Hauling 2 Dragsters in a trailer - Yellow Bullet Forums
Old 04-25-2011, 06:07 PM   #1
fastfords
Pre-Staged
Default Hauling 2 Dragsters in a trailer
We have a 32 foot trailer and have been thinking about putting downswept headers on both dragsters. I've been told you can't do it. We have a quad at the rear of the trailer so the cars need to be at the front. Does anyone know if it can be done??
fastfords is offline   Reply With Quote
Old 04-25-2011, 06:15 PM   #2
Chris Van
Chris Van's Avatar
Default Re: Hauling 2 Dragsters in a trailer
Used to haul 2 dragsters in a 32 foot trailer but both had upswept headers, along with 4 wheeler, generator, etc..... I have also heard it could not be done with downswept headers but I cannot speak from experience.... Sorry I wasn't any help to ya either.
Quote:
Originally Posted by FRANKTHECRANK View Post
This is the Bullet, where you are guilty until proven innocent. That's just the way it is.
http://www.miawings.com/
Chris Van is offline   Reply With Quote
Old 04-25-2011, 06:50 PM   #3
Dragwayman
Member
Pullin gears
Dragwayman's Avatar
I did yes in a 32 footer both had downswepts, I backed one in and pulled one in with no trouble.
Welcome To The "House Of Hook"
www.CarolinaDragway.com
www.GrudgeRacer.com
Dragwayman is offline   Reply With Quote
Old 04-25-2011, 07:27 PM   #4
racer1688
Burnout box
had 2 in 30' , 1 with up & 1 with down. plus 2 scooters. 10lbs of sh*t in 5lb bag.
racer1688 is offline   Reply With Quote
Old 04-25-2011, 07:33 PM   #5
red light
Launchin
could you put the headers on when you get to the track?
red light is offline   Reply With Quote
Old 04-25-2011, 09:28 PM   #6
WFGE
Pre-Staged
WFGE's Avatar
yes it can be done, took two dragsters, both with down sweep headers, 2 drums of alcohol and alot of other gear to darlington...........28 ft trailer no problem
WFGE is offline   Reply With Quote
Old 04-25-2011, 09:42 PM   #7
rodracer
Pre-Staged
rodracer's Avatar
Yes back one in and pull one in. both had down swepts. 32ft, 2. 240" dragsters, golf cart with rear seat, tool box, and 2 drums of fuel.
rodracer is offline   Reply With Quote
Old 04-25-2011, 10:57 PM   #8
Dragwayman
Member
Pullin gears
Dragwayman's Avatar
Quote:
LMAO now that was a full trailer
www.GrudgeRacer.com
Old 04-26-2011, 12:46 AM   #9
BSTracing
Member
Pullin gears
BSTracing's Avatar
Thats using all of your trailer space.......
BSTracing is offline   Reply With Quote
Old 04-26-2011, 01:22 AM   #10
chevydude
chevydude's Avatar
Garage
32ft.. that's a ton of room for two dragsters with downswept headers... we did it with a 28 footer!! The 32 footer was like a dream...Back the first car in against the wall, If you have a dragster dolly it makes it that much easier because then you can kick the front - end all the way over against the wall, then just drive the second car right into the trailer, you'll have about 6 inches between the rear & front tire of each car....We get the cars in just enough to clear the chute on the forward facing car....just put a good piece of timber in the step of the side door, the forward facing car maybe closer to that edge of the step.....The golf cart & drums of alky right in the front of the trailer...I hope of course you use load Bars ...But it can be done with ease.. we can load two cars in just about 5 minutes no problem!!
The Ultimate budget build!!Ford makes it, Chevy shakes it...86 Coupe S/S, BBC Powered 10 to1 489ci very mild..615/.620 flat tapped cam,(Procomp heads)850 alky carb, Powerglide, 4.10's 9" tire.best to date= 1.331 60' & 6.053 @ 112mph 1/8th, Has been 9.90's In the quarter but have not run the quarter since figuring out some issues, Car & motor built by me, Build cost of entire car Just under $5000.00
https://www.youtube.com/watch?featur...&v=kJaN3fgNl1k Still sorting!
chevydude is offline   Reply With Quote
Old 04-26-2011, 09:59 AM   #11
fastfords
Pre-Staged
Thanks for the help. I was calling around checking header prices and it was one of them that told me they wouldn't fit with downswept on both cars..
Old 04-26-2011, 10:03 AM   #12
thrasher
thrasher's Avatar
What about lifting the front of one car ? My buddy put a camaro and a 235" dragster in a trailer that size. They winch up the front of the dragster and put a crossbar up that has pockets to hold the front wheels. Actually lots of room I thought it was odd and alot of work at first but it goes pretty quick.
thrasher is offline   Reply With Quote
Old 04-26-2011, 10:18 AM   #13
dennysavage
dennysavage's Avatar
Quote:
The one we used at Hawleys, carried 2 S/C dragsters, and a Firebird S/G car... It was a 52ft Haulmark [POS]...
dennysavage is offline   Reply With Quote
Old 04-26-2011, 10:27 AM   #14
scorpion5
Spooled up
I just sold a 32 ft trailor built just for that. it had a lift. back the first one in ,pick the front up with the cable lift.pull the second one in forward with no trouble.
scorpion5 is offline   Reply With Quote
Old 04-26-2011, 11:04 AM   #15
carby
carby's Avatar
Just did it, like everyone said, back one in and drive one in, our cars were 30" different in length which actually helped, we had to take one header off one of the cars.
"Governments do not produce anything. So the destruction of those incomes will be offset by the saving produced by not complying with whatever it was they did to justify their existence." Mark O'Neal
carby is offline   Reply With Quote
