june 18 th thompson roll call - Page 36 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Fire your bullets!!! > Let's Talk Drag Racing
Let's Talk Drag Racing Talk about drag racing with censorship...
Old 06-23-2011, 11:03 PM   #526
chevydude
chevydude's Avatar
Garage
Default Re: june 18 th thompson roll call
Quote:
Originally Posted by slorob View Post
so what happens if any fuel washes down into the ringlands?
A cylinder wall that looks like glass!! A crank case full of stinky fuel/oil....plus a few more issues if not addressed Bearings ect... But thats after continuous rich conditions & abuse like that.. His was all of a sudden, Why Rob? you don't think it would fire the hole?? Burnt gasket,Excessive fuel, Possibly sucking air Or caught the adjacent hole during intake & Boom!!! Seen it before Grasshopper!! LOL!
The Ultimate budget build!!Ford makes it, Chevy shakes it...86 Coupe S/S, BBC Powered 10 to1 489ci very mild..615/.620 flat tapped cam,(Procomp heads)850 alky carb, Powerglide, 4.10's 9" tire.best to date= 1.331 60' & 6.053 @ 112mph 1/8th, Has been 9.90's In the quarter but have not run the quarter since figuring out some issues, Car & motor built by me, Build cost of entire car Just under $5000.00
https://www.youtube.com/watch?featur...&v=kJaN3fgNl1k Still sorting!
chevydude is offline   Reply With Quote
Old 06-23-2011, 11:51 PM   #527
BLUEOVALRACER
Quote:
Originally Posted by ozone eater View Post
question 1: which way is the plate mounted? for example, if you are standing at the nose of the car and looking at the engine, is the spray but run from the back of the engine to the front or from one bank to the other?
question2: when you switch from 93 to the high octane, do you pull the fuel lines off and drain every single drop of gas out of them and the tank?
Gerry,i was thinking the same thing are you using the same fuel cell for the pump gas and race gas?Also what did the spark plug look like out of that cylinder?
Later Mark.
BLUEOVALRACER is offline   Reply With Quote
Old 06-24-2011, 05:57 AM   #528
gerry
R.I.P DAD 9-25-2012
gerry's Avatar
barran ill post pic and all ? will be answered
and yes i use same fuel cell no i dont drain every drop - theses are ? ive been ? ing my self plus many more
barran its a 4 noid system
Its official Making a come back in 2016
R.I.P JAMES PENN 9-25-2012 YOU WILL BE TRUELY MISSED DAD
R.I.P FRANCIS COLEY 7-01-2012
gerry is offline   Reply With Quote
Old 06-24-2011, 08:59 AM   #529
bones427
bones427's Avatar
Gerry call cometic they make mls gaskets fo bbf and also do custom stuff.look at there website Cometic Gasket, Inc.
8090 Auburn Road
Concord, OH 44077(800) 752-9850Call Toll Free(440) 354-0777Order / Tech Line(440) 354-0350Fax
bones427 is offline   Reply With Quote
Old 06-24-2011, 09:29 AM   #530
ultrarace
Member
Pullin gears
ultrarace's Avatar
You can buy cometic for the big block ford thru competition products they have them in stock most of the time
WWW.ULTRATECHRACECARS.COM
For all your chassis & fabrication needs
Race one or Chase one
You can also check us out on facebook.
ultrarace is offline   Reply With Quote
Old 06-24-2011, 06:34 PM   #531
slorob
Quote:
I was thinking about damaged ringlands, like some old 496 with a small, safe tune had on it.
slorob is offline   Reply With Quote
Old 06-24-2011, 07:44 PM   #532
fast406malibu
fast406malibu's Avatar
What cranking pressure did you have in the motor gerry..??
If it was high to begin with adding the small shot you did of nitrous would increase that pressure and make that gasket go..We all know the ford head bolt pattern isn't the best for torquing a head down..I would also look into a MLS gasket possibly.. A good race Fel-Pro gasket will work but i would add acouple coats of Copper spray to both sides when installing..
either way good luck on getting it back together..
APD carbs & race engines..
Fleenor Racing Powerglides
419-280-1406
BTE, Hughes & Trans Specialties Dealer.
http://www.youtube.com/watch?v=iW-5g...ature=youtu.be
http://www.youtube.com/watch?v=f0cho...ature=youtu.be
fast406malibu is offline   Reply With Quote
Old 06-24-2011, 08:14 PM   #533
Leavinsteven
REBUILDING
Leavinsteven's Avatar
Hmmmm Rob, sounds familiar, but I think you mean "489"? lol.
Hey Gerry, after all the grief that you get on here, it seems as if the Renegades really do pull together when the going gets tough!
Talk to Ronnie indepth, he will figure out what happened.... he did with my motor!
http://youtu.be/5L5h8pyAG6Q
Life is Drag Racing....
Everything else is waiting.
Leavinsteven is offline   Reply With Quote
Old 06-24-2011, 10:53 PM   #534
chevydude
chevydude's Avatar
Garage
I figured you were, But not the same scenario...Turns out that the smashed ringland came from a piston that was too tight in the Bore!! Even has the Odd wear marks to prove it..actually had started to fold the material over itself, Good thing he's being meticulous with his build & disassembled everything, I saw the piston in question yesterday, one side was virtually untouched & the other side was heavy aluminum to metal contact, So some of that fog was probably from a hole that the rings were no longer seating properly!! All the others looked Fine.....Something expanded or distorted that one (heat)..maybe from the prior blown head gasket that it suffered late in October when it was last run when it was really cool out & it was a little Lean if you remember correctly, which was the reason for them fattening it up & taking some timing away the next time out!! basically it had probably already developed that problem right then...
Old 06-24-2011, 11:35 PM   #535
slorob
if you dont ask the questions? how can you learn and get answers? thanks!
Old 06-24-2011, 11:57 PM   #536
Leavinsteven
REBUILDING
Thats scary considering that the balancer had spun on the rubber o ring approximately 89 degrees! Anyone want to buy a balancer, cheap? 75cents.... LOL.
Old 07-10-2011, 07:25 PM   #537
Mopardiva
Burnout box
Mopardiva's Avatar
Talking Re: june 18 th thompson roll call
HEY GUYS AUG 6,IS THE CUDRA RACE!!!!!HEADS UP 24/7 ALL DAY .THE CAR SHOW WAS GREAT,FUNNYCAR,HOT RODS.BIKES I ENJOY MYSELF!!!GO CUDRA!!!!
Mopardiva is offline   Reply With Quote
Old 07-10-2011, 10:03 PM   #538
denn468
denn468's Avatar
Quote:
what index?
denn468 is offline   Reply With Quote
Old 07-11-2011, 10:24 AM   #539
cumminatya
Member
Pullin gears
cumminatya's Avatar
Denny they are having a some different index classes that day all 1/8 mile a 6.70 for sure i will try to post the flyer tonite tomm it looked like a pretty good bang for the buck
Renegade Racing Association
Davis Race Cars
Hyatt Racing Clutches
UMTR North
cumminatya is offline   Reply With Quote
Old 07-11-2011, 11:19 AM   #540
jim loveland
Member
Pullin gears
jim loveland's Avatar
Quote:
looks pretty good i think i will be racing
jim loveland is offline   Reply With Quote
