Pick a 9" Rear for my car. - Yellow Bullet Forums
Go Back   Yellow Bullet Forums > Technical Section > Rearends and Differentials - Mark Williams Enterprises
View Poll Results: Which style of Rear to go with?
Stamped Aftermarket F-body Housing 10 41.67%
Fabricated Rear Housing 14 58.33%
Other (post reason) 0 0%
Voters: 24. You may not vote on this poll
Old 05-02-2011, 09:36 PM   #1
RoadHammer
Burnout box
Default Pick a 9" Rear for my car.
I need help in deciding what rearend to put in my car. I can't decide on whether to get a Stamped housing 9" OR a fabricated housing 9" (Like the Moser M9).
Personally, I am leaning towards the M9, but after talking to a few local racers, the consensus of opinion is that I shouldn't waste my money on Fab 9 stuff.
Specifics:
Third gen Camaro.
Small-block single turbo car (800-1000hp)
Stock-style suspension.
Will see a fair amount to street use.
Any help will be appreciated.
Thanks.
RoadHammer is offline   Reply With Quote
Old 05-03-2011, 11:54 PM   #2
vegaman924
vegaman924's Avatar
Default Re: Pick a 9" Rear for my car.
stamped steel all you need just brace it
vegaman924 is offline   Reply With Quote
Old 05-03-2011, 11:59 PM   #3
jeff c
pig hunter
jeff c's Avatar
put 1500hp through the strange 9" with a back brace. no need for a fab piece other then they look cool lol.
sr-20 headed 4.60x3.70=492cid 2.49 per cid @ 9100rpm's
jeff c is offline   Reply With Quote
Old 05-05-2011, 06:52 PM   #4
ChevyD
Pre-Staged
ChevyD's Avatar
Love my M9
ChevyD is offline   Reply With Quote
Old 05-05-2011, 07:32 PM   #5
wforty94
Member
Pullin gears
aren't the M9 housings lighter than the regular stamped 9" housings?
wforty94 is offline   Reply With Quote
Old 05-05-2011, 07:46 PM   #6
jeff c
pig hunter
jeff c's Avatar
no^^^^. cm to cm the stamp is lighter. the brothers is about 5# lighter both with ford ends,back brace, one is 49 1/2" and the other is 49"
Old 05-06-2011, 02:24 PM   #7
Steve Burger
Member
Pullin gears
Check ours out. A little more than stamped, but a lot more features including a back brace.
WWW.BURKHARTCHASSIS.COM
2013 LSx Shootout Drag Radial runner up.
Steve Burger is offline   Reply With Quote
Old 05-13-2011, 01:29 PM   #8
rskrause
rskrause's Avatar
I voted "stamped" but the stock type is not a simple stamping. It's a "banjo" type axle and it is made from a number of stamped pieces that are welded together. So, it is "fabbed" in a sense.
Best description I could find with a quick Google search:
A method for manufacturing a banjo-type drive axle housing for a motor vehicle is disclosed. The first step is the operation of forming the substantially identical upper and lower half members having a U-shaped cross-section along entire length thereof with radially extending wall sections. Each of the members is metal formed, such as by stamping or forging, from a blank sheet of steel. Next step is to select a desired box-section of an axle beam portions, and a desired size of an opening in a central portion of the axle housing. Then, if necessary, the wall sections of the housing half members are trimmed so that when assembled said housing half members provide the desired box section and size of the opening in the central portion of the axle housing. Finally, the trimmed housing half members are welded to each other to produce the axle housing.
Here's a link to a pic showing how the pieces might fit together.
http://www.freepatentsonline.com/6609649-0-large.jpg
rskrause is offline   Reply With Quote
Old 05-17-2011, 02:44 PM   #9
T/ALT1
Spooled up
Burkhart has really nice rearends/parts and fair prices. I just ordered a Fab 9" housing/axles etc... from Chuck Burkhart and he is very knowledgeable and very friendly as well. Thanks again Chuck. later Clint
1995 Pontiac T/A, LSX,S475,Glide, Fab 9",275radials! streetcar
T/ALT1 is offline   Reply With Quote
Old 05-18-2011, 12:28 AM   #10
RoadHammer
Burnout box
I did talk to Burkhart last week (can't recall the guy's name off-hand), they answered all my dumb questions. I like how they setup their housings to use anyone's suspension parts instead of forcing you to buy their TA/cross-member like other companies that make Fab9 housings.
Old 05-18-2011, 05:04 AM   #11
wforty94
Member
Pullin gears
I know the benefits of an aftermarket braced rear end and the super trick ones like TRZ and Burkhart, but has anybody ever seen an aftermarket 9" housing such as those by Moser or Strange fail without a backbrace?
Old 05-18-2011, 11:56 AM   #12
T/ALT1
Spooled up
For under 800-1,000HP the stock style housing should work fine but will you go faster?
Old 06-07-2011, 12:00 AM   #13
RoadHammer
Burnout box
Quote:
If I plan on going faster, I don't want to have to spend money twice to upgrade again down the road.
Having said that, I pulled the trigger on the Burkhart Chassis piece.
Old 06-07-2011, 12:22 PM   #14
Steve Burger
Member
Pullin gears
Thanks for the order.
Old 06-09-2011, 12:42 AM   #15
Pat7272
Just curious - did you go with a spool or differential?
1973 Plymouth Duster
G3 Hemi/727/S60
[Under Construction]
2013 Chevy 2500HD
Dmax Tow/Support Vehicle
Pat7272 is offline   Reply With Quote
Resources saved on this page: MySQL 2.11%
