
Chris Uratchko's Avatar
Ah.... had some of that stuff years ago and never found it again. Should have known to look at Mcmaster. That place is awesome.
Chris Uratchko is offline   Reply With Quote
Resources saved on this page: MySQL 2.15%
