Old 10-23-2005, 10:59 PM   #1
tsmale
Burnout box
Default Holley HP carb inflated CFM numbers?
I saw this on the Newsgroups: rec.autos.rod-n-custom
"Holley is misrepresenting their HP carb sizes, a HP 950 is really a
830, a HP1000 is about a 870 if measured the same vac as a 47-- series.
The industry standard for cfm ratings was 1.5"Hg vac for a 4 barrel.
holley may have decided to follow the deciptive lead of it's
competitors and use 28"wc which is 2.06" hg.
Holly has all their carbs listed with flow spects. They make no
distinction between a HP type and a older 4781 type. Unless you
actually flow a carb, with holley's listings, you can't tell what flow
it may be since the listed flows of the 4 barrels are not made with the
same test standard. Their all listed together by flow ratings. I'm just
for the truth in advertising, if holley actually told the test vac for
carbs it would be better, Esp if they use different test spects for
different 4 brl carbs. It looks like Holley uses a 1.5"HG vacuum
standard for the 47_ _ series carbs and for the HP series they use
2.06"hg vacuum test standard. The result is a false comparison between
the two carbs. I got tricked and many others will be also. Spread the
word about this .
The bottom line --- I paid $700 for a HP950 thats smaller than my 4781
850 carb.
The HP950 has a 1 3/4 base plate and a 1 3/8 venturi.
A older 850 has a 1 3/4 base with a 1 9/16 venturi
A HP830 has a 1 11/16 base and a 1 9/16 venturi"
http://www.thecarburetorshop.net/bigger2.html
tsmale is offline   Reply With Quote
Old 10-24-2005, 07:22 PM   #2
Chris Uratchko
Moderator
Chris Uratchko's Avatar
Default
Far as I'm concerned everyone else is inflating too... so I think Holley just jumped on the bandwagon.
That is why if you talk with Patrick at ProSystems he will really try and not discuss flow numbers.....he chooses parameters that will fulfill and engines needs and that is what he uses.... not really by choosing advertised flow numbers.
___ www.URE-Racing.com ___
Dealer For -
BME
Brodix
Diamond
Manley
MGP
Jesel
Star Vacuum Pumps
Trend Products
Xceldyne
Chris Uratchko is offline   Reply With Quote
Old 10-24-2005, 07:29 PM   #3
DOTracer
DOTracer's Avatar
Default
Exactly...I don't even know what the dry or wet flow CFM of the PS carb I got other than to know it's a 1000HP model. Don't really care either as long as it performs better than the carb it replaced, which it did by a tenth.
DOTracer is online now   Reply With Quote
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
YellowBullet.com
