| The Photo and Video Store All video and photo views are free of charge. No late fees!!! Post your favorite racing photos and videos here... |
Thread Tools | Display Modes |
#1 |
Member
Pullin gears
Thanks to; http://www.DYNOTUNEUSA.COM http://www.boostwerx.com/olander.html E-85 since 06' New car in testing stage-09' 8.14 @ 174 3410 lbs.
#2 |
That's nuts. Cool though! What is your engine/turbo combo?
Pick battles big enough to matter, small enough to win. - Jonathan Kozol Flatout Gaskets Harland Sharp Rocker Arms PAC Valve Springs Probell Bell Housings Pro/Cam Oil Pans |
#3 |
Member
Pullin gears
427W Dart Block
Eagle crank, rods TFS-R hogged out 1-5/8" flipped headers to twin PT 78 GTS Super Victor Intake EFI 80 MM Accufab Custom I/C Bell core Ed Curtis cam little guy, solid roller Power is over at 6300 rpm's, still trying to figure that one out, been fighting it all summer???? Any input???????
#4 | |
Nice power !
Got pictures of the setup ? I would assume one of 2 possabilitys. 1 your out of camshaft 2 you are out of cylinder head for the rpm your looking for with the CI. Quote:
#5 |
Badass!
Brant Campbell http://www.amarilloracers.com Owner of the Quickest and Fastest car that doesn't run yet. ![]()
#6 |
Very nice! Have any back pressure data?
CDR Performance, LLC Aeroquip Fittings & Hose Aeromotive Pumps AMS-500-AMS-1000 S300-S400 turbos CustomCams CSU Carbs JGS W/G & BOV Magnafuel Pumps Stroud Safety & more |
#7 |
#8 |
Member
Pullin gears
I was having issues with back pressure when I had on-centers on it. I then changed over to tangs. We did a pull at 27 psi a few weeks back and only saw 30 psi on the guage. We were taking the measurement off the #8 port about 2" from the head.
My first set-up had on-center MP 60-1 908 rwhp @ 20 psi. HP went flat at 6000rpm's. Tried a pair of 74's on-center picked up 100 hp 6100 then flat. Once we see full boost it will not gain any more hp with rpm, some but not much. Even added 10* more duration in the cam and it only bumped it up maybe 100 rpm's. I have made a lot of changes this summer to get it where it is at everything helped a little bit but I feel I am missing something somewhere. Never did see a huge increase anywhere. Changes turbos torque converter valve springs cam on-center to tang intake downpipe to the rear went from 3" to 4" by-passed I/C no change
#9 | |
Hit me up via PM.
Quote:
#10 |
Spooled up
what size turbine housings?
Some people are alive, only because its illegal to kill them. |
#11 |
Member
Pullin gears
#12 |
Member
Pullin gears
Here's a bunch of picts from the last couple of years, some are old most are recent
http://www.imagestation.com/album/pi...?id=2086775316
#13 |
Launchin
Im going to go on a lim here and give some advise baised on what I have learened playing with GN's
1st your turbin wheel plays a big roll in Back Presure, If your using a P - trim wheel your in for a lot of back presure any thing over 25psi of boost. For every PSI over 25 your going to add 5 psi back presure. Now if you chage to a GTQ wheel you will not pick up any extra b/p do to the better design of the exaust wheel. Also the Newturbos from turbonetics are suposed to be one step up from a GTQ wheel. Your next issue can be the Heads what do they Flow?? If you cant move enough out you cant put any more in hence the Back presure issues again. Example going from a stock GN head to a race ported version dropped back pressure and maid 90 more HP with just the better flow and the same turbo motor also spun up faster and maid power spun 500-600 RPM faster as well. Next issue with back pressure Header size, At your hp level you should be running a 2" primary header so you can move the exaust out faster. This will hurt low end #'s but will most likly pick up as soon as you hit boost. Turbos are tricky you cant just bolt them on and think there going to add tons of power and nt have issues. You have to find all the parts that work same as any engine combo. Turbos just add more veriables that have to be addressed. Hope this helps you some and Id try a better set of heads 1st or have yours ported a bunch more.
[B] ![]() Wife and her blazer
#14 |
Spooled up
This stuff's cool and all; at least it isn't ricers; But just cause you can pay somebody the figure to build you a killer motor doesn't mean you can hook it, look at top fuel... The car with the most horsepower isn't always the first the stripe.
Not trying to take away from these guys awesome efforts, but I and alot of others don't give a shiite if someone can take a locomotive based powerplant convert it to hydrogen based fuel, boost it till it blows, and run it on dynamite, if it has no real world speed, or danger. In other words this is like bragging about phucking a shemale from Thailand with a condom on... Yeah you got off; but so did the goat your dad was doin last night.
Life is a lesson, you learn it when you're through |
#15 | |
Member
Pullin gears
Quote:
BTW, I looked at some of your last few posts, you seem like a huge contributor to this forum, keep up the good work...and thanx for the input...
| Thread Tools | |
| Display Modes | |
