Bluchev - Yellow Bullet Forums
Old 05-24-2011, 12:52 AM   #1
bluchev
bluchev's Avatar
Default Bluchev
Ok after a shit ton of research on here i thought it'd be cool to build a turbo car. So over the last few months i put this together.
72 Chevelle
SBC 355
Turbo 350
Fab 9" rear with 35 spline axles, 3.70 gear spool
295/65/15 MT ET street Radials
3800 stall Nitrous converter
355 SBC Vic JR., intake NOS Cheater kit,
CSU 750 E85 Blow thru Carb
S400 75mm turbo with 96mm turbine wheel 1.32 AR
Non intercooled
2- 38mm turbonetics wastegates
5" Downpipe
-10 drain
2,5" stainless crossover with no flex, SSautochrome CHINA headers fitted with v band flanges
Dart Pro 1 200cc aluminum heads
9.5-1 Speed Pro forged pistons
Crower sportman forged rods
4 bolt block
9.10@153.3 on 24 psi (2015) Dominator EFI 3850 lbs
New setup for 2016 Twin Billet S374's from CRT turbo, 6.0 on 25 psi 1117WHP 884 WTQ
bluchev is offline   Reply With Quote
Old 05-24-2011, 12:53 AM   #2
bluchev
bluchev's Avatar
Default Re: Bluchev
Here's The car
Old 05-24-2011, 12:55 AM   #3
bluchev
bluchev's Avatar
Default Re: Bluchev
I took a short cut on the down pipe, the section where i wanted to put the down pipe is too tight and i dont want to take the hammer to it just yet. Jeremy said he has access to a porta power so its still an option, i just dont wanna clearance it with a hammer, id rather have it look nice.
I wanna get this thing on the road as soon as i can to see how well that carb works so i can give myself as much time as possible to dial it in. I expect alot of tuning
if i decide to keep the downpipe where its at i'll just chop up another 90 and shoot it right out the front fender and put a nice trim ring around it. Either way its gonna be loud so i dont think it'll matter much :dunno:
Old 05-24-2011, 12:56 AM   #4
bluchev
bluchev's Avatar
Default Re: Bluchev
Old 05-24-2011, 12:57 AM   #5
bluchev
bluchev's Avatar
Default Re: Bluchev
Update:
Put everything together this weekend, tied up all the loose ends. sealed up the headers
and hotside with ultra copper rtv, plumbed the wastegates, polished the compressor
housing, had a chunk of 3.5" tubing welded onto the carb hat, put a oil fill cap and some
bungs in the valve covers for the -12 lines that go to the catch cans(the imaginary
catch cans i havent made yet). Welded in an o2 bung for the wideband. hooked up the
nitrous, wired up the alternator, installed new manual steering box and single adjustable
Qa1 shocks up front, cleaned up some of my wiring, figured out the size of belt i needed
for my new alt setup.Re-routed my plug wires so they go under the headers and installed
some plug boots so they have a chance of NOT burning up (hopefully).
I'm gonna start this thing tomorrow. Topped it off with E85 and fresh fluids, double
checked everything. So far everything looks good. The only thing not completely hooked
up is the BTM and my catch cans. I'll load up some pictures in a bit.
Update:
Update:
Update:
Old 05-24-2011, 12:58 AM   #6
bluchev
bluchev's Avatar
Default Re: Bluchev
Old 05-24-2011, 12:59 AM   #7
bluchev
bluchev's Avatar
Default Re: Bluchev
And yes, those are band clamps on the carb hat.
the t bolt clamps i got from tnt were too small and i was hoping to drive it this weekend so i just grabbed them for the time being. Im gonna order up the correct size tbolt clamps tomorrow.
Old 05-24-2011, 01:00 AM   #8
Notchkid89
Notchkid89's Avatar
Default Re: Bluchev
lookin good...
FoxBodyFonz without the fox body haha
Notchkid89 is offline   Reply With Quote
Old 05-24-2011, 01:06 AM   #9
bluchev
bluchev's Avatar
Default Re: Bluchev
Ok here's a couple videos of me screwing around with the car. LOL
https://www.youtube.com/watch?v=7A3A..._order&list=UL
https://www.youtube.com/watch?v=7A3A..._A1W7k&index=3
Old 05-24-2011, 03:01 AM   #10
jason cole
Launchin
jason cole's Avatar
Default Re: Bluchev
looks good but you better get a blow off valve on that thing or you are going to mess stuff up.like your turbo or bend some throttle shafts or worse.
jason cole is offline   Reply With Quote
Old 05-24-2011, 03:02 AM   #11
bluchev
bluchev's Avatar
Default Re: Bluchev
Blow off Valve is on its way.
Old 05-24-2011, 03:14 AM   #12
jason cole
Launchin
jason cole's Avatar
Default Re: Bluchev
cool make sure to post some times when you get some good luck looks great!!!!!!!!http://s1182.photobucket.com/albums/...t=SDV_0043.mp4
Old 05-24-2011, 05:02 AM   #13
Kid_Money
Launchin
Kid_Money's Avatar
Default Re: Bluchev
Car looks really cool. I'd also like to see some numbers. How hard was it to polish the housing?
LOOSE LIPS SINK SHIPS
Kid_Money is offline   Reply With Quote
Old 05-24-2011, 10:15 AM   #14
bluchev
bluchev's Avatar
Default Re: Bluchev
Quote:
Thanks, So far polishing the compressor housing was the hardest part of the build. It took me 2 days and quite a bit of elbow grease. It wasn't really hard but definitely a pain in the ass, very tedious. I knocked down the casting with a 90 degree grinder with a green roloc disc, then started with 100 grit then 150, 220, 240(wet), 400(wet),800(wet), 1200 (wet), then 2000(wet).
after all that i used some of this http://www.californiacustom.com/purp...al_polish.html
I think if i used some fine rubbing compounds i could get it a little shinier.
Old 05-24-2011, 12:23 PM   #15
turbo_boat
Smoked another BBF
turbo_boat's Avatar
Garage
Default Re: Bluchev
nice!
turbo_boat is offline   Reply With Quote
Resources saved on this page: MySQL 2.06%
