Mozez heads? - Page 8 - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > LSX, Mod Motor and Gen III Hemi Tech
Old 06-30-2011, 04:53 PM   #106
moderncylinder
Launchin
Default Re: Mozez heads?
Quote:
Originally Posted by stage20 View Post
what about the GM canted valve head?
the gm canted valve head is cast with gm numbers in it and is accepted,, it was used in pro stock truck,, and is used in comp often,, though castings are thin and not too rigid
most in truck welded the crap out of them or added bars of aluminum to the intake side to move ports and add integrity
moderncylinder is offline   Reply With Quote
Old 07-01-2011, 09:15 PM   #107
lsp
Quote:
Originally Posted by Billyman View Post
The guys I know that are building/testing LS engines for Comp are using wedge heads.....C5R style.
What are they using for a block?
lsp is offline   Reply With Quote
Old 07-01-2011, 10:13 PM   #108
Billyman
out of work hair dresser
Billyman's Avatar
Quote:
GM LSX Bowtie.
Quote:
Originally Posted by Monty Mikho View Post
If you can't dazzle them with brilliance.. baffle them with bullshit
Quote:
Originally Posted by Plato
"Wise men talk because they have something to say; fools talk because they have to say something."
Billyman is offline   Reply With Quote
Old 07-01-2011, 11:09 PM   #109
lsp
GM LSX Bowtie.
Still has the pan rail on it?
Old 07-01-2011, 11:16 PM   #110
Billyman
Billyman's Avatar
I haven't seen it therefor I don't know.
Why would they remove the pan rail?
Old 07-01-2011, 11:32 PM   #111
lsp
[QUOTE=Billyman;6535553
Why would they remove the pan rail?[/QUOTE]
More power, raw deck blank lifter bore sbc low deck ps truck type block might be a neat possibility.
Old 07-01-2011, 11:51 PM   #112
Billyman
Billyman's Avatar
Use punctuation please..........................the fuck you just say?
Truck type block? You do know we're talking about LS engines here?
Old 07-02-2011, 07:33 AM   #113
lsp
I think a traditional a blank lifter bore/blank deck sbc block would be a better place to start for a serious Comp style LS motor.
Old 07-02-2011, 03:47 PM   #114
Billyman
Billyman's Avatar
How do you get an LS motor from a traditional sbc block?
Old 07-04-2011, 12:33 PM   #115
lsp
Only reason to consider LS anything is if the cylinder head available shows potential over what else is available for a particular class. I wouldn't use the LSX block for anything but a stock or super stock deal that must run a GM LS block.
Old 07-04-2011, 03:07 PM   #116
Smith
Smith's Avatar
What is your reason? Why do you feel that the ls platform is inferior to the traditional sbc?
Smith is offline   Reply With Quote
Old 07-04-2011, 05:39 PM   #117
lsp
Deck height is too tall, not a big fan of the deep skirt block either.
Old 07-05-2011, 12:16 AM   #118
Billyman
Billyman's Avatar
This I agree with but can be dealt with also..........and has actually.
It has its downfalls but again it can be worked around. We use to build 3.8 Buick round track engines years ago at just under 580HP N/A...........with stock blocks.
Resources saved on this page: MySQL 2.15%
