How do you guys mount steel bodies to a full tube chassis? - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Chassis and Suspension - Tim McAmis Performance Parts
Old 05-19-2011, 08:32 AM   #1
CurleysRacecars
Default How do you guys mount steel bodies to a full tube chassis?
Just looking for everyone elses ideas. Ive seen a couple simple tabs here and there with bolts...any other way? Tab/bolt placement? Any input would be appreciated.
Thanks!
Kyle Curley
Curleys Racecars & Components
(916)-397-3465
www.curleysracecars.com
DEALER FOR:
Kinetic Engineering
Viking Performance
AFCO
Dynatech Headers
Call or message for the best pricing!
CurleysRacecars is offline   Reply With Quote
Old 05-19-2011, 08:42 AM   #2
neetchracer
Member
Pullin gears
neetchracer's Avatar
Default Re: How do you guys mount steel bodies to a full tube chassis?
I weld the bottom 4 link bar to plates welded to the rocker/ body. A couple 1/2" tubes on each side welded from the a pilar bars to the a pilars. A few various 1/2" tubes on the sides of the main hoop and by the rear window area welded to the body( generally on a window pinch weld where metal will not get distorted). I do the rear one of two ways. I either weld tabs to the outer most corner pinch welds in the trunk and put a tube between them, or I weld frame rails directly to the rear trunk wall.
neetchracer is offline   Reply With Quote
Old 05-19-2011, 08:58 AM   #3
ashtrak
ashtrak's Avatar
Location: 4.2 miles away from paridise North East, Maryland
[/IMG]
In the pic you can see the tabs I made ao all 4 ends I cut the inner rocker panel out then welded 1/8" flat steel in its place then drilled and tapped it for 2 bolts in each tab. Then in the back of the body I welded tabs to go through the tail end bar that was capped then drilled and tapped.
ashtrak is offline   Reply With Quote
Old 05-19-2011, 08:58 AM   #4
ashtrak
ashtrak's Avatar
Old 05-19-2011, 09:01 AM   #5
ashtrak
ashtrak's Avatar
Old 05-19-2011, 09:59 AM   #6
85montess
Pre-Staged
85montess's Avatar
It depends on if you are keeping the rocker and door jambs stock or not. Using the stock rockers, I reinforce the rear of the rocker with 1/8" plate/angle and weld a gusset tab to it that will lay on top of the gusset tab welded to the chassis that will line up and make the "shelf". This really helps when taking the body on and off to keep it from going down too far.
At rear, I make the rear bar on the chassis wider, so that I weld plates to it and attach it to the rear bumper area.
At the front of the rockers, I weld gusset tabs to the chassis at the end of the 6A/6B bars and then flat plates to the rockers with nuts welded to the inside of the plates.
I weld a couple of more gusset tabs at the midway of the main hoop facing backwards and then make some tabs/plates with nuts welded to them that will be attached to the door jamb area.
If you zoom in on this picture at the rear of the main hoop, you can see the tab with an aluminum spacer bolted over the quarter trim panel.
Bill Mitchell
BMR Performance
_____________________________
http://s254.photobucket.com/albums/hh93/85monte_ss/
85montess is offline   Reply With Quote
Old 05-19-2011, 10:43 AM   #7
overkillrc
7.86 @ 8800DA 3365lb 275s
overkillrc's Avatar
last one i did i just welded plates to the rockers and weld the chassis to the plates. then ran some bars from the dash bar to the door pilar.
Justin Kill
Overkill Race Cars 970-581-8134
Loveland, CO
www.overkillracecars.com
H-body control arms and parts
http://www.overkillracecars.com/Products.html
overkillrc is offline   Reply With Quote
Old 05-19-2011, 10:53 AM   #8
JSutphin
JSutphin's Avatar
very nice work !
JSutphin is offline   Reply With Quote
Old 05-20-2011, 12:54 PM   #9
1big2JZ
Burnout box
Very nice indeed Bill !
1big2JZ is offline   Reply With Quote
Old 05-20-2011, 11:14 PM   #10
novakid85
SD AUTOFAB
novakid85's Avatar
Quote:
X2
novakid85 is offline   Reply With Quote
Old 09-21-2011, 06:03 AM   #11
mcrider29
Pre-Staged
X2
mcrider29 is offline   Reply With Quote
